#ifndef __LQ12864_h
#define __LQ12864_h
#include "reg52.h"
#include "intrins.h"
#include "codetab.h"
sbit SCL=P1^0; //串行時(shí)鐘
sbit SDA=P1^1;//串行數(shù)據(jù)
sbit RES=P1^2;
sbit DC=P1^3;//串行數(shù)據(jù)
sbit keyup=P2^0;
sbit keyenter=P2^2;
sbit keydown=P2^1;
#define high 1
#define low 0
#define X_WIDTH 128
#define Y_WIDTH 64
void delay(uint z) //1ms
unsigned int x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
// 通過SPI總線寫一個(gè)字節(jié)
void Write_SPI_Data(uchar ucData)
uchar i = 8;
DC = 1;
SCL = 0;
while (i--)
if (ucData & 0x80)
SDA = 1;
SDA = 0;
SCL = 1;
_nop_();
SCL = 0;
ucData <<= 1;
void Write_SPI_Command(uchar ucCmd)
unsigned char i = 8;
DC = 0;
SCL = 0;
while (i--)
if (ucCmd & 0x80)
SDA = 1;
SDA = 0;
SCL = 1;
_nop_();
SCL = 0;
ucCmd <<= 1;
/*********************OLED 設(shè)置坐標(biāo)************************************/
void OLED_Set_Pos(uchar x, uchar y)
Write_SPI_Command(0xb0+y); //設(shè)置頁(yè)地址
Write_SPI_Command(((x&0xf0)>>4)|0x10);//設(shè)置行高四位地址
Write_SPI_Command((x&0x0f)|0x01);//設(shè)置行低四位地址,最低位為1
/*********************OLED復(fù)位************************************/
void OLED_CLS(void)
unsigned char y,x;
for(y=0;y<8;y++)
Write_SPI_Command(0x01);
Write_SPI_Command(0x10);
for(x=0;x<X_WIDTH;x++)
Write_SPI_Data(0);
/*********************OLED初始化************************************/
void OLED_Init(void)
delay(500);
Write_SPI_Command(0xAE); //display off
Write_SPI_Command(0x20); //Set Memory Addressing Mode
Write_SPI_Command(0x10); //00,Horizontal Addressing Mode;01,Vertical Addressing Mode;10,Page Addressing Mode (RESET);11,Invalid
Write_SPI_Command(0xb0); //Set Page Start Address for Page Addressing Mode,0-7
Write_SPI_Command(0xc8); //Set COM Output Scan Direction
Write_SPI_Command(0x00);//---set low column address
Write_SPI_Command(0x10);//---set high column address
Write_SPI_Command(0x40);//--set start line address
Write_SPI_Command(0x81);//--set contrast control register
Write_SPI_Command(0x7f);
Write_SPI_Command(0xa1);//--set segment re-map 0 to 127
Write_SPI_Command(0xa6);//--set normal display
Write_SPI_Command(0xa8);//--set multiplex ratio(1 to 64)
Write_SPI_Command(0x3F);//
Write_SPI_Command(0xa4);//0xa4,Output follows RAM content;0xa5,Output ignores RAM content
Write_SPI_Command(0xd3);//-set display offset
Write_SPI_Command(0x00);//-not offset
Write_SPI_Command(0xd5);//--set display clock divide ratio/oscillator frequency
Write_SPI_Command(0xf0);//--set divide ratio
Write_SPI_Command(0xd9);//--set pre-charge period
Write_SPI_Command(0x22); //
Write_SPI_Command(0xda);//--set com pins hardware configuration
Write_SPI_Command(0x12);
Write_SPI_Command(0xdb);//--set vcomh
Write_SPI_Command(0x20);//0x20,0.77xVcc
Write_SPI_Command(0x8d);//--set DC-DC enable
Write_SPI_Command(0x14);//
Write_SPI_Command(0xaf);//--turn on oled panel
OLED_CLS();
OLED_Set_Pos(0,0);
/*****************功能描述:顯示16*16點(diǎn)陣 顯示的坐標(biāo)(x,y),y為頁(yè)范圍0~7****************************/
void OLED_P16x16Ch(uchar x, y, N)
unsigned char wm=0;
unsigned int adder=32*N;
OLED_Set_Pos(x , y);
for(wm = 0;wm < 16;wm++)
Write_SPI_Data(F16x16[adder]);
adder += 1;
OLED_Set_Pos(x,y + 1);
adder += 1;
#endif
#ifndef __codetab_h
#define __LED_H
/***************************16*16的點(diǎn)陣字體取模方式:共陰——列行式——逆向輸出*********/
unsigned char code F16x16[] =
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
0x20,0x20,0x10,0x10,0x28,0x24,0x22,0x29,0xB2,0x64,0x28,0x10,0x10,0x20,0x20,0x00,
0x00,0x80,0x80,0x9F,0x41,0x41,0x21,0x1D,0x01,0x21,0x21,0x5F,0x40,0x80,0x00,0x00,//貪,1
0x00,0xFC,0x04,0x04,0xFC,0x20,0x10,0x4C,0x4B,0x48,0x48,0x48,0xC8,0x08,0x08,0x00,
0x00,0x0F,0x04,0x04,0x0F,0x00,0x30,0x48,0x44,0x42,0x42,0x41,0x40,0x40,0x70,0x00,//吃,2
0x00,0xF8,0x08,0xFF,0x08,0xF8,0x20,0x18,0xC8,0x08,0x09,0x0E,0x88,0x28,0x18,0x00,
0x20,0x63,0x21,0x1F,0x11,0x19,0x30,0x00,0x3F,0x44,0x42,0x41,0x40,0x40,0x78,0x00,//蛇,3
0x10,0x60,0x02,0x8C,0x00,0x08,0xF9,0x4E,0xC8,0x20,0x58,0x4F,0x48,0xC8,0x08,0x00,
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游,4
0x00,0x08,0x48,0x88,0x08,0xC8,0x38,0x40,0x40,0x40,0xFF,0x20,0x22,0xAC,0x20,0x00,
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲,5
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//" ",6
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//" ",7
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//8
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//一,9
0x80,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x80,0x00,
0x00,0x80,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,//開10
0x10,0x10,0xF0,0x1F,0x10,0xF0,0x00,0x40,0xE0,0x58,0x47,0x40,0x50,0x60,0xC0,0x00,
0x40,0x22,0x15,0x08,0x16,0x21,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,//始11
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游12
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲13
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 14
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x30,0x0C,0x03,0x00,
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0 15
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//16
0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x00,
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//二,17
0x20,0x30,0xAC,0x63,0x20,0x18,0x08,0x48,0x48,0x48,0x7F,0x48,0x48,0x48,0x08,0x00,
0x22,0x67,0x22,0x12,0x12,0x12,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,//結(jié) 18
0x04,0x04,0xE4,0x24,0x24,0x24,0x24,0xFF,0x24,0x24,0x24,0x24,0xE4,0x04,0x04,0x00,
0x40,0x40,0x27,0x22,0x12,0x0A,0x06,0xFF,0x06,0x0A,0x12,0x22,0x27,0x40,0x40,0x00,//束 19
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游 20
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲 21
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 22
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 23
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 24
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 25
0x40,0x40,0x42,0xCC,0x00,0x00,0xFC,0x24,0xA4,0x24,0x22,0x22,0xA3,0x62,0x00,0x00,
0x00,0x40,0x20,0x1F,0x20,0x58,0x47,0x50,0x48,0x45,0x42,0x45,0x48,0x50,0x40,0x00,//返26
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 27
0x00,0x00,0xFE,0x02,0x02,0xF2,0x12,0x12,0x12,0xF2,0x02,0x02,0xFE,0x00,0x00,0x00,
0x00,0x00,0x7F,0x20,0x20,0x27,0x24,0x24,0x24,0x27,0x20,0x20,0x7F,0x00,0x00,0x00,//回28
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 29
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 30
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 31
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//32
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//二,33
0x22,0x67,0x22,0x12,0x12,0x12,0x00,0xFE,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,//結(jié) 34
0x40,0x40,0x27,0x22,0x12,0x0A,0x06,0xFF,0x06,0x0A,0x12,0x22,0x27,0x40,0x40,0x00,//束 35
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游 36
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲 37
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 38
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0 39
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 40
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 41
0x00,0x40,0x20,0x1F,0x20,0x58,0x47,0x50,0x48,0x45,0x42,0x45,0x48,0x50,0x40,0x00,//返42
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 43
0x00,0x00,0x7F,0x20,0x20,0x27,0x24,0x24,0x24,0x27,0x20,0x20,0x7F,0x00,0x00,0x00,//回44
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 45
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 46
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0 47
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//48
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//一,49
0x00,0x80,0x40,0x30,0x0F,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,//開,50
0x40,0x22,0x15,0x08,0x16,0x21,0x00,0x00,0xFE,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,//始,51
0x04,0x04,0x7E,0x81,0x40,0x30,0x0F,0x40,0x7F,0x00,0x44,0x84,0x7F,0x04,0x04,0x00,//游,52
0x00,0x20,0x10,0x0C,0x03,0x04,0x18,0x80,0x40,0x20,0x17,0x18,0x26,0x41,0xF0,0x00,//戲.53
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 54
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // 55
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 56
0x08,0x04,0x93,0x92,0x96,0x9A,0x92,0xFA,0x94,0x93,0x92,0x96,0xFA,0x02,0x02,0x00,
0x40,0x40,0x47,0x24,0x24,0x14,0x0C,0xFF,0x04,0x04,0x24,0x44,0x24,0x1C,0x00,0x00,//第257
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 58
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//一3 59
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 60
0x00,0x00,0x10,0x11,0x16,0x10,0x10,0xF0,0x10,0x10,0x14,0x13,0x10,0x00,0x00,0x00,
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關(guān)4 61
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 62
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // 63
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 64
0x40,0x40,0x47,0x24,0x24,0x14,0x0C,0xFF,0x04,0x04,0x24,0x44,0x24,0x1C,0x00,0x00,//第2 65
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 66
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//二 67
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 68
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關(guān) 69
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 70
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, // 71
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 72
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 73
0x00,0x40,0x20,0x1F,0x20,0x58,0x47,0x50,0x48,0x45,0x42,0x45,0x48,0x50,0x40,0x00,//返74
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 75
0x00,0x00,0x7F,0x20,0x20,0x27,0x24,0x24,0x24,0x27,0x20,0x20,0x7F,0x00,0x00,0x00,//回76
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 77
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 78
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 79
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 80
0x40,0x40,0x47,0x24,0x24,0x14,0x0C,0xFF,0x04,0x04,0x24,0x44,0x24,0x1C,0x00,0x00,//第2 81
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 82
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//一3 83
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 84
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關(guān)4 85
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 86
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0 87
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 88
0x40,0x40,0x47,0x24,0x24,0x14,0x0C,0xFF,0x04,0x04,0x24,0x44,0x24,0x1C,0x00,0x00,//第2 89
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 90
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x00,//二 91
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// ,// 92
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關(guān) 93
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 94
0x00,0x00,0x00,0x10,0x08,0x04,0x18,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x00,//√0 95
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 96
0x40,0x40,0x42,0xCC,0x00,0x50,0x4E,0xC8,0x48,0x7F,0xC8,0x48,0x48,0x40,0x00,0x00,
0x00,0x40,0x20,0x1F,0x20,0x50,0x4C,0x43,0x40,0x40,0x4F,0x50,0x50,0x5C,0x40,0x00,//選97
0x10,0x10,0xFF,0x10,0x00,0x82,0x86,0x4A,0x52,0xA2,0x52,0x4A,0x86,0x80,0x80,0x00,
0x42,0x82,0x7F,0x01,0x00,0x10,0x12,0x12,0x12,0xFF,0x12,0x12,0x12,0x10,0x00,0x00,//擇98
0x81,0x81,0x41,0x41,0x21,0x11,0x0D,0x03,0x0D,0x11,0x21,0x41,0x41,0x81,0x81,0x00,//關(guān)99
0x40,0x40,0x40,0x40,0x40,0x40,0xFF,0x44,0x44,0x44,0x44,0x44,0x44,0x40,0x40,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x02,0x04,0x08,0x10,0x00,0x00,0x00,//卡100
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,// 101
0x00,0x08,0x78,0xE8,0x00,0x00,0x00,0xD8,0xF8,0xC0,0x00,0x00,0xC0,0x38,0x08,0x00,
0x00,0x00,0x00,0x03,0x3F,0x18,0x07,0x00,0x00,0x0F,0x3E,0x0E,0x01,0x00,0x00,0x00,//W 102
0x00,0x00,0x08,0xF8,0xF8,0x08,0x08,0x08,0x08,0x08,0x88,0xC8,0x08,0x18,0x00,0x00,
0x00,0x20,0x20,0x3F,0x3F,0x21,0x21,0x21,0x21,0x21,0x21,0x23,0x20,0x30,0x08,0x00,//E 103
0x00,0x00,0x08,0xF8,0xF8,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x20,0x20,0x3F,0x3F,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x30,0x08,0x00,//L 104
0x00,0xC0,0xE0,0x70,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x18,0x20,0x00,
0x00,0x07,0x0F,0x1C,0x10,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x10,0x10,0x08,0x00,//C 105
0x00,0xC0,0xE0,0xF0,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x18,0x30,0xE0,0xC0,0x00,
0x00,0x03,0x0F,0x1F,0x10,0x20,0x20,0x20,0x20,0x20,0x20,0x10,0x18,0x0F,0x07,0x00,//O 106
0x00,0x08,0xF8,0x38,0xE0,0x80,0x00,0x00,0x00,0x00,0xE0,0x18,0xF8,0xF8,0x08,0x00,
0x20,0x20,0x3F,0x20,0x01,0x07,0x1E,0x38,0x0C,0x03,0x20,0x20,0x3F,0x3F,0x20,0x20,//M 107
0x00,0x20,0x20,0x3F,0x3F,0x21,0x21,0x21,0x21,0x21,0x21,0x23,0x20,0x30,0x08,0x00,//E 108
#endif
#include "reg52.h"
sbit RES=P1^2;
sbit keyup=P3^0;
sbit keyenter=P3^2;
sbit keydown=P3^1;
uchar func_index=0;
void (*current_operation_index)();
void func1();
void func2();
void func3();
void func4();
void func5();
void func6();
void func7();
void func8();
void delay_1ms(uint z) //1ms
unsigned int x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
typedef struct
uchar current;
uchar up;//向上翻索引號(hào)
uchar down;//向下翻索引號(hào)
uchar enter;//確認(rèn)索引號(hào)
void (*current_operation)();
} key_table;
key_table code table[]=
{0,2,1,3,(*func1)},//第一層,開始
{1,0,2,7,(*func2)},//第一層,結(jié)束
{2,1,3,6,(*func3)},//第一層, 返回
{3,5,4,3,(*func4)},//第二層,第一關(guān)
{4,3,5,4,(*func5)},//第二層, 第二關(guān)
{5,4,3,0,(*func6)},//第二層, 返回
{6,0,0,0,(*func7)}, //第0層,welcome
{7,0,0,0,(*func8)}, // 清屏
RES=0;
delay_1ms(10);
RES=1;
delay_1ms(10);
DC=0;
OLED_Init();
delay_1ms(5);
if((keyup==0)||(keydown==0)||(keyenter==0))
delay_1ms(1);//消抖
if(keyup==0)
delay_1ms(1);
if(keyup==0)
func_index=table[func_index].up; //向上翻
while(!keyup);//松手檢測(cè)
if(keydown==0)
delay_1ms(1);
if(keydown==0)
func_index=table[func_index].down; //向下翻
while(!keydown);
if(keyenter==0)
delay_1ms(1);
if(keyenter==0)
func_index=table[func_index].enter; //確認(rèn)
while(!keyenter);
OLED_Init();
current_operation_index=table[func_index].current_operation;
(*current_operation_index)();//執(zhí)行當(dāng)前操作函數(shù)
#include "LQ12864.h"
void func1()
unsigned char i;
OLED_P16x16Ch(24,0,1); //貪吃蛇游戲
OLED_P16x16Ch(40,0,2);
OLED_P16x16Ch(57,0,3);
OLED_P16x16Ch(74,0,4);
OLED_P16x16Ch(91,0,5);
for(i=0; i<8; i++)//通過點(diǎn)整顯示漢字 -- i表示字表數(shù)組的位置
OLED_P16x16Ch(i*16,2,i+8); //開始
OLED_P16x16Ch(i*16,4,i+16); //結(jié)束
OLED_P16x16Ch(i*16,6,i+24); //返回
void func2()
unsigned char i;
OLED_P16x16Ch(24,0,1); //貪吃蛇射游戲
OLED_P16x16Ch(i*16,2,i+48); //開始
OLED_P16x16Ch(i*16,4,i+32); //結(jié)束
void func3()
unsigned char i;
OLED_P16x16Ch(i*16,6,i+40); //返回
void func4()
unsigned char i;
OLED_P16x16Ch(16,0,97); //選擇關(guān)卡
OLED_P16x16Ch(32,0,98);
OLED_P16x16Ch(48,0,99);
OLED_P16x16Ch(64,0,100);
OLED_P16x16Ch(i*16,2,i+80); //第一關(guān)√
OLED_P16x16Ch(i*16,4,i+64); //
void func5()
unsigned char i;
OLED_P16x16Ch(i*16,2,i+56); //第二關(guān)√
OLED_P16x16Ch(i*16,4,i+88); //
void func6()
unsigned char i;
OLED_P16x16Ch(i*16,2,i+56); //返回√
void func7()
OLED_P16x16Ch(16,0,102); //WELCOME
OLED_P16x16Ch(32,0,103);
OLED_P16x16Ch(48,0,104);
OLED_P16x16Ch(64,0,105);
OLED_P16x16Ch(80,0,106);
OLED_P16x16Ch(96,0,107);
OLED_P16x16Ch(112,0,108);
void func8()
delay(400);
OLED_CLS();
