W5500官方驅(qū)動 ioLibrary_Driver-master V4.0.0, 2018年3月29日最新板,下載不容易
2018-8-3 23:49 上傳
單片機源程序如下:
- #include <stdio.h>
- #include "loopback.h"
- #include "socket.h"
- #include "wizchip_conf.h"
- #if LOOPBACK_MODE == LOOPBACK_MAIN_NOBLCOK
- int32_t loopback_tcps(uint8_t sn, uint8_t* buf, uint16_t port)
- int32_t ret;
- uint16_t size = 0, sentsize=0;
- #ifdef _LOOPBACK_DEBUG_
- uint8_t destip[4];
- uint16_t destport;
- #endif
- switch(getSn_SR(sn))
- case SOCK_ESTABLISHED :
- if(getSn_IR(sn) & Sn_IR_CON)
- getSn_DIPR(sn, destip);
- destport = getSn_DPORT(sn);
- printf("%d:Connected - %d.%d.%d.%d : %d\r\n",sn, destip[0], destip[1], destip[2], destip[3], destport);
- #endif
- setSn_IR(sn,Sn_IR_CON);
- if((size = getSn_RX_RSR(sn)) > 0) // Don't need to check SOCKERR_BUSY because it doesn't not occur.
- if(size > DATA_BUF_SIZE) size = DATA_BUF_SIZE;
- ret = recv(sn, buf, size);
- if(ret <= 0) return ret; // check SOCKERR_BUSY & SOCKERR_XXX. For showing the occurrence of SOCKERR_BUSY.
- size = (uint16_t) ret;
- sentsize = 0;
- while(size != sentsize)
- ret = send(sn, buf+sentsize, size-sentsize);
- if(ret < 0)
- close(sn);
- return ret;
- sentsize += ret; // Don't care SOCKERR_BUSY, because it is zero.
- break;
- case SOCK_CLOSE_WAIT :
- //printf("%d:CloseWait\r\n",sn);
- #endif
- if((ret = disconnect(sn)) != SOCK_OK) return ret;
- printf("%d:Socket Closed\r\n", sn);
- #endif
- break;
- case SOCK_INIT :
- printf("%d:Listen, TCP server loopback, port [%d]\r\n", sn, port);
- #endif
- if( (ret = listen(sn)) != SOCK_OK) return ret;
- break;
- case SOCK_CLOSED:
- //printf("%d:TCP server loopback start\r\n",sn);
- #endif
- if((ret = socket(sn, Sn_MR_TCP, port, 0x00)) != sn) return ret;
- //printf("%d:Socket opened\r\n",sn);
- #endif
- break;
- default:
- break;
- return 1;
- int32_t loopback_tcpc(uint8_t sn, uint8_t* buf, uint8_t* destip, uint16_t destport)
- int32_t ret; // return value for SOCK_ERRORs
- // Destination (TCP Server) IP info (will be connected)
- // >> loopback_tcpc() function parameter
- // >> Ex)
- // uint8_t destip[4] = {192, 168, 0, 214};
- // uint16_t destport = 5000;
- // Port number for TCP client (will be increased)
- static uint16_t any_port = 50000;
- // Socket Status Transitions
- // Check the W5500 Socket n status register (Sn_SR, The 'Sn_SR' controlled by Sn_CR command or Packet send/recv status)
- if(getSn_IR(sn) & Sn_IR_CON) // Socket n interrupt register mask; TCP CON interrupt = connection with peer is successful
- printf("%d:Connected to - %d.%d.%d.%d : %d\r\n",sn, destip[0], destip[1], destip[2], destip[3], destport);
- #endif
- setSn_IR(sn, Sn_IR_CON); // this interrupt should be write the bit cleared to '1'
- // Data Transaction Parts; Handle the [data receive and send] process
- if((size = getSn_RX_RSR(sn)) > 0) // Sn_RX_RSR: Socket n Received Size Register, Receiving data length
- if(size > DATA_BUF_SIZE) size = DATA_BUF_SIZE; // DATA_BUF_SIZE means user defined buffer size (array)
- ret = recv(sn, buf, size); // Data Receive process (H/W Rx socket buffer -> User's buffer)
- if(ret <= 0) return ret; // If the received data length <= 0, receive failed and process end
- sentsize = 0;
- // Data sentsize control
- ret = send(sn, buf+sentsize, size-sentsize); // Data send process (User's buffer -> Destination through H/W Tx socket buffer)
- if(ret < 0) // Send Error occurred (sent data length < 0)
- close(sn); // socket close
- return ret;
- break;
- #endif
- if((ret=disconnect(sn)) != SOCK_OK) return ret;
- #endif
- break;
- case SOCK_INIT :
- printf("%d:Try to connect to the %d.%d.%d.%d : %d\r\n", sn, destip[0], destip[1], destip[2], destip[3], destport);
- #endif
- if( (ret = connect(sn, destip, destport)) != SOCK_OK) return ret; // Try to TCP connect to the TCP server (destination)
- break;
- case SOCK_CLOSED:
- close(sn);
- if((ret=socket(sn, Sn_MR_TCP, any_port++, 0x00)) != sn){
- if(any_port == 0xffff) any_port = 50000;
- return ret; // TCP socket open with 'any_port' port number
- //printf("%d:TCP client loopback start\r\n",sn);
- #endif
- break;
- default:
- break;
- return 1;
- int32_t loopback_udps(uint8_t sn, uint8_t* buf, uint16_t port)
- int32_t ret;
- uint16_t size, sentsize;
- case SOCK_UDP :
- ret = recvfrom(sn, buf, size, destip, (uint16_t*)&destport);
- if(ret <= 0)
- printf("%d: recvfrom error. %ld\r\n",sn,ret);
- #endif
- return ret;
- sentsize = 0;
- while(sentsize != size)
- ret = sendto(sn, buf+sentsize, size-sentsize, destip, destport);
- if(ret < 0)
- printf("%d: sendto error. %ld\r\n",sn,ret);
- #endif
- return ret;
- break;
- case SOCK_CLOSED:
- //printf("%d:UDP loopback start\r\n",sn);
- #endif
- if((ret = socket(sn, Sn_MR_UDP, port, 0x00)) != sn)
- return ret;
- printf("%d:Opened, UDP loopback, port [%d]\r\n", sn, port);
- #endif
- break;
- default :
- break;
- return 1;
- #endif
W5500官方驅(qū)動.zip
(6.07 MB, 下載次數(shù): 82)
2018-8-3 20:57 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
