查看: 1886|回復: 1
ATtiny13-RGB-LED-Colormixer源程序
ID:383566 發(fā)表于 2018-8-6 22:29 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
RGB LED MIXER- In this project we used the attiny 13 microcntroller for operating the RGB LED AND COLOR MIXING.
單片機源程序如下:
  1. /*
  2. Chapter - 2
  3. Project - 3 RGB Colormixer
  4. */
  5. #include<avr/io.h>
  6. #include<avr/interrupt.h>
  7. #define F_CPU 9600000UL
  8. #include<util/delay.h>
  9. //Prototypes
  10. //This function is called to switch on the LED at the
  11. //Required stage of PWM cycle
  12. void abc(unsigned char a,unsigned char b,unsigned char c,unsigned char status);
  13. //This function read the value of ADC from selected channel
  14. unsigned char read_adc(unsigned char channel);
  15. //Global variables
  16. volatile unsigned char e;
  17. volatile unsigned char pwm[3]={255,255,255};
  18. int main(void)
  19. {
  20.         DDRB  &= ~((1<<3)|(1<<4)|(1<<5));//ADC inputs
  21.
  22.         //Initially LEDs should be off
  23.         DDRB |=  (1<<0|1<<1|1<<2);
  24.         PORTB |= (1<<0)|(1<<1)|(1<<2);
  25.
  26.         //ADC init
  27.
  28.         ADMUX =  0b00100000; //ADC0 (default),ADLAR,VCc
  29.         ADCSRA = 0b10000010; //prescaled by 4
  30.
  31.         //Timer Initialisation
  32.         TCCR0A = 0x00;
  33.         TCCR0B = 0x01;//No Prescaling
  34.         TIMSK0 = 1<<TOIE0;//Overflow Interrupt Enabled
  35.         sei();//Global Interrupts Enabled
  36.         while(1)
  37.         {
  38.
  39.                 pwm[0]=read_adc(0);
  40.                 pwm[1]=read_adc(2);
  41.                 pwm[2]=read_adc(3);
  42.
  43.                 _delay_ms(2);//Just a small delay
  44.
  45.         }
  46.
  47. }
  48. //Overflow routine for Timer 0
  49. ISR(TIM0_OVF_vect)
  50. {
  51.
  52.         //Value of e decides the no of levels of PWM.
  53.         //This has 256 levels for e - 0 to 255
  54.         //0 - complete on and 255 is complete off
  55.
  56.         if(e==255)
  57.         {
  58.                 e=0;
  59.                 PORTB |= (1<<0)|(1<<1)|(1<<2);
  60.         }
  61.         abc(pwm[0],pwm[1],pwm[2],e);
  62.
  63.         e++;
  64.
  65. }
  66. //This function is called to switch on the LED at the
  67. //Required stage of PWM cycle
  68. void abc(unsigned char a,unsigned char b,unsigned char c,unsigned char status)
  69. {
  70.         if((status==a))
  71.         {
  72.                 PORTB&= ~(1<<0);
  73.         }
  74.         if((status==b))
  75.         {
  76.                 PORTB&= ~(1<<1);
  77.         }
  78.         if((status==c))
  79.         {
  80.                 PORTB&= ~(1<<2);
  81.         }
  82.
  83. }
  84. //This function read the value of ADC from selected channel
  85. unsigned char read_adc(unsigned char channel)
  86. {
  87.
  88.         unsigned char k;
  89.         unsigned int adcvalue=0;
  90.         ADMUX = ADMUX&(0b11111100); //clear channel select bits
  91.         ADMUX |= channel;
  92.
  93.         //neglect first reading after changing channel
  94.         ADCSRA |= 1<<ADSC;
  95.         while(ADCSRA&(1<<ADSC));//Wait
  96.         adcvalue=ADCH;
  97.         adcvalue=0;//neglectreading
  98.         for(k=0;k<=7;k++)
  99.         {
  100.                 ADCSRA |= 1<<ADSC;
  101.                 while(ADCSRA&(1<<ADSC));//Wait
  102.                 adcvalue += ADCH;
  103.         }
  104.         return (adcvalue>>3); //divide by 8
  105.
  106. }
復制代碼
Project-3-RGB-LED-Colormixer.rar (116.49 KB, 下載次數(shù): 21)
ID:240626 發(fā)表于 2019-10-30 16:40 | 只看該作者
你這個用arduino軟件打開燒錄不了
Powered by 單片機教程網
