查看: 5442|回復(fù): 0
激光測(cè)距模塊VL530X API程序源碼
ID:384082 發(fā)表于 2018-8-8 10:37 | 顯示全部樓層 |閱讀模式
激光測(cè)距模塊VL530X API,內(nèi)含ContinuousRanging測(cè)距模式例程,SingleRanging測(cè)距模式例程,SingleRanging_High_Accuracy測(cè)距模式例程,SingleRanging_High_Speed測(cè)距模式例程,SingleRanging_Long_Range測(cè)距模式例程可供參考。
源程序如下:
  1. #include <windows.h>
  2. #include <stdio.h>
  3. #include <tchar.h>
  4. #include "get_nucleo_serial_comm.h"
  5. DWORD QueryKey(HKEY hKey, TCHAR *pSearchDevice, TCHAR *pPortName)
  6. {
  7.     TCHAR    achKey[MAX_KEY_LENGTH];   // buffer for subkey name
  8.     DWORD    cbName;                   // size of name string
  9.     TCHAR    achClass[MAX_PATH] = TEXT("");  // buffer for class name
  10.     DWORD    cchClassName = MAX_PATH;  // size of class string
  11.     DWORD    cSubKeys=0;               // number of subkeys
  12.     DWORD    cbMaxSubKey;              // longest subkey size
  13.     DWORD    cchMaxClass;              // longest class string
  14.     DWORD    cValues;              // number of values for key
  15.     DWORD    cchMaxValue;          // longest value name
  16.     DWORD    cbMaxValueData;       // longest value data
  17.     DWORD    cbSecurityDescriptor; // size of security descriptor
  18.     FILETIME ftLastWriteTime;      // last write time
  19.     DWORD i, retCode;
  20.     TCHAR  achValue[MAX_VALUE_NAME];
  21.     DWORD cchValue = MAX_VALUE_NAME;
  22.     TCHAR  achDataValue[MAX_VALUE_NAME];
  23.     DWORD cchDataValue = MAX_VALUE_NAME;
  24.     // Get the class name and the value count.
  25.     retCode = RegQueryInfoKey(
  26.         hKey,                    // key handle
  27.         achClass,                // buffer for class name
  28.         &cchClassName,           // size of class string
  29.         NULL,                    // reserved
  30.         &cSubKeys,               // number of subkeys
  31.         &cbMaxSubKey,            // longest subkey size
  32.         &cchMaxClass,            // longest class string
  33.         &cValues,                // number of values for this key
  34.         &cchMaxValue,            // longest value name
  35.         &cbMaxValueData,         // longest value data
  36.         &cbSecurityDescriptor,   // security descriptor
  37.         &ftLastWriteTime);       // last write time
  38.     // Enumerate the subkeys, until RegEnumKeyEx fails.
  39.
  40.     if (cSubKeys)
  41.     {
  42.         _tprintf(TEXT( "\nNumber of subkeys: %d\n"), (int)cSubKeys);
  43.         for (i=0; i<cSubKeys; i++)
  44.         {
  45.             cbName = MAX_KEY_LENGTH;
  46.             retCode = RegEnumKeyEx(hKey, i,
  47.                      achKey,
  48.                      &cbName,
  49.                      NULL,
  50.                      NULL,
  51.                      NULL,
  52.                      &ftLastWriteTime);
  53.             if (retCode == ERROR_SUCCESS)
  54.             {
  55.                 _tprintf(TEXT("(%d) %s\n"), (int)(i+1), achKey);
  56.             }
  57.         }
  58.     }
  59.     // Enumerate the key values.
  60.     if (cValues)
  61.     {
  62.         printf( "\nNumber of values: %d\n", (int)cValues);
  63.         for (i=0, retCode=ERROR_SUCCESS; i<cValues; i++)
  64.         {
  65.             cchValue = MAX_VALUE_NAME;
  66.             achValue[0] = '\0';
  67.             cchDataValue = MAX_VALUE_NAME;
  68.             achDataValue[0] = '\0';
  69.             retCode = RegEnumValue(hKey, i,
  70.                 achValue,
  71.                 &cchValue,
  72.                 NULL,
  73.                 NULL,
  74.                 achDataValue,
  75.                 &cchDataValue );
  76.             if (retCode == ERROR_SUCCESS)
  77.             {
  78.                 _tprintf(TEXT("(%d) %s data %s  cchDataValue=%d\n"), (int)(i+1), achValue, achDataValue, (int)cchDataValue);
  79.                 if (strcmp(pSearchDevice, achValue) == 0) {
  80.                         strcpy(pPortName, achDataValue);
  81.                         _tprintf(TEXT("Found\n"));
  82.                         return 1;
  83.                 }
  84.             } else {
  85.                 _tprintf(TEXT("ERROR (%d) %d \n"), (int)(i+1), (int)retCode);
  86.             }
  87.         }
  88.     }
  89.
  90.     return 0;
  91. }
  92. DWORD GetNucleoSerialComm(TCHAR *pSerialCommStr)
  93. {
  94.    HKEY hTestKey;
  95.    DWORD state = 0;
  96.     TCHAR  achDataValue[MAX_VALUE_NAME];
  97.    if( RegOpenKeyEx( HKEY_LOCAL_MACHINE,
  98.         TEXT("HARDWARE\\DEVICEMAP\\SERIALCOMM"),
  99.         0,
  100.         KEY_READ,
  101.         &hTestKey) == ERROR_SUCCESS
  102.       )
  103.    {
  104.         state = QueryKey(hTestKey, "\\Device\\USBSER000", achDataValue);
  105.         if (state == 1) {
  106.                 _tprintf(TEXT("found USBSER000 at port com %s\n"), achDataValue);
  107.                 strcpy(pSerialCommStr, achDataValue);
  108.         } else
  109.                 _tprintf(TEXT("ERROR USBSER000 not found!\n"));
  110.    }
  111.
  112.    RegCloseKey(hTestKey);
  113.    if (state == 1)
  114.         return 1;
  115.    else
  116. ……………………
  117. …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
en.STSW-IMG005.zip (3.7 MB, 下載次數(shù): 26)
