// MFCdkjceshiDlg.cpp : 實(shí)現(xiàn)文件
#include "stdafx.h"
#include "MFCdkjceshi.h"
#include "MFCdkjceshiDlg.h"
#include "afxdialogex.h"
#include"Resource.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#endif
int xssz[160][240];
HDC dcc;
int dydata = 0;
int zljs = 0;
int yddata[38401];
CString str9;
LPCTSTR zhilingbiao[8000000];
// 用于應(yīng)用程序“關(guān)于”菜單項(xiàng)的 CAboutDlg 對話框
class CAboutDlg : public CDialogEx
public:
CAboutDlg();
// 對話框數(shù)據(jù)
#ifdef AFX_DESIGN_TIME
enum { IDD = IDD_ABOUTBOX };
#endif
protected:
virtual void DoDataExchange(CDataExchange* pDX); // DDX/DDV 支持
// 實(shí)現(xiàn)
protected:
DECLARE_MESSAGE_MAP()
CAboutDlg::CAboutDlg() : CDialogEx(IDD_ABOUTBOX)
void CAboutDlg::DoDataExchange(CDataExchange* pDX)
CDialogEx::DoDataExchange(pDX);
BEGIN_MESSAGE_MAP(CAboutDlg, CDialogEx)
END_MESSAGE_MAP()
// CMFCdkjceshiDlg 對話框
CMFCdkjceshiDlg::CMFCdkjceshiDlg(CWnd* pParent /*=NULL*/)
: CDialogEx(IDD_MFCDKJCESHI_DIALOG, pParent)
m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
void CMFCdkjceshiDlg::DoDataExchange(CDataExchange* pDX)
DDX_Control(pDX, IDC_MSCOMM1, m_com);
BEGIN_MESSAGE_MAP(CMFCdkjceshiDlg, CDialogEx)
ON_WM_SYSCOMMAND()
ON_WM_PAINT()
ON_WM_QUERYDRAGICON()
ON_BN_CLICKED(IDC_BUTTON2, &CMFCdkjceshiDlg::OnBnClickedButton2)
ON_BN_CLICKED(IDC_BUTTON3, &CMFCdkjceshiDlg::OnBnClickedButton3)
ON_BN_CLICKED(IDC_BUTTON1, &CMFCdkjceshiDlg::OnBnClickedButton1)
END_MESSAGE_MAP()
// CMFCdkjceshiDlg 消息處理程序
BOOL CMFCdkjceshiDlg::OnInitDialog()
CDialogEx::OnInitDialog();
// 將“關(guān)于...”菜單項(xiàng)添加到系統(tǒng)菜單中。
// IDM_ABOUTBOX 必須在系統(tǒng)命令范圍內(nèi)。
ASSERT((IDM_ABOUTBOX & 0xFFF0) == IDM_ABOUTBOX);
ASSERT(IDM_ABOUTBOX < 0xF000);
CMenu* pSysMenu = GetSystemMenu(FALSE);
if (pSysMenu != NULL)
BOOL bNameValid;
CString strAboutMenu;
bNameValid = strAboutMenu.LoadString(IDS_ABOUTBOX);
ASSERT(bNameValid);
if (!strAboutMenu.IsEmpty())
pSysMenu->AppendMenu(MF_SEPARATOR);
pSysMenu->AppendMenu(MF_STRING, IDM_ABOUTBOX, strAboutMenu);
// 設(shè)置此對話框的圖標(biāo)。 當(dāng)應(yīng)用程序主窗口不是對話框時(shí),框架將自動(dòng)
// 執(zhí)行此操作
SetIcon(m_hIcon, TRUE); // 設(shè)置大圖標(biāo)
SetIcon(m_hIcon, FALSE); // 設(shè)置小圖標(biāo)
// TODO: 在此添加額外的初始化代碼
return TRUE; // 除非將焦點(diǎn)設(shè)置到控件,否則返回 TRUE
void CMFCdkjceshiDlg::OnSysCommand(UINT nID, LPARAM lParam)
if ((nID & 0xFFF0) == IDM_ABOUTBOX)
CAboutDlg dlgAbout;
dlgAbout.DoModal();
CDialogEx::OnSysCommand(nID, lParam);
// 如果向?qū)υ捒蛱砑幼钚』粹o,則需要下面的代碼
// 來繪制該圖標(biāo)。 對于使用文檔/視圖模型的 MFC 應(yīng)用程序,
// 這將由框架自動(dòng)完成。
void CMFCdkjceshiDlg::OnPaint()
if (IsIconic())
CPaintDC dc(this); // 用于繪制的設(shè)備上下文
SendMessage(WM_ICONERASEBKGND, reinterpret_cast<WPARAM>(dc.GetSafeHdc()), 0);
// 使圖標(biāo)在工作區(qū)矩形中居中
int cxIcon = GetSystemMetrics(SM_CXICON);
int cyIcon = GetSystemMetrics(SM_CYICON);
CRect rect;
GetClientRect(&rect);
int x = (rect.Width() - cxIcon + 1) / 2;
int y = (rect.Height() - cyIcon + 1) / 2;
// 繪制圖標(biāo)
dc.DrawIcon(x, y, m_hIcon);
CDialogEx::OnPaint();
//當(dāng)用戶拖動(dòng)最小化窗口時(shí)系統(tǒng)調(diào)用此函數(shù)取得光標(biāo)
//顯示。
HCURSOR CMFCdkjceshiDlg::OnQueryDragIcon()
return static_cast<HCURSOR>(m_hIcon);
void CMFCdkjceshiDlg::OnBnClickedButton2()// 選擇并打開圖像
CString strFile = _T("");
CFileDialog dlgFile(TRUE, NULL, NULL, OFN_HIDEREADONLY, _T("Describe Files (*.jpg)|*.jpg|All Files (*.*)|*.*||"), NULL);
if (dlgFile.DoModal())
strFile = dlgFile.GetPathName();
//以指定大小顯示圖像
CImage image;
int iii,jjj,ccc,ddd;
image.Load(strFile);
dcc = GetDC()->m_hDC;
image.Draw(dcc, CRect(0, 0,240,160));
int xsx, xsy, js = 0;
int xsx1, xsy1=0;////////
int wzjs = 0;
for (xsy = 0; xsy <240; xsy++)
for (xsx = 0; xsx <160; xsx++)
if (GetPixel(dcc, xsy, xsx)<9000000)
xssz[xsx][xsy] = 1;
xssz[xsx][xsy] = 2;
int aaaa;
for (aaaa = 0; aaaa < 80; aaaa++)
for (xsx1 = 0; xsx1 <240; xsx1++)
if (xssz[xsy1][xsx1] == 1)
if (xsx1 == wzjs)
zhilingbiao[zljs] = L"A";
zljs++;
if (xsx1 < wzjs)
ccc = wzjs - xsx1;
for (iii = 0; iii < ccc; iii++)
zhilingbiao[zljs] = L"C";
zljs++;
wzjs--;
zljs++;
ccc = xsx1 - wzjs;
zhilingbiao[zljs] = L"B";
zljs++;
wzjs++;
zljs++;
zhilingbiao[zljs] = L"D";
zljs++;
xsy1++;
for (xsx1 = 240; xsx1>0; xsx1--)
jjj = xsx1 - 1;
if (xssz[xsy1][jjj] == 1)
if (jjj == wzjs)
zljs++;
if (jjj < wzjs)
ddd = wzjs - jjj;
for (iii = 0; iii < ddd; iii++)
zljs++;
wzjs--;
zljs++;
ddd = jjj - wzjs;
zljs++;
wzjs++;
zljs++;
zljs++;
xsy1++;
zhilingbiao[zljs] = L"E";
zljs++;
str9.Format(_T("%d"), zljs);
SetDlgItemText(IDC_STATIC5, str9);
SetDlgItemText(IDC_STATIC3, L"準(zhǔn)備完畢");
zljs = 0;
BEGIN_EVENTSINK_MAP(CMFCdkjceshiDlg, CDialogEx)
ON_EVENT(CMFCdkjceshiDlg, IDC_MSCOMM1, 1, CMFCdkjceshiDlg::OnCommMscomm1, VTS_NONE)
END_EVENTSINK_MAP()
void CMFCdkjceshiDlg::OnCommMscomm1()// 接收事件處理函數(shù)
VARIANT variant_inp;
COleSafeArray safearray_inp;
CString strInput;
if (m_com.get_CommEvent() == 2)//值為2表示接收緩沖區(qū)內(nèi)有字符
variant_inp = m_com.get_Input();//讀取緩沖區(qū)消息
str9.Format(_T("%d"), dydata);
panduan();
void CMFCdkjceshiDlg::OnBnClickedButton3()//打開串口
CString Data;
GetDlgItem(IDC_COMBO1)->GetWindowText(Data);
int b = _ttoi(Data);
if (m_com.get_PortOpen())//如果發(fā)現(xiàn)串口原來是打開的,關(guān)閉串口
m_com.put_PortOpen(FALSE);
m_com.put_CommPort(b);//選擇COM1端口
m_com.put_InBufferSize(1024);//設(shè)置輸入緩沖區(qū)大小
m_com.put_OutBufferSize(512);//設(shè)置輸出緩沖區(qū)大小
m_com.put_Settings(L"9600,n,8,1");//設(shè)置波特率9600,無校驗(yàn),8個(gè)數(shù)據(jù)位,1個(gè)停止位
if (!m_com.get_PortOpen())
m_com.put_PortOpen(TRUE);//打開串口
m_com.put_RThreshold(1);//每當(dāng)接收緩沖區(qū)中有1個(gè)字符,則接收串口數(shù)據(jù)
m_com.put_InputLen(0);//設(shè)置當(dāng)前緩沖區(qū)長度為0
m_com.get_Input();//預(yù)讀緩沖區(qū)以清除殘留數(shù)據(jù)
SetDlgItemText(IDC_STATIC2, L"連接成功!");
SetDlgItemText(IDC_STATIC2, L"連接失!");
void CMFCdkjceshiDlg::OnBnClickedButton1()//開始雕刻
SetDlgItemText(IDC_STATIC4, L"正在工作中");
m_com.put_Output(COleVariant(L"Q"));//發(fā)送握手指令
void CMFCdkjceshiDlg::panduan()
if (zhilingbiao[dydata] == L"E")
m_com.put_Output(COleVariant(zhilingbiao[dydata])); //發(fā)送指令
MessageBox(L"打印完畢");
dydata = 0;
dydata++;
