OLED 3.12寸 256*64 驅(qū)動(dòng)程序 stm32f103
- MOD:25664 (dots:256*64)
- IC : SSD1322 (加入圖片測(cè)試功能)
- MCU: W78E516D 12MHZ
- 說明:6800:BS0=1,BS1=1;
- 8080:BS0=0,BS1=1; (默認(rèn))
- 3-SPI:BS0=1,BS1=0;
- 4-SPI:BS0=0,BS1=0;
- /* 接口定義:
- 1. VSS--------------GND
- 2. VDD--------------+3.3V
- 3. NC
- 4. DB0--------------P1.0
- 5. DB1--------------P1.1
- 6. DB2--------------P1.2
- 7. DB3--------------P1.3
- 8. DB4--------------P1.4
- 9. DB5--------------P1.5
- 10. DB6--------------P1.6
- 11. DB7--------------P1.7
- 12. RD/E-------------P3.4
- 13. WR---------------P3.3
- 14. DC/A0------------P3.2
- 15. RST--------------P3.1
- 16. CS---------------P3.0
- #include <reg51.h>
- #include <intrins.h>
- #define uchar unsigned char
- #define xData P1
- #define Shift 0x1C
- uchar data_4byte[4];
- void delayus(uchar m);
- void delayms(uchar m);
- void change (uchar dat);
- void Fill_RAM(unsigned char Data) ;
- void send_2bit(unsigned char two_bit_data);
- unsigned char code bmp25664_0[];
- unsigned char code bmp25664_1[];
- void display_graphic_256x64_0();
- void display_graphic_256x64_1();
- // Global Variables
- #define Max_Column 0x3F // 256/4-1
- #define Max_Row 0x3F // 64-1
- #define Brightness 0x0F
- //#define SPI
- #define I80
- //#define M68
- sbit REST=P3^1; // Reset
- sbit CS=P3^0; // Chip Select
- sbit DC=P3^2; // Data/Command Control
- //6800
- sbit RW=P3^3; // Write Signal
- sbit E=P3^4; // E Signal
- //8080
- sbit _WR=P3^3; //80
- sbit _RD=P3^4; //80
- //SPI
- sbit SCLK=P1^0; //spi
- sbit SDIN=P1^1; //spi
- uchar code tab88[]={
- 0x0e,0x11,0x13,0x15,0x19,0x11,0x0e,0x00,// 0 代碼"10"
- 0x04,0x0c,0x04,0x04,0x04,0x04,0x0e,0x00,//1 代碼"11"
- 0x0e,0x11,0x01,0x02,0x04,0x08,0x1f,0x00,//2 代碼"12"
- 0x1f,0x02,0x04,0x02,0x01,0x11,0x0e,0x00,// 3 代碼"13"
- 0x02,0x06,0x0a,0x12,0x1f,0x02,0x02,0x00,// 4 代碼"14"
- 0x1f,0x10,0x1e,0x01,0x01,0x11,0x0e,0x00,// 5 代碼"15"
- 0x06,0x08,0x10,0x1e,0x11,0x11,0x0e,0x00,// 6 代碼"16"
- 0x1f,0x01,0x02,0x04,0x04,0x04,0x04,0x00,// 7 代碼"17"
- 0x0e,0x11,0x11,0x0e,0x11,0x11,0x0e,0x00,// 8 代碼"18"
- 0x0e,0x11,0x11,0x0e,0x01,0x02,0x0c,0x00,// 9 代碼"19"
- 0x0e,0x11,0x11,0x11,0x1f,0x11,0x11,0x00,// A 代碼"21"
- 0x11,0x11,0x11,0x1f,0x11,0x11,0x11,0x00,// H 代碼"28"
- 0x0e,0x04,0x04,0x04,0x04,0x04,0x0e,0x00,// I 代碼"29"
- 0x07,0x02,0x02,0x02,0x02,0x12,0x0c,0x00,// J 代碼"2A"
- 0x11,0x12,0x14,0x18,0x14,0x12,0x11,0x00,// K 代碼"2B"
- 0x10,0x10,0x10,0x10,0x10,0x10,0x1f,0x00,// L 代碼"2C"
- 0x11,0x1b,0x15,0x11,0x11,0x11,0x11,0x00,// M 代碼"2D"
- 0x11,0x19,0x19,0x15,0x13,0x13,0x11,0x00,// N 代碼"2E"
- 0x0e,0x11,0x11,0x11,0x11,0x11,0x0e,0x00,// O 代碼"2F"
- 0x1e,0x11,0x11,0x1e,0x10,0x10,0x10,0x00,// P 代碼"30"
- 0x0e,0x11,0x11,0x11,0x15,0x12,0x0b,0x00,// Q 代碼"31"
- 0x1e,0x11,0x11,0x1e,0x14,0x12,0x11,0x00,//R 代碼"32"
- 0x0e,0x11,0x10,0x0e,0x01,0x11,0x0e,0x00,// S 代碼"33"
- 0x1f,0x04,0x04,0x04,0x04,0x04,0x04,0x00,// T 代碼"34"
- 0x11,0x11,0x11,0x11,0x11,0x11,0x0e,0x00,// U 代碼"35"
- 0x11,0x11,0x11,0x11,0x11,0x0a,0x04,0x00,// V 代碼"36"
- 0x11,0x11,0x11,0x15,0x15,0x1b,0x11,0x00,// W 代碼"37"
- 0x11,0x11,0x0a,0x04,0x0a,0x11,0x11,0x00,// X 代碼"38"
- 0x11,0x11,0x11,0x0a,0x04,0x04,0x04,0x00,// Y 代碼"39"
- 0x1f,0x01,0x02,0x04,0x08,0x10,0x1f,0x00,// Z 代碼"3A"
- 0x0e,0x08,0x08,0x08,0x08,0x08,0x0e,0x00,// [ 代碼"3B"
- 0x00,0x10,0x08,0x04,0x02,0x01,0x00,0x00,// \ 代碼"3C"
- 0x0e,0x02,0x02,0x02,0x02,0x02,0x0e,0x00,// ] 代碼"3D"
- 0x04,0x0a,0x11,0x00,0x00,0x00,0x00,0x00,// ^ 代碼"3E"
- 0x00,0x00,0x00,0x00,0x00,0x00,0x1f,0x00,// _ 代碼"3F"
- 0x10,0x08,0x04,0x00,0x00,0x00,0x00,0x00,// ` 代碼"40"
- 0x00,0x00,0x0e,0x01,0x0f,0x11,0x0f,0x00,// a 代碼"41"
- 0x10,0x10,0x16,0x19,0x11,0x11,0x1e,0x00,// b 代碼"42"
- 0x00,0x00,0x0e,0x11,0x10,0x11,0x0e,0x00,// c 代碼"43"
- 0x01,0x01,0x0d,0x13,0x11,0x11,0x0f,0x00,// d 代碼"44"
- 0x00,0x00,0x0e,0x11,0x1f,0x10,0x0e,0x00,// e 代碼"45"
- 0x02,0x05,0x04,0x0e,0x04,0x04,0x04,0x00,// f 代碼"46"
- 0x00,0x0d,0x13,0x13,0x0d,0x01,0x0e,0x00,// g 代碼"47"
- 0x10,0x10,0x16,0x19,0x11,0x11,0x11,0x00,// h 代碼"48"
- 0x04,0x00,0x0c,0x04,0x04,0x04,0x0e,0x00,// i 代碼"49"
- 0x02,0x00,0x06,0x02,0x02,0x12,0x0c,0x00,// j 代碼"4A"
- 0x08,0x08,0x09,0x0a,0x0c,0x0a,0x09,0x00,//k 代碼"4B"
- 0x0c,0x04,0x04,0x04,0x04,0x04,0x0e,0x00,// l 代碼"4C"
- 0x00,0x00,0x1a,0x15,0x15,0x15,0x15,0x00,// m 代碼"4D"
- 0x00,0x00,0x16,0x19,0x11,0x11,0x11,0x00,// n 代碼"4E"
- 0x00,0x00,0x0e,0x11,0x11,0x11,0x0e,0x00,// o 代碼"4F"
- 0x00,0x16,0x19,0x19,0x16,0x10,0x10,0x00,// p 代碼"50"
- 0x00,0x0d,0x13,0x13,0x0d,0x01,0x01,0x00,// q 代碼"51"
- 0x00,0x00,0x16,0x19,0x10,0x10,0x10,0x00,// r 代碼"52"
- 0x00,0x00,0x0f,0x10,0x1e,0x01,0x1f,0x00,// s 代碼"53"
- 0x08,0x08,0x1c,0x08,0x08,0x09,0x06,0x00,// t 代碼"54"
- 0x00,0x00,0x12,0x12,0x12,0x12,0x0d,0x00,// u 代碼"55"
- 0x00,0x00,0x11,0x11,0x11,0x0a,0x04,0x00,// v 代碼"56"
- 0x00,0x00,0x11,0x11,0x15,0x15,0x0a,0x00,// w 代碼"57"
- 0x00,0x00,0x11,0x0a,0x04,0x0a,0x11,0x00,// x 代碼"58"
- 0x00,0x00,0x11,0x11,0x13,0x0d,0x01,0x0e,// y 代碼"59"
- uchar code tab816[160]={
- /*-- 文字: Q --*/
- /*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16 --*/
- 0x00,0x00,0x00,0xEE,0x44,0x44,0x28,0x28,0x10,0x10,0x10,0x10,0x10,0x38,0x00,0x00,
- /*-- 文字: T --*/
- 0x00,0x00,0x00,0xF8,0x44,0x44,0x44,0x78,0x44,0x42,0x42,0x42,0x44,0xF8,0x00,0x00,
- /*-- 文字: S --*/
- /*-- Times New Roman12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=8x16 --*/
- 0x00,0x00,0x00,0x3E,0x42,0x42,0x40,0x20,0x18,0x04,0x02,0x42,0x42,0x7C,0x00,0x00,
- /*-- 文字: 2 --*/
- 0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x04,0x04,0x08,0x10,0x20,0x42,0x7E,0x00,0x00,
- /*-- 文字: 5 --*/
- 0x00,0x00,0x00,0x7E,0x40,0x40,0x40,0x58,0x64,0x02,0x02,0x42,0x44,0x38,0x00,0x00,
- /*-- 文字: 6 --*/
- 0x00,0x00,0x00,0x1C,0x24,0x40,0x40,0x58,0x64,0x42,0x42,0x42,0x24,0x18,0x00,0x00,
- /*-- 文字: X --*/
- 0x00,0x00,0x00,0xE7,0x42,0x24,0x24,0x18,0x18,0x18,0x24,0x24,0x42,0xE7,0x00,0x00,
- /*-- 文字: 6 --*/
- /*-- 文字: 4 --*/
- 0x00,0x00,0x00,0x04,0x0C,0x14,0x24,0x24,0x44,0x44,0x7E,0x04,0x04,0x1E,0x00,0x00,
- /*-- 文字: 1 --*/
- 0x00,0x00,0x00,0x10,0x70,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x7C,0x00,0x00,
- uchar code tab1616[]={
- /* 點(diǎn)陣:16x16
- 提取點(diǎn)陣方向:橫向取模(先左->右, 再上->下)
- 字節(jié)掉轉(zhuǎn):否
- 字節(jié)方式:C語言 */
- /*-- 文字: 深 --*/
- /*-- 宋體12; 此字體下對(duì)應(yīng)的點(diǎn)陣為:寬x高=16x16 --*/
- 0x00,0x00,0x7F,0xFC,0x04,0x40,0x04,0x40,0x04,0x40,0x04,0x40,0x44,0x44,0x24,0x44,
- 0x24,0x48,0x14,0x48,0x14,0x50,0x04,0x40,0x04,0x40,0x04,0x40,0xFF,0xFE,0x00,0x00,
- /*-- 文字: 圳 --*/
- 0x00,0x10,0x20,0x14,0x11,0xD2,0x00,0x12,0xFC,0x10,0x0B,0xFE,0x08,0x10,0x48,0x90,
- 0x28,0x90,0x12,0xD0,0x12,0x90,0x2A,0x90,0x2A,0x8A,0x4A,0xEA,0x87,0x06,0x02,0x02,
- /*-- 文字: 秦 --*/
- 0x01,0x00,0x01,0x00,0x01,0x00,0x3F,0xF8,0x21,0x08,0x21,0x08,0x21,0x08,0x3F,0xF8,
- 0x21,0x08,0x21,0x08,0x21,0x08,0x3F,0xF8,0x21,0x0A,0x01,0x02,0x01,0x02,0x00,0xFE,
- /*-- 文字: 唐 --*/
- 0x00,0x00,0x7F,0xF8,0x00,0x10,0x00,0x20,0x00,0x40,0x01,0x80,0x01,0x00,0xFF,0xFE,
- 0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x05,0x00,0x02,0x00,
- /*-- 文字: 科 --*/
- 0x08,0x10,0x1D,0x10,0xF0,0x90,0x10,0x90,0x10,0x10,0xFD,0x10,0x10,0x90,0x38,0x90,
- 0x34,0x10,0x50,0x1E,0x53,0xF0,0x90,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,
- /*-- 文字: 技 --*/
- 0x10,0x20,0x10,0x20,0x10,0x20,0x13,0xFE,0xFC,0x20,0x10,0x20,0x10,0x20,0x15,0xFC,
- 0x18,0x84,0x30,0x88,0xD0,0x48,0x10,0x50,0x10,0x20,0x10,0x50,0x51,0x88,0x26,0x06,
- /*-- 文字: 有 --*/
- 0x02,0x00,0x02,0x00,0xFF,0xFE,0x04,0x00,0x04,0x00,0x0F,0xF0,0x08,0x10,0x18,0x10,
- 0x2F,0xF0,0x48,0x10,0x88,0x10,0x0F,0xF0,0x08,0x10,0x08,0x10,0x08,0x50,0x08,0x20,
- /*-- 文字: 限 --*/
- 0x00,0x00,0x7B,0xF8,0x4A,0x08,0x52,0x08,0x53,0xF8,0x62,0x08,0x52,0x08,0x4B,0xF8,
- 0x4A,0x44,0x4A,0x48,0x6A,0x30,0x52,0x20,0x42,0x10,0x42,0x88,0x43,0x06,0x42,0x00,
- /*-- 文字: 公 --*/
- 0x00,0x80,0x04,0x80,0x04,0x80,0x08,0x40,0x08,0x40,0x10,0x20,0x20,0x10,0x42,0x08,
- 0x82,0x06,0x04,0x00,0x04,0x40,0x08,0x20,0x10,0x20,0x3F,0xF0,0x10,0x10,0x00,0x00,
- /*-- 文字: 司 --*/
- 0x00,0x00,0x3F,0xF8,0x00,0x08,0x00,0x08,0x7F,0xE8,0x00,0x08,0x00,0x08,0x1F,0x88,
- 0x10,0x88,0x10,0x88,0x10,0x88,0x10,0x88,0x1F,0x88,0x10,0x88,0x00,0x28,0x00,0x10,
- 延時(shí)子程序
- while(--m);
- uchar i,j;
- for(i=0;i<102;i++)
- for(j=0;j<m;j++)
- delayus(1);
- void delay(uchar m)
- uchar i,j;
- for(i=0;i<100;i++)
- for(j=0;j<m;j++)
- delayms(1);
- #ifdef M68
- void Write_cmd(unsigned char Data) //68XX方式寫指令子程序
- { DC=0;
- CS=0;
- RW=0;
- xData=Data;
- E=1;
- _nop_();
- _nop_();
- E=0;
- RW=1;
- CS=1;
- DC=1;
- void Write_dat(unsigned char Data) //68XX方式寫數(shù)據(jù)子程序
- { DC=1;
- CS=0;
- RW=0;
- xData=Data;
- E=1;
- _nop_();
- _nop_();
- E=0;
- RW=1;
- CS=1;
- DC=1;
- #endif
- #ifdef I80 // 8-bit 80XX Parallel
- DC=0;
- CS=0;
- _WR=0;
- xData=Data;
- _WR=1;
- CS=1;
- DC=1;
- DC=1;
- CS=0;
- _WR=0;
- xData=Data;
- _WR=1;
- CS=1;
- DC=1;
- #endif
- #ifdef SPI // 4-wire SPI
- unsigned char i;
- CS=0;
- DC=0;
- for (i=0; i<8; i++)
- SCLK=0;
- SDIN=(Data&0x80)>>7;
- Data = Data << 1;
- // uDelay(1);
- SCLK=1;
- // uDelay(1);
- // SCLK=0;
- DC=1;
- CS=1;
- unsigned char i;
- CS=0;
- DC=1;
- SCLK=0;
- Data = Data << 1;
- // uDelay(1);
- SCLK=1;
- // uDelay(1);
- // SCLK=0;
- DC=1;
- CS=1;
- #endif
- 行,列,起始地址設(shè)定,寫入命令定義 一個(gè)像素對(duì)應(yīng)4位
- void Set_Column_Address(unsigned char a, unsigned char b)
- Write_cmd(0x15); // Set Column Address
- Write_dat(a); // Default => 0x00
- Write_dat(b); // Default => 0x77
- void Set_Row_Address(unsigned char a, unsigned char b)
- Write_cmd(0x75); // Set Row Address
- Write_dat(b); // Default => 0x7F
- void Set_Write_RAM()
- Write_cmd(0x5C); // Enable MCU to Write into RAM
- void Set_Remap_Format(unsigned char d)
- Write_cmd(0xA0); // Set Re-Map / Dual COM Line Mode
- Write_dat(d); // Default => 0x40
- Write_dat(0x11); // Default => 0x01 (Disable Dual COM Mode)
- //初始化程序
- void Initial (void)
- Write_cmd(0xFD);
- Write_dat(0x12); //打開MCU通信
- Set_Column_Address(0x1c,0x5b); //256列
- Set_Row_Address(0x00,0x3f); //64行
- Write_cmd(0xAE); //開休眠
- Write_cmd(0xB3); ///驅(qū)動(dòng)和振蕩時(shí)鐘
- Write_dat(0x91);
- Write_cmd(0xCA); ///設(shè)定MUX占空比
- Write_dat(0x3F);
- Write_cmd(0xA2);
- Write_dat(0x00); //卷動(dòng)地址
- Write_cmd(0xA1);
- Write_dat(0x00); //起始行
- Write_cmd(0xA6); //正常顯示
- Write_cmd(0xA0);
- Write_dat(0x14);
- Write_dat(0x11); //掃描方向
- Write_cmd(0xB5); ///set gpio
- Write_dat(0x00);
- Write_cmd(0xAB);
- Write_dat(0x01); //內(nèi)部調(diào)節(jié)電壓
- Write_cmd(0xB4); ///加深顯示Display Enhancement a
- Write_dat(0xA0);
- Write_dat(0xfd); //0xb5
- Write_cmd(0xC1); ///Set Contrast Current
- Write_dat(0xaf); //9f
- Write_cmd(0xC7); //Master Contrast Current Control
- Write_dat(0x0F);
- Write_cmd(0xb8); //灰模
- Write_dat(0x0c);
- Write_dat(0x18);
- Write_dat(0x24);
- Write_dat(0x30);
- Write_dat(0x3c);
- Write_dat(0x48);
- Write_dat(0x54);
- Write_dat(0x60);
- Write_dat(0x6c);
- Write_dat(0x78);
- Write_dat(0x84);
- Write_dat(0x90);
- Write_dat(0x9c);
- Write_dat(0xa8);
- Write_dat(0xb4);
- Write_cmd(0x00);
- Write_cmd(0xB1); //Set Phase Length
- Write_dat(0xE2);
- Write_cmd(0xD1); //Display Enhancement B
- Write_dat(0xa2);
- Write_dat(0x20);//反顯
- Write_cmd(0xBB);
- Write_dat(0x1F);
- Write_cmd(0xB6);
- Write_dat(0x08);
- Write_cmd(0xBE);
- Write_dat(0x07);//0.86VCC
- Write_cmd(0xA6);//正常顯示
- Write_cmd(0xA9);//退部分顯示
- Write_cmd(0x5c);
- Fill_RAM(0x00);
- Write_cmd(0xAF); //關(guān)休眠
- 全和間隔列顯示
- unsigned char i,j;
- Set_Write_RAM();
- for(i=0;i<64;i++)
- for(j=0;j<64;j++)
- Write_dat(Data);
- Write_dat(Data);
- /*************************Fill Data**************************/
- void fill(unsigned char dat1,unsigned char dat2)
- unsigned char x,y;
- Write_cmd(0x15); /*Set Column Address*/
- Write_dat(0x00); /*Start Address,start at SEG0*/
- Write_dat(0x77); /*End Address,end at SEG479*/
- Write_cmd(0x75); /*Set Row address*/
- Write_dat(0x00); /*Start Address,start at row0*/
- Write_dat(0x7f); /*End Address,end at row127*/
- Write_cmd(0x5c); /*Write RAM Command*/
- for(y=0;y<128;y++)
- for(x=0;x<120;x++)
- Write_dat(dat1);
- Write_dat(dat2);
- // delay(1);
- //=========圖形
- unsigned int i=0;
- Write_cmd(0x15);
- Write_dat(0x1c); //
- Write_dat(0x5b); //91 91-28=63
- Write_cmd(0x75);
- Write_dat(0x00); //0
- Write_dat(0x3f); //63 63-0=63
- Write_cmd(0x5C);
- for(y=0;y<64;y++)
- for(x=0;x<32;x++)
- unsigned char code_buf,code_buf2;
- code_buf=bmp25664_0[i++];
- code_buf2=code_buf&0xc0;
- send_2bit(code_buf2);
- code_buf2=code_buf&0x30;
- code_buf2<<=2;
- code_buf2=code_buf&0x0c;
- code_buf2<<=4;
- code_buf2=code_buf&0x03;
- code_buf2<<=6;
- //=========圖形
- unsigned int i=0;
- Write_cmd(0x15);
- Write_cmd(0x75);
- Write_cmd(0x5C);
- for(y=0;y<64;y++)
- for(x=0;x<32;x++)
- code_buf=bmp25664_1[i++];
- code_buf2<<=2;
- code_buf2<<=4;
- code_buf2<<=6;
- if(two_bit_data==0x00)
- Write_dat(0x00);
- else if(two_bit_data==0x40)
- Write_dat(0x0f);
- else if(two_bit_data==0x80)
- Write_dat(0xf0);
- else
- Write_dat(0xff);
- 間隔行顯示
- void hang(unsigned char Data)
- Set_Write_RAM();
- for(i=0;i<32;i++)
- for(j=0;j<64;j++)
- Write_dat(Data);
- Write_dat(Data);
- for(j=0;j<64;j++)
- Write_dat(~Data);
- Write_dat(~Data);
- 間隔點(diǎn)顯示
- void gedot(uchar m)
- Set_Row_Address(0x00,0x3f); //128行
- Set_Write_RAM();
- for(i=0;i<32;i++)
- for(j=0;j<64;j++)
- if(m==0xf0)
- Write_dat(0xf0);
- Write_dat(0xf0);
- else
- Write_dat(0x0f);
- Write_dat(0x0f);
- for(j=0;j<64;j++)
- if(m==0xf0)
- Write_dat(0x0f);
- Write_dat(0x0f);
- else
- Write_dat(0xf0);
- Write_dat(0xf0);
- 矩形邊框
- void biank()
- unsigned char i; // unsigned char i,j;
- Set_Remap_Format(0x14);
- Write_cmd(0x15);
- Write_dat(0x1c);
- Write_dat(0x5b);
- Write_cmd(0x75);
- Write_dat(0x00);
- Write_dat(0x00);
- Write_cmd(0x5c);
- for(i=0;i<64;i++)
- Write_dat(0xff);
- Write_dat(0xff);
- Write_cmd(0x75);
- Write_dat(0x3f);
- Write_dat(0x3f);
- Write_cmd(0x5c);
- for(i=0;i<64;i++)
- Write_dat(0xff);
- Write_dat(0xff);
- Set_Remap_Format(0x15);
- Write_cmd(0x15);
- Write_dat(0x1c);
- Write_dat(0x1c);
- Write_cmd(0x75);
- Write_dat(0x01);
- Write_dat(0x3e);
- Write_cmd(0x5c);
- for(i=0;i<64;i++)
- Write_dat(0xf0);
- Write_dat(0x00);
- Write_cmd(0x15);
- Write_dat(0x5b);
- Write_dat(0x5b);
- Write_cmd(0x5c);
- for(i=0;i<64;i++)
- Write_dat(0x00);
- Write_dat(0x0f);
- 轉(zhuǎn)換函數(shù),D7=1,一位轉(zhuǎn)換成四位
- void change (uchar m)
- uchar k;
- uchar kk,kkk;
- kk=m;
- for(k=0;k<4;k++) // 一兩位的方式寫入 2*4=8位
- kkk=kk&0xc0; //當(dāng)K=0時(shí) 為D7,D6位 當(dāng)K=1時(shí) 為D5,D4位
- /****出現(xiàn)4種可能,16階色素,一個(gè)地址兩個(gè)像素,一個(gè)像素對(duì)應(yīng)4位***/
- switch(kkk)
- case 0x00:
- data_4byte[k]=0x00;
- break;
- case 0x40:
- data_4byte[k]=0x0f;
- break;
- case 0x80:
- data_4byte[k]=0xf0;
- break;
- case 0xc0:
- data_4byte[k]=0xff;
- break;
- default:
- break;
- kk=kk<<2; //左移兩位
- Write_dat(data_4byte[k]); /* 8 column a nibble of command is a dot*/
- 在顯示屏上寫一個(gè)8*16的數(shù)字
- // 用字模表tab816(1維數(shù)組),
- //在坐標(biāo)(x坐標(biāo))(y坐標(biāo))位置顯示一行字(左上腳坐標(biāo)),
- //其中x坐標(biāo)必須為偶數(shù)。
- //字占row行,一行col點(diǎn)。
- //以上定義都是unsigned char全局變量,
- void write_oled(uchar x,uchar y,uchar coder)
- uchar dat;
- uchar i;
- Set_Remap_Format(0x14); //定義2個(gè)地址,1個(gè)字節(jié)
- Write_cmd(0x15);
- Write_dat(0x1c+x);
- Write_dat(0x1d+x);
- Write_cmd(0x75); //16行
- Write_dat(0x00+y);
- Write_dat(0x10+y);
- Write_cmd(0x5c);
- for(i=0;i<16;i++)
- dat=tab816[i+16*coder];
- change(dat);
- 寫入一行8*16的數(shù)字
- void string816(uchar x,uchar y,uchar m)
- uchar i;
- for(i=0;i<m;i++)
- write_oled(x,y,i);
- x=x+4; //delay(2); 取消延時(shí),消除顯示停頓
- 寫入一行8*8的數(shù)字
- void write_oled8(uchar x,uchar y,uchar coder)
- uchar dat;
- uchar i;
- Write_cmd(0x15);
- Write_dat(0x08+y);
- Write_cmd(0x5c);
- for(i=0;i<8;i++)
- dat=tab88[i+8*coder];
- change(dat);
- 寫入一行8*8的數(shù)字
- void string88(uchar x,uchar y,uchar m)
- uchar i;
- for(i=0;i<m;i++)
- write_oled8(x,y,i);
- x=x+2;
- 在顯示屏上寫一個(gè)16*16的漢字
- // 用字模表tab1616(1維數(shù)組),
- //以上定義都是unsigned char全局變量,coder為代碼值
- void hzwrite_oled(uchar x,uchar y,uchar coder)
- uchar dat;
- uchar i;
- Set_Remap_Format(0x14); //定義4個(gè)地址,2個(gè)字節(jié)
- Write_cmd(0x15);
- Write_dat(0x1f+x);
- Write_cmd(0x5c);
- for(i=0;i<32;i++)
- dat=tab1616[i+32*coder];
- change(dat);
- // 寫入一行漢字
- void stinghz(uchar x,uchar y,uchar m)
- uchar i;
- for(i=0;i<m;i++)
- hzwrite_oled(x,y,i);
- x=x+6; delay(2);
- 卷動(dòng)程序
- void Set_Partial_Display(unsigned char a, unsigned char b, unsigned char c)
- Write_cmd(0xA8|a);
- // Default => 0x8F
- // Select Internal Booster at Display On
- if(a == 0x00)
- Write_dat(b);
- Write_dat(c);
- 顯示偏移量
- void Set_Display_Offset(unsigned char d)
- Write_cmd(0xA2); // Set Vertical Scroll by Row
- Write_dat(d); // Default => 0x00
- // Vertical Scrolling (Full Screen)
- // a: Scrolling Direction
- // "0x00" (Upward)
- // "0x01" (Downward)
- // b: Set Numbers of Row Scroll per Step
- // c: Set Time Interval between Each Scroll Step
- void Vertical_Scroll(unsigned char a, unsigned char b, unsigned char c)
- unsigned int i,j;
- Set_Partial_Display(0x00,0x00,Max_Row);
- switch(a)
- case 0:
- for(i=0;i<(Max_Row+1);i+=b)
- Set_Display_Offset(i+1);
- for(j=0;j<c;j++)
- delayus(100);
- break;
- case 1:
- Set_Display_Offset(Max_Row-i);
- for(j=0;j<c;j++)
- delayus(100);
- break;
- Set_Partial_Display(0x01,0x00,0x00);
- 起始行
- void Set_Start_Line(unsigned char d)
- Write_cmd(0xA1); // Set Vertical Scroll by RAM
- // Vertical Fade Scrolling (Full Screen)
- // "0x00" (Upward - In)
- // "0x01" (Downward - In)
- // "0x02" (Upward - Out)
- // "0x03" (Downward - Out)
- void Fade_Scroll(unsigned char a, unsigned char b, unsigned char c)
- unsigned int i,j;
- switch(a)
- case 0:
- for(i=(Max_Row+1);i<128;i+=b)
- Set_Start_Line(i);
- for(j=0;j<c;j++)
- delayus(100);
- Set_Start_Line(0x00);
- for(j=0;j<c;j++)
- delayus(100);
- break;
- case 1:
- Set_Start_Line(Max_Row-i);
- for(j=0;j<c;j++)
- delayus(100);
- break;
- case 2:
- Set_Start_Line(i+1);
- for(j=0;j<c;j++)
- delayus(100);
- break;
- case 3:
- for(i=127;i>Max_Row;i-=b)
- for(j=0;j<c;j++)
- delayus(100);
- break;
- // Show Regular Pattern (Partial or Full Screen)
- // a: Column Address of Start
- // b: Column Address of End (Total Columns Devided by 4)
- // c: Row Address of Start
- // d: Row Address of End
- void Fill_Block(unsigned char Data, unsigned char a, unsigned char b, unsigned char c, unsigned char d)
- Set_Column_Address(Shift+a,Shift+b);
- Set_Row_Address(c,d);
- Set_Write_RAM();
- for(i=0;i<(d-c+1);i++)
- for(j=0;j<(b-a+1);j++)
- Write_dat(Data);
- Write_dat(Data);
- // Show Gray Scale Bar (Full Screen)
- void Grayscale()
- // Level 16 => Column 1~16
- Fill_Block(0xFF,0x00,0x03,0x00,Max_Row);
- // Level 15 => Column 17~32
- Fill_Block(0xEE,0x04,0x07,0x00,Max_Row);
- // Level 14 => Column 33~48
- Fill_Block(0xDD,0x08,0x0B,0x00,Max_Row);
- // Level 13 => Column 49~64
- Fill_Block(0xCC,0x0C,0x0F,0x00,Max_Row);
- // Level 12 => Column 65~80
- Fill_Block(0xBB,0x10,0x13,0x00,Max_Row);
- // Level 11 => Column 81~96
- Fill_Block(0xAA,0x14,0x17,0x00,Max_Row);
- // Level 10 => Column 97~112
- Fill_Block(0x99,0x18,0x1B,0x00,Max_Row);
- // Level 9 => Column 113~128
- Fill_Block(0x88,0x1C,0x1F,0x00,Max_Row);
- // Level 8 => Column 129~144
- Fill_Block(0x77,0x20,0x23,0x00,Max_Row);
- // Level 7 => Column 145~160
- Fill_Block(0x66,0x24,0x27,0x00,Max_Row);
- // Level 6 => Column 161~176
- Fill_Block(0x55,0x28,0x2B,0x00,Max_Row);
- // Level 5 => Column 177~192
- Fill_Block(0x44,0x2C,0x2F,0x00,Max_Row);
- // Level 4 => Column 193~208
- Fill_Block(0x33,0x30,0x33,0x00,Max_Row);
- // Level 3 => Column 209~224
- Fill_Block(0x22,0x34,0x37,0x00,Max_Row);
- // Level 2 => Column 225~240
- Fill_Block(0x11,0x38,0x3B,0x00,Max_Row);
- // Level 1 => Column 241~256
- Fill_Block(0x00,0x3C,Max_Column,0x00,Max_Row);
- 主函數(shù)
- void main(void)
- REST=0;
- delayms(100);
- REST=1;
- delayms(50); //100
- Initial();
- while(1)
- Fill_RAM(0xff); //全顯示
- delay(2);
- Fill_RAM(0xf0); //豎線
- delay(2);
- Fill_RAM(0x0f); //豎線
- delay(2);
- hang(0xff); //顯示行
- delay(2);
- hang(0x00); //顯示行
- delay(2);
- gedot(0xf0); //顯示點(diǎn)
- delay(2);
- gedot(0x0f); //顯示點(diǎn)
- delay(2);
- Fill_RAM(0x00); // Clear Screen
- write_oled(0,0,0x00);
- write_oled(4,0,0x01);
- biank(); //矩形框
- delay(10);
- hzwrite_oled(14,0,0x00);
- hzwrite_oled(22,0,0x01);
- hzwrite_oled(30,0,0x02);
- hzwrite_oled(38,0,0x03);
- string88(0,17,32);
- stinghz(4,25,10) ;
- string816(14,45,10);
- delay(10);
- Grayscale(); //顯示灰階
- delay(10);
- // delay(10);
- // fill(0xff,0xff);
- display_graphic_256x64_0();
- delay(10);
- display_graphic_256x64_1();
- delay(10);
- unsigned char code bmp25664_0[]=
- /*-- 調(diào)入了一幅圖像:E:\LCD小工具\(yùn)程序圖片\25664.bmp --*/
- /*-- 寬度x高度=256x64 --*/
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
3.12寸OLED模組(1).zip
(7.63 MB, 下載次數(shù): 87)
2018-8-9 17:36 上傳
點(diǎn)擊文件名下載附件
stm32
