查看: 3065|回復(fù): 0
RL78G14瑞薩單片機(jī)的蜂鳴器PWM輸出后無(wú)反應(yīng),幫忙看下程序,急~~~
設(shè)計(jì)思路:
一、蜂鳴器:頻率為40KHz,周期25us,占空比50%,P70為蜂鳴器開(kāi)關(guān),P31為PWM輸出。
二、程   序:根據(jù)聯(lián)動(dòng)通道設(shè)置,主機(jī)通道為0,從機(jī)通道為3,PWM輸出引腳為T(mén)O03。
三、原理圖:
四、程序代碼:
#define Port_Beep_OUT   P7.0
#define Port_Beep_PWM   P3.1
PM3.1 = 0; P3.1 = 0;    //Buzzer PWM Out
PM7.0 = 0; P7.0 = 0;    //Buzzer Switch
void R_TAU0_Create(void)
    TAU0EN = 1U;    /* supplies input clock */
TPS0 = _0000_TAU_CKM0_FCLK_0 | _0000_TAU_CKM1_FCLK_0 | _0000_TAU_CKM2_FCLK_1 | _0000_TAU_CKM3_FCLK_8;
    /* Stop all channels */
    TT0 = _0001_TAU_CH0_STOP_TRG_ON | _0002_TAU_CH1_STOP_TRG_ON | _0004_TAU_CH2_STOP_TRG_ON | _0008_TAU_CH3_STOP_TRG_ON | _0200_TAU_CH1_H8_STOP_TRG_ON | _0800_TAU_CH3_H8_STOP_TRG_ON;
    /* Mask channel 0 interrupt */
    TMMK00 = 1U;    /* disable INTTM00 interrupt */
    TMIF00 = 0U;    /* clear INTTM00 interrupt flag */
    /* Mask channel 1 interrupt */
    TMMK01 = 1U;    /* disable INTTM01 interrupt */
    TMIF01 = 0U;    /* clear INTTM01 interrupt flag */
    /* Mask channel 1 higher 8 bits interrupt */
    TMMK01H = 1U;    /* disable INTTM01H interrupt */
    TMIF01H = 0U;    /* clear INTTM01H interrupt flag */
    /* Mask channel 2 interrupt */
    TMMK02 = 1U;    /* disable INTTM02 interrupt */
    TMIF02 = 0U;    /* clear INTTM02 interrupt flag */
    /* Mask channel 3 interrupt */
    TMMK03 = 1U;    /* disable INTTM03 interrupt */
    TMIF03 = 0U;    /* clear INTTM03 interrupt flag */
    /* Mask channel 3 higher 8 bits interrupt */
    TMMK03H = 1U;    /* disable INTTM03H interrupt */
    TMIF03H = 0U;    /* clear INTTM03H interrupt flag */
    /* Set INTTM00 low priority */
    TMPR100 = 1U;
    TMPR000 = 1U;
    /* Set INTTM03 low priority */
    TMPR103 = 1U;
    TMPR003 = 1U;
/* Channel 0 is used as master channel for PWM output function */
    TMR00 = _0000_TAU_CLOCK_SELECT_CKM0 | _0000_TAU_CLOCK_MODE_CKS | _0000_TAU_COMBINATION_MASTER | _0000_TAU_TRIGGER_SOFTWARE | _0001_TAU_MODE_PWM_MASTER;
    TDR00 = 0x031F; //799,周期25us
    TO0 &= ~_0001_TAU_CH0_OUTPUT_VALUE_1;
    TOE0 &= ~_0001_TAU_CH0_OUTPUT_ENABLE;
    /* Channel 3 is used as slave channel for PWM output function */
    TMR03 = _0000_TAU_CLOCK_SELECT_CKM0 | _0000_TAU_CLOCK_MODE_CKS | _0000_TAU_COMBINATION_SLAVE | _0400_TAU_TRIGGER_MASTER_INT | _0009_TAU_MODE_PWM_SLAVE;
    TDR03 = 0x0190; //400,占空比50%
    TOM0 |= _0008_TAU_CH3_OUTPUT_COMBIN;
    TOL0 &= ~_0008_TAU_CH3_OUTPUT_LEVEL_L;
    TO0 |= _0008_TAU_CH3_OUTPUT_VALUE_1;
    TOE0 |= _0008_TAU_CH3_OUTPUT_ENABLE;
    /* Set TO03 pin */
    P3 &= 0xFDU;
    PM3 &= 0xFDU;
void R_TAU0_Channel0_Start(void)
    TMMK00 = 0U;    /* enable INTTM00 interrupt */
    TMMK03 = 0U;    /* enable INTTM03 interrupt */
    TS0 |= _0001_TAU_CH0_START_TRG_ON | _0008_TAU_CH3_START_TRG_ON;
void R_TAU0_Channel0_Stop(void)
    TT0 |= _0001_TAU_CH0_STOP_TRG_ON | _0008_TAU_CH3_STOP_TRG_ON;
    TOE0 &= ~_0008_TAU_CH3_OUTPUT_ENABLE;
#pragma interrupt INTTM00 r_tau0_channel0_interrupt
__interrupt static void r_tau0_channel0_interrupt(void)
#pragma interrupt INTTM03 r_tau0_channel3_interrupt
__interrupt static void r_tau0_channel3_interrupt(void)
void main(void)
hdwinit();
R_MAIN_UserInit();
R_TAU0_Channel0_Start();
   Port_Beep_OUT = 1;       //打開(kāi)蜂鳴器,讓他一直響。
