制作一個(gè)貪吃蛇小游戲用12864顯示,即時(shí)顯示,可控制速度,附上源代碼,just娛樂(lè),可供研究
- //12864并行接口參考程序,控制器st7920
- #include "reg51.h"
- #include "Lcd12864.h"
- #include "Key.h"
- #define uchar unsigned char
- #define uint unsigned int
- static unsigned long Seed = 1;
- #define A 48271L
- #define M 2147483647L
- #define Q (M / A)
- #define R (M % A)
- 偽隨機(jī)數(shù)發(fā)生器
- double Random(void)
- long TmpSeed;
- TmpSeed=A*(Seed%Q)-R*(Seed/Q);
- if(TmpSeed>=0)
- Seed=TmpSeed;
- else
- Seed=TmpSeed+M;
- return (double)Seed/M;
- 為偽隨機(jī)數(shù)發(fā)生器播種
- void InitRandom(unsigned long InitVal)
- Seed=InitVal;
- //延時(shí)子程序
- void delay(unsigned int t)
- unsigned int i,j;
- for(i=0;i<t;i++)
- for(j=0;j<10;j++);
- 初始化MPU
- void InitCpu(void)
- TMOD=0x0;
- TH0=0;
- TL0=0;
- TR0=1;
- ET0=1;
- EA=1;
- #define N 25
- struct Food
- unsigned char x;
- unsigned char y;
- unsigned char yes;
- }food;//食物結(jié)構(gòu)體
- struct Snake
- unsigned char x[N];
- unsigned char y[N];
- unsigned char node;
- unsigned char direction;
- unsigned char life;
- }snake;//蛇結(jié)構(gòu)體
- unsigned char Flag=0;
- unsigned char Score=0;
- unsigned char Speed=5;
- unsigned char KeyBuffer=0;
- #define FUNC 1
- #define UP 2
- #define DOWN 3
- #define LEFT 4
- #define RIGHT 5
- #define PASSSCORE 50//預(yù)定義過(guò)關(guān)成績(jī)
- void Timer0Int(void) interrupt 1
- switch(OSReadKey())
- case 9:
- KeyBuffer=FUNC;
- /*if(++Speed>=10)
- Speed=1;
- Flag|=1<<1;//速度變化標(biāo)志置1*/
- break;
- case 13:
- KeyBuffer=DOWN;
- /*if(snake.direction!=2)
- snake.direction=1;*/
- break;
- case 17:
- KeyBuffer=UP;
- /*if(snake.direction!=1)
- snake.direction=2;*/
- break;
- case 21:
- KeyBuffer=RIGHT;
- /*if(snake.direction!=4)
- snake.direction=3;*/
- break;
- case 25:
- KeyBuffer=LEFT;
- /*if(snake.direction!=3)
- snake.direction=4;*/
- break;
- default:
- break;
- /* if(K1==1)
- KeyBuffer=DOWN;
- //if(++Speed>=10) Speed=1; Flag|=1<<1;//速度變化標(biāo)志置1
- if(K2==1)
- KeyBuffer=RIGHT;
- //if(snake.direction!=2) snake.direction=1;
- 畫(huà)墻壁,初始化界面
- void DrawBoard(void)
- unsigned char n;
- for(n=0;n<31;n++)
- Lcd_Rectangle(3*n,0,3*n+2,2,1);
- Lcd_Rectangle(3*n,60,3*n+2,62,1);
- for(n=0;n<21;n++)
- Lcd_Rectangle(0,3*n,2,3*n+2,1);
- Lcd_Rectangle(90,3*n,92,3*n+2,1);
- Lcd_HoriLine(93,31,35,1);
- Lcd_HoriLine(93,63,35,1);
- 打印成績(jī)
- void PrintScore(void)
- unsigned char Str[3];
- Lcd_WriteStr(6,0,"成績(jī)");
- Str[0]=(Score/10)|0x30;//十位
- Str[1]=(Score%10)|0x30;//個(gè)位
- Str[2]=0;
- Lcd_WriteStr(7,1,Str);
- 打印速度級(jí)別
- void PrintSpeed(void)
- unsigned char Str[2];
- Lcd_WriteStr(6,2,"級(jí)別");
- Str[0]=Speed|0x30;
- Str[1]=0;
- Lcd_WriteStr(7,3,Str);
- 游戲結(jié)束處理
- void GameOver(void)
- unsigned char n;
- Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隱出食物
- for(n=1;n<snake.node;n++)
- Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,0);//消隱食物,蛇頭已到墻壁內(nèi),故不用消去
- if(snake.life==0)//如果蛇還活著
- Lcd_WriteStr(2,1,"通關(guān)");
- else //如果蛇死了
- Lcd_WriteStr(2,1,"輸了");
- Lcd_WriteStr(1,2,"游戲結(jié)束");
- 游戲的具體過(guò)程,也是貪吃蛇算法的關(guān)鍵部分
- void GamePlay(void)
- unsigned char n;
- InitRandom(TL0); //數(shù)據(jù)流入
- food.yes=1;//1表示需要出現(xiàn)新事物,0表示已經(jīng)存在食物尚未吃掉
- snake.life=0;//表示蛇還活著
- snake.direction=DOWN;
- snake.x[0]=6;snake.y[0]=6;
- snake.x[1]=3;snake.y[1]=6;
- snake.node=2;
- PrintScore();
- PrintSpeed();
- while(1)
- if(food.yes==1)
- while(1)
- food.x=Random()*85+3;
- food.y=Random()*55+3;//獲得隨機(jī)數(shù)
- while(food.x%3!=0)
- food.x++;
- while(food.y%3!=0)
- food.y++;
- for(n=0;n<snake.node;n++)//判斷產(chǎn)生的食物坐標(biāo)是否和蛇身重合
- if((food.x==snake.x[n])&&(food.y==snake.y[n]))
- break;
- if(n==snake.node)
- food.yes=0;
- break;//產(chǎn)生有效的食物坐標(biāo)
- if(food.yes==0)
- Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,1);
- for(n=snake.node-1;n>0;n--)
- snake.x[n]=snake.x[n-1];
- snake.y[n]=snake.y[n-1];
- switch(snake.direction)
- case DOWN:snake.x[0]+=3;break;
- case UP:snake.x[0]-=3;break;
- case RIGHT:snake.y[0]-=3;break;
- case LEFT:snake.y[0]+=3;break;
- default:break;
- for(n=3;n<snake.node;n++)//從第三節(jié)開(kāi)始判斷蛇頭是否咬到自己
- if(snake.x[n]==snake.x[0]&&snake.y[n]==snake.y[0])
- GameOver();
- snake.life=1;
- break;
- if(snake.x[0]<3||snake.x[0]>=90||snake.y[0]<3||snake.y[0]>=60)//判蛇頭是否撞到墻壁
- GameOver();
- snake.life=1;
- if(snake.life==1)
- break;//蛇死,則跳出while(1)循環(huán)
- if(snake.x[0]==food.x&&snake.y[0]==food.y)//判蛇是否吃到食物
- Lcd_Rectangle(food.x,food.y,food.x+2,food.y+2,0);//消隱食物
- snake.x[snake.node]=200;
- snake.y[snake.node]=200;//產(chǎn)生蛇新的節(jié)坐標(biāo)先放在看不見(jiàn)的位置
- snake.node++;//蛇節(jié)數(shù)加1
- food.yes=1;//食物標(biāo)志置1
- if(++Score>=PASSSCORE)
- PrintScore();
- GameOver();
- break;
- PrintScore();
- Lcd_Rectangle(snake.x[n],snake.y[n],snake.x[n]+2,snake.y[n]+2,1);
- }//根據(jù)蛇的節(jié)數(shù)畫(huà)出蛇
- delay(Speed*1000);
- Lcd_Rectangle(snake.x[snake.node-1],snake.y[snake.node-1],snake.x[snake.node-1]+2,snake.y[snake.node-1]+2,0);
- switch(KeyBuffer)
- case FUNC:
- KeyBuffer=0;
- if(++Speed>=10)
- Speed=1;
- PrintSpeed();
- break;
- case DOWN:
- KeyBuffer=0;
- if(snake.direction!=UP)
- break;
- case UP:
- KeyBuffer=0;
- if(snake.direction!=DOWN)
- snake.direction=UP;
- break;
- case RIGHT:
- KeyBuffer=0;
- if(snake.direction!=LEFT)
- snake.direction=RIGHT;
- break;
- case LEFT:
- KeyBuffer=0;
- if(snake.direction!=RIGHT)
- snake.direction=LEFT;
- break;
- default:
- break;
- }//結(jié)束while(1)
- void Main()
- InitCpu();//初始化CPU
- Lcd_Reset(); //初始化LCD屏
- Lcd_Clear(0);//清屏
- DrawBoard();//畫(huà)界面
- GamePlay();//玩游戲
- GameOver();//游戲結(jié)束
- while(1);//要想重玩,只能重啟,可繼續(xù)完善該游戲
SnakeGame.rar
(72.74 KB, 下載次數(shù): 37)
2018-8-10 15:50 上傳
點(diǎn)擊文件名下載附件
貪吃蛇小游戲
