電動(dòng)車(chē)是吃得多才能跑的遠(yuǎn),為方便測(cè)試電動(dòng)車(chē)電瓶的容量,前段時(shí)間在某寶入手了一個(gè)機(jī)械式電度表,到手只有十幾元。不過(guò)便宜沒(méi)好貨,這貨經(jīng)常停走。檢查發(fā)現(xiàn)是機(jī)械計(jì)數(shù)器阻力太大造成的。于是采用單片機(jī)對(duì)其進(jìn)行改進(jìn),改進(jìn)思路是用單片機(jī)記錄電度表的光耦輸出脈沖,轉(zhuǎn)換成電度數(shù)用數(shù)碼管顯示出來(lái)。另外還分時(shí)顯示了充電器功率(瓦數(shù))和充電時(shí)間(小時(shí)數(shù))。程序見(jiàn)附件。
- #define MAIN_Fosc 11059200L //定義主時(shí)鐘
- //#include<reg52.h>
- #include "STC15Fxxxx.H"
- #define uchar unsigned char
- #define uint unsigned int
- sbit COUNT_IN=P3^2;
- unsigned code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
- #define DataPort P1;
- sbit led1=P3^4;
- sbit led2=P3^5;
- sbit led3=P3^6;
- sbit led4=P3^7;
- unsigned long count;
- unsigned long kwh;
- unsigned int w,h;
- float s;
- bit flag;
- void init()
- IT0=1; //INT0負(fù)跳變觸發(fā)
- TMOD=0x01;//定時(shí)器工作于方式1
- TH0=0x3c; //50ms
- TL0=0xb0;
- EA=1; //CPU開(kāi)中斷總允許
- ET0=1;//開(kāi)定時(shí)中斷
- EX0=1;//開(kāi)外部INTO中斷
- TR0=1;//啟動(dòng)定時(shí)
- // 函數(shù): void Delayms(unsigned int ms)
- // 描述: 延時(shí)函數(shù)。
- // 參數(shù): ms,要延時(shí)的ms數(shù), 這里只支持1~65535ms. 自動(dòng)適應(yīng)主時(shí)鐘.
- // 返回: none.
- // 版本: VER1.0
- // 日期: 2013-4-1
- // 備注:
- void Delayms(unsigned int ms)
- unsigned int i;
- do{
- i = MAIN_Fosc / 13000;
- while(--i) ; //14T per loop
- }while(--ms);
- void EXINT0() interrupt 0
- // kwh=kwh+.000625;
- count++; //累計(jì)電度表輸出脈沖個(gè)數(shù)
- void time0() interrupt 1
- TH0=0x3c;
- TL0=0xb0; //50ms(實(shí)測(cè)每次循環(huán)52.9514ms,使用STC15W408AS內(nèi)部時(shí)鐘,11.0592Mhz,環(huán)境溫度29℃)
- s=s+.0529514; //累計(jì)秒數(shù)
- void display_SMG_kwh(void)
- P1=table[kwh/1000];
- led1= 0;
- Delayms(5);
- led1 = 1;
- P1=table[kwh%1000/100]&0x7f;
- led2 = 0;
- Delayms(5);
- led2 = 1;
- P1=table[kwh%100/10];
- led3 = 0;
- Delayms(5);
- led3 = 1;
- P1=table[kwh%10];
- led4 = 0;
- Delayms(5);
- led4 = 1;
- void display_SMG_w(void)
- P1=table[w%10000/1000];
- led1= 0;
- Delayms(5);
- led1 = 1;
- P1=(table[w%1000/100]);
- led2 = 0;
- Delayms(5);
- led2 = 1;
- P1=table[w%100/10];
- led3 = 0;
- Delayms(5);
- led3 = 1;
- P1=table[w%10];
- led4 = 0;
- Delayms(5);
- led4 = 1;
- void display_SMG_h(void)
- P1=0x8b;
- // P1=table[h/1000];
- led1= 0;
- Delayms(5);
- led1 = 1;
- P1=table[h%1000/100];
- led2 = 0;
- Delayms(5);
- led2 = 1;
- P1=table[h%100/10]&0x7f;
- led3 = 0;
- Delayms(5);
- led3 = 1;
- P1=table[h%10];
- led4 = 0;
- Delayms(5);
- led4 = 1;
- void main()
- unsigned char a;
- init();
- while(1)
- for(a=0;a<=50;a++)
- kwh=count*.0625; //用電度數(shù)=電度表閃燈次數(shù)*.000625kwh/1000*100,(2位小數(shù))
- display_SMG_kwh();
- w=kwh*1000*3600/s; //用電瓦數(shù)=累計(jì)千瓦時(shí)*1000*3600/累計(jì)秒數(shù)
- display_SMG_w();
- h=s/360; //用電小時(shí)數(shù)=累計(jì)秒數(shù)/3600*10,(1位小數(shù))
STC15W408AS+電度表smg4.rar
(47.84 KB, 下載次數(shù): 17)
2018-8-11 13:45 上傳
點(diǎn)擊文件名下載附件
