查看: 3633|回復(fù): 4
單片機LCD1602隨機模擬顯示乘法口訣的proteus仿真與源程序
ID:387019 發(fā)表于 2018-8-16 19:13 | 顯示全部樓層 |閱讀模式
lcd1602隨機顯示乘法口訣的仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
單片機源程序如下:
  1. #include <REGX52.H>
  2. #include <INTRINS.H>
  3. unsigned int x,y,z;
  4. unsigned int sj_x_cnt = 0,sj_y_cnt = 0;//隨機
  5. unsigned int sd_x_cnt = 0,sd_y_cnt = 0;//順到序
  6. unsigned char cheng[46][2] =
  7. {
  8. {0,0},
  9. {1,1},
  10. {1,2},{2,2},
  11. {1,3},{2,3},{3,3},
  12. {1,4},{2,4},{3,4},{4,4},
  13. {1,5},{2,5},{3,5},{4,5},{5,5},
  14. {1,6},{2,6},{3,6},{4,6},{5,6},{6,6},
  15. {1,7},{2,7},{3,7},{4,7},{5,7},{6,7},{7,7},
  16. {1,8},{2,8},{3,8},{4,8},{5,8},{6,8},{7,8},{8,8},
  17. {1,9},{2,9},{3,9},{4,9},{5,9},{6,9},{7,9},{8,9},{9,9},
  18. };
  19. void delay1ms(unsigned char xms)
  20. {
  21.         unsigned char i,j;
  22.         for(i=xms;i>0;i--)
  23.                 for(j=110;j>0;j--);
  24. }
  25. /***************液晶顯示模塊*****************/
  26. sbit RS=P2^0;
  27. sbit RW=P2^1;
  28. sbit E=P2^2;
  29. sbit key=P1^4;
  30. sbit key2=P1^5;
  31. sbit key3=P1^6;
  32. //sbit BF=P0^7;
  33.   /*液晶忙檢測
  34. bit BusyTest(void)
  35. {
  36.         bit result;
  37.         RS=0;
  38.         RW=1;
  39.         E=1;
  40.         _nop_();
  41.         _nop_();
  42.         _nop_();
  43.         result=BF;
  44.         _nop_();
  45.         _nop_();
  46.         _nop_();
  47.         E=0;
  48.         return result;
  49. }*/
  50. /*寫指令*/
  51. void Write_com(unsigned char command)
  52. {
  53. //        while(BusyTest()!=0);
  54.         RS=0;
  55.         RW=0;
  56.         E=0;
  57.         _nop_();
  58.         _nop_();
  59.         _nop_();
  60.         P0=command;
  61.         _nop_();
  62.         _nop_();
  63.         _nop_();
  64.         E=1;
  65.         _nop_();
  66.         _nop_();
  67.         _nop_();
  68.         E=0;
  69. }
  70. /*寫地址*/
  71. void Write_Address(unsigned char address)
  72. {
  73.         Write_com(address);
  74.         delay1ms(1);
  75. }
  76. /*寫數(shù)據(jù)*/
  77. void Write_Date(unsigned char date)
  78. {
  79.         RS=1;
  80.         RW=0;
  81.         E=0;
  82.         _nop_();
  83.         _nop_();
  84.         _nop_();
  85.         P0=date;
  86.         _nop_();
  87.         _nop_();
  88.         _nop_();
  89.         E=1;
  90.         _nop_();
  91.         _nop_();
  92.         _nop_();
  93.         E=0;
  94.         delay1ms(1);
  95. }
  96. /*初始化*/
  97. void Lcd_Int(void)
  98. {
  99.         Write_com(0x38);
  100.         delay1ms(1);
  101.         Write_com(0x38);
  102.         Write_com(0x38);
  103.         delay1ms(1);
  104.         delay1ms(1);
  105.         Write_com(0x06);
  106.         delay1ms(1);
  107.         Write_com(0x0c);
  108.         delay1ms(1);
  109.         Write_com(0x01);
  110. }
  111. void writelcd(unsigned char a,b,dat)
  112. {
  113.         if(b==1)
  114.         {
  115.                 Write_Address(0x80+a);
  116.                 Write_Date(dat);
  117.         }
  118.            else
  119.         {
  120.                 Write_Address(0xc0+a);
  121.                 Write_Date(dat);
  122.         }
  123. }
  124. void main()
  125. {
  126.     unsigned char mode = 0;
  127.         int k_cnt = 0;
  128.         TMOD = 0x01;
  129.     TH0 = 0x0EC;
  130.     TL0 = 0x78;
  131.     EA = 1;
  132.     ET0 = 1;
  133.     TR0 = 0;
  134.         Lcd_Int();
  135.         mode = 1;//默認為隨機的
  136.         while(1)
  137.         {
  138.                 if(key==0)
  139.                 {
  140.                         delay1ms(10);
  141.                         if(key==0)
  142.                         {
  143.                                 TR0=1;
  144.                         }
  145.                         while(!key);
  146.                         TR0=0;
  147.                         mode = 1; //隨機
  148.                 }
  149.                 else if(key2==0)
  150.                 {
  151.                         delay1ms(10);
  152.                         if(key2==0)
  153.                         {
  154.                                 while(!key2);
  155.                                 mode = 2;//順序
  156.                                 k_cnt ++;
  157.                                 if(k_cnt >=46)
  158.                                         k_cnt = 0;
  159.                         }
  160.                 }
  161.                 else if(key3==0)
  162.                 {
  163.                         delay1ms(10);
  164.                         if(key3==0)
  165.                         {
  166.                                 while(!key3);
  167.                                 mode = 3;//倒序
  168.                                 k_cnt --;
  169.                                 if(k_cnt <= 0)
  170.                                         k_cnt = 45;
  171.                         }
  172.                 }
  173.                 if(mode == 1)
  174.                 {
  175.                         x = sj_x_cnt;
  176.                         y = sj_y_cnt;
  177.                 }
  178.                 else
  179.                 {
  180.                         x = cheng[k_cnt][0];
  181.                         y = cheng[k_cnt][1];
  182.                 }
  183.                 z=x*y;
  184.                 Write_Address(0x80);
  185.                 if(x/10!=0)
  186.                 Write_Date(0x30+x/10);
  187.                 Write_Date(0x30+x%10);
  188.                 Write_Date('*');
  189.                 if(y/10!=0)
  190.                 Write_Date(0x30+y/10);
  191.                 Write_Date(0x30+y%10);
  192.                 Write_Date('=');
  193.                 if(z/1000!=0)
  194. ……………………
  195. …………限于本文篇幅 余下代碼請從51黑下載附件…………
1602LCD隨機模擬顯示乘法口訣.rar (54.06 KB, 下載次數(shù): 52)
admin + 50 共享資料的黑幣獎勵!
ID:387047 發(fā)表于 2018-8-16 21:11 | 顯示全部樓層
看到這麼完整的PCB封裝庫,心理非場想要,但我得努力賺黑幣才行~
ID:387047 發(fā)表于 2018-8-16 21:12 | 顯示全部樓層
心理非場想要,但我得努力賺黑幣才行~
ID:1 發(fā)表于 2018-8-17 00:05 | 顯示全部樓層
注意,此程序存在重復(fù)內(nèi)容:詳見http://www.torrancerestoration.com/bbs/dpj-84794-1.html
以后不要發(fā)這種重復(fù)的
ID:818482 發(fā)表于 2020-9-13 14:37 | 顯示全部樓層
非常有用,看完恍然大悟
