查看: 8220|回復(fù): 10
幫我看看這個(gè)矩陣按鍵鍵盤控制8*8的點(diǎn)陣顯示數(shù)字程序
ID:370231 發(fā)表于 2018-8-18 15:32 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
我是初學(xué)的,我是想用矩陣按鍵鍵盤控制8*8的點(diǎn)陣顯示數(shù)字,可是我寫的程序按鍵控制不了數(shù)字,不知道哪里出現(xiàn)了問題,幫我改一下,謝謝~~
  1. #include<reg51.h>
  2. typedef unsigned int u16;
  3. typedef unsigned char u8;
  4. //--定義要使用的IO口--//
  5. #define READPORTS                 P1
  6. #define GPIO_KEY        P2
  7. #define COMMONPORTS                P0
  8.
  9. u8 KeyValue;
  10. void delay(u16 i)
  11. {
  12.         while(i--);
  13. }
  14. void KeyDown(void)
  15. {
  16.         char a=0;
  17.         GPIO_KEY=0x0f;
  18.         if(GPIO_KEY!=0x0f)
  19.         {
  20.                 delay(1000);
  21.                 if(GPIO_KEY!=0x0f)
  22.                 {
  23.
  24.                         GPIO_KEY=0X0F;
  25.                         switch(GPIO_KEY)
  26.                         {
  27.                                 case(0X07):        KeyValue=0;break;
  28.                                 case(0X0b):        KeyValue=1;break;
  29.                                 case(0X0d): KeyValue=2;break;
  30.                                 case(0X0e):        KeyValue=3;break;
  31.                         }
  32.
  33.                         GPIO_KEY=0XF0;
  34.                         switch(GPIO_KEY)
  35.                         {
  36.                                 case(0X70):        KeyValue=KeyValue;break;
  37.                                 case(0Xb0):        KeyValue=KeyValue+4;break;
  38.                                 case(0Xd0): KeyValue=KeyValue+8;break;
  39.                                 case(0Xe0):        KeyValue=KeyValue+12;break;
  40.                         }
  41.                         while((a<50)&&(GPIO_KEY!=0xf0))
  42.                         {
  43.                                 delay(1000);
  44.                                 a++;
  45.                         }
  46.                 }
  47.         }
  48. }
  49. //--列選通控制--//
  50. unsigned char code TAB[8]  = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  51. //--點(diǎn)陣字碼--//
  52. unsigned char code CHARCODE[16][8]={
  53. {0x00,0x00,0x3e,0x41,0x41,0x41,0x3e,0x00}, //0
  54. {0x00,0x00,0x00,0x00,0x21,0x7f,0x01,0x00}, //1
  55. {0x00,0x00,0x27,0x45,0x45,0x45,0x39,0x00}, //2
  56. {0x00,0x00,0x22,0x49,0x49,0x49,0x36,0x00}, //3
  57. {0x00,0x00,0x0c,0x14,0x24,0x7f,0x04,0x00}, //4
  58. {0x00,0x00,0x72,0x51,0x51,0x51,0x4e,0x00}, //5
  59. {0x00,0x00,0x3e,0x49,0x49,0x49,0x26,0x00}, //6
  60. {0x00,0x00,0x40,0x40,0x40,0x4f,0x70,0x00}, //7
  61. {0x00,0x00,0x36,0x49,0x49,0x49,0x36,0x00}, //8
  62. {0x00,0x00,0x32,0x49,0x49,0x49,0x3e,0x00}, //9
  63. {0x00,0x00,0x7F,0x48,0x48,0x30,0x00,0x00}, //P
  64. {0x00,0x00,0x7F,0x48,0x4C,0x73,0x00,0x00}, //R
  65. {0x00,0x00,0x7F,0x49,0x49,0x49,0x00,0x00}, //E
  66. {0x00,0x00,0x3E,0x41,0x41,0x62,0x00,0x00}, //C
  67. {0x00,0x00,0x7F,0x08,0x08,0x7F,0x00,0x00}, //H
  68. {0x00,0x00,0x00,0xFF,0xFF,0x00,0x00,0x00}, //I
  69. };
  70. void main()
  71. {
  72.         unsigned char tab, j;
  73.         unsigned int  i;   //無符號(hào)整數(shù)
  74.         while(1)
  75.         {
  76.
  77.
  78.                 for(i= 0; i<5000; i++ )   //兩個(gè)字之間的掃描間隔時(shí)間
  79.                 {
  80.                         KeyDown();
  81.                         COMMONPORTS=CHARCODE[KeyValue];
  82.                         for(tab=0;tab<8;tab++)
  83.                         {
  84.                                 READPORTS=0xFF;                                   //消隱
  85.                                 COMMONPORTS=CHARCODE[j][tab];  //輸出字碼
  86.                                 READPORTS=TAB[tab];
  87.                         }
  88.                 }
  89.                 j++;
  90.                 if(j == 16)
  91.                 {
  92.                         j = 0;
  93.                 }
  94.         }
  95. }
ID:370231 發(fā)表于 2018-8-18 16:45 | 只看該作者
求指點(diǎn)迷津
ID:164602 發(fā)表于 2018-8-18 17:35 | 只看該作者
從你的程序上看,按鍵當(dāng)然不能控制顯示。
第一:你的電路圖沒有給出來,不好判斷程序?qū)Σ粚?duì),只能以我的經(jīng)驗(yàn)去看程序——思路基本正確。
第二:主循環(huán)中這句: COMMONPORTS=CHARCODE[j][tab];  //輸出字碼
應(yīng)該改為: COMMONPORTS=CHARCODE[KeyValue][tab];  //輸出字碼
第三:主循環(huán)中這句是多余且錯(cuò)誤的,去掉:COMMONPORTS=CHARCODE[KeyValue];
第四:主循環(huán)中這些: j++;
                if(j == 16)
                        j = 0;
我不知道你的用途。應(yīng)該是沒用的。
ID:370231 發(fā)表于 2018-8-18 23:49 | 只看該作者
HC6800-ES-V2.0 發(fā)表于 2018-8-18 17:35
第一:你的電路圖沒有給出來,不好判斷程序?qū)Σ粚?duì),只能以我的經(jīng) ...
我用的板子是普中科技的HC6800-EM3 V2.2的開發(fā)板,根據(jù)你說的我試了一下還是不行,不過還是要謝謝你,多謝你的指教
ID:164602 發(fā)表于 2018-8-19 07:58 | 只看該作者
a89588038 發(fā)表于 2018-8-18 23:49
我用的板子是普中科技的HC6800-EM3 V2.2的開發(fā)板,根據(jù)你說的我試了一下還是不行,不過還是要謝謝你,多 ...
普中的板子?將板子照片發(fā)一個(gè)。。。!
我知道的普中板子,點(diǎn)陣都有595控制哦,你的程序中,沒有595的控制內(nèi)容嘛。
單片機(jī)程序一定與相應(yīng)的硬件是配套的,你不給硬件只發(fā)程序,沒用的。
ID:370231 發(fā)表于 2018-8-19 13:11 | 只看該作者
HC6800-ES-V2.0 發(fā)表于 2018-8-19 07:58
我知道的普中板子,點(diǎn)陣都有595控制哦,你的程序中,沒有595的 ...
ID:370231 發(fā)表于 2018-8-19 20:47 | 只看該作者
終于弄出來了,先上程序,從主循環(huán)開始,稍微改動(dòng)一下,就是不明白為什么排線都要反著插才顯示出來,不然就是倒著顯示。放圖片上去給大家看看。多多指教~~~
修改的程序
                        KeyDown();
                    READPORTS=TAB[tab];
                        j++;
                if(j == 16)
                        j = 0;
參與人數(shù) 1黑幣 +80 收起 理由
admin + 80 回帖助人的獎(jiǎng)勵(lì)!
ID:164602 發(fā)表于 2018-8-20 08:42 | 只看該作者
a89588038 發(fā)表于 2018-8-19 20:47
終于弄出來了,先上程序,從主循環(huán)開始,稍微改動(dòng)一下,就是不明白為什么排線都要反著插才顯示出來, ...
你這款普中板子還真沒看到過。
將電路圖文件發(fā)來看看,謝謝。
至于你說的現(xiàn)象,肯定是和電路有關(guān)。
ID:370231 發(fā)表于 2018-8-20 14:39 | 只看該作者
HC6800-ES-V2.0 發(fā)表于 2018-8-20 08:42
你這款普中板子還真沒看到過。
將電路圖文件發(fā)來看看,謝謝。
EM3-V22原理圖.pdf (196.36 KB, 下載次數(shù): 44)
ID:440947 發(fā)表于 2018-12-9 17:49 | 只看該作者
請(qǐng)問樓主有木有原理圖,能否看一下?
ID:258260 發(fā)表于 2018-12-24 16:09 | 只看該作者
我想問一下,跟著你連線可是按下按鍵還是沒反應(yīng)
