查看: 5602|回復: 9
有關雙CAN總線STM32F105系列例程源碼
ID:147641 發(fā)表于 2018-8-21 10:43 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這是我做的雙CAN總線例程,試驗通過。
單片機源程序如下:
  1. /*
  2.         CAN1
  3.         USART1
  4.     CAN波特率、收發(fā)器 配置見CAN.h
  5.         stm32f10x.h中修改了外部晶振值8MHz
  6. */
  7. /* Includes ------------------------------------------------------------------*/
  8. #include "stm32f10x.h"
  9. #include "stm32f10x_rcc.h"
  10. #include "stm32f10x_flash.h"
  11. #include "stm32f10x_can.h"
  12. #include "usart.h"
  13. #include "CAN.h"
  14. #include <stdio.h>
  15. void RCC_Configuration(void);
  16. void LED_Config(void);
  17. void Delay(__IO uint32_t nCount);
  18. CanTxMsg TxMsg1={0xAB,0,CAN_ID_STD,CAN_RTR_DATA,8,{0xAB,0,0,0,0,0,0,0}};
  19. CanTxMsg TxMsg2={0xCD,0,CAN_ID_STD,CAN_RTR_DATA,8,{0xCD,0,0,0,0,0,0,0}};
  20. int main(void)
  21. {
  22.
  23.   /* System Clocks Configuration **********************************************/
  24.   RCC_Configuration();
  25.   LED_Config();
  26.   // 串口配置
  27.   USART_Configuration();
  28.   USART_STR(USART2,"++++++++++++++++++++++++\r\n");
  29.   USART_STR(USART2,"  CAN Study Board\r\n");
  30.   USART_STR(USART2,"++++++++++++++++++++++++\r\n");
  31.
  32.
  33.   // CAN1 配置
  34.   CAN1_Config(SET_CAN_SJW,SET_CAN_BS1,SET_CAN_BS2,SET_CAN_PRES);
  35.
  36.   Delay(2000);
  37.
  38.   // CAN2 配置
  39.   CAN2_Config(SET_CAN_SJW,SET_CAN_BS1,SET_CAN_BS2,SET_CAN_PRES);
  40.
  41.
  42.   while (1)
  43.   {
  44.           GPIO_ResetBits(GPIOC,GPIO_Pin_0);
  45.           GPIO_SetBits(GPIOC,GPIO_Pin_1);
  46.           GPIO_SetBits(GPIOC,GPIO_Pin_14);
  47.           GPIO_SetBits(GPIOC,GPIO_Pin_15);
  48.       Delay(5000);
  49.           Delay(5000);
  50.           GPIO_SetBits(GPIOC,GPIO_Pin_0);
  51.           GPIO_ResetBits(GPIOC,GPIO_Pin_1);
  52.           GPIO_SetBits(GPIOC,GPIO_Pin_14);
  53.           GPIO_SetBits(GPIOC,GPIO_Pin_15);
  54.           CAN_SendData(CAN1,&TxMsg1);
  55.           Delay(5000);
  56.           Delay(5000);
  57.           GPIO_SetBits(GPIOC,GPIO_Pin_0);
  58.           GPIO_SetBits(GPIOC,GPIO_Pin_1);
  59.           GPIO_ResetBits(GPIOC,GPIO_Pin_14);
  60.           GPIO_SetBits(GPIOC,GPIO_Pin_15);
  61.           Delay(5000);
  62.           Delay(5000);
  63.           GPIO_SetBits(GPIOC,GPIO_Pin_0);
  64.           GPIO_SetBits(GPIOC,GPIO_Pin_1);
  65.           GPIO_SetBits(GPIOC,GPIO_Pin_14);
  66.           GPIO_ResetBits(GPIOC,GPIO_Pin_15);
  67.           Delay(5000);
  68.           Delay(5000);
  69.
  70.           CAN_SendData(CAN2,&TxMsg2);
  71.   }
  72. }
  73. void RCC_Configuration(void)
  74. {
  75.   /* Setup the microcontroller system. Initialize the Embedded Flash Interface,
  76.      initialize the PLL and update the SystemFrequency variable. */
  77.   SystemInit();
  78.
  79. }
  80. void Delay(__IO uint32_t nCount)
  81. {
  82.     uint8_t x;
  83.     for(; nCount != 0; nCount--)
  84.             for(x=0;x<100;x++);
  85. }
  86. void LED_Config(void)
  87. {
  88.   GPIO_InitTypeDef GPIO_InitStructure;
  89.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  90.
  91.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_14|GPIO_Pin_15;
  92.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  93.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  94.   GPIO_Init(GPIOC, &GPIO_InitStructure);
  95. }
  96. #ifdef  USE_FULL_ASSERT
  97. /**
  98.   * @brief  Reports the name of the source file and the source line number
  99.   *   where the assert_param error has occurred.
  100.   * @param  file: pointer to the source file name
  101.   * @param  line: assert_param error line source number
  102. ……………………
  103. …………限于本文篇幅 余下代碼請從51黑下載附件…………
復制代碼
STM32_CAN500K USART_LED.rar (458.73 KB, 下載次數(shù): 188)
ID:243168 發(fā)表于 2018-8-23 10:34 | 只看該作者
好東西,謝謝分享
ID:446581 發(fā)表于 2019-2-13 10:03 | 只看該作者
謝謝分享
ID:47548 發(fā)表于 2019-5-5 16:53 | 只看該作者
可以發(fā)送下嗎
905036191@qq.com
謝謝
ID:158966 發(fā)表于 2019-7-29 15:49 | 只看該作者
謝謝分享
ID:158966 發(fā)表于 2019-7-29 16:34 | 只看該作者
初學者,樓主可以分享嗎
457268908@qq.com
謝謝
ID:118473 發(fā)表于 2019-7-29 21:01 | 只看該作者
不錯不錯   .
ID:231807 發(fā)表于 2020-3-26 22:40 | 只看該作者
好東西,謝謝分享
ID:86450 發(fā)表于 2020-4-10 09:04 | 只看該作者
好東西,謝謝分享
ID:703927 發(fā)表于 2020-4-10 10:19 | 只看該作者
好東西
Powered by 單片機教程網
