查看: 3330|回復(fù): 1
單片機(jī)四位數(shù)碼模塊時(shí)鐘驅(qū)動(dòng)程序
制作出來的實(shí)物圖如下:
  1. 之前的程序是倒計(jì)時(shí)的,現(xiàn)在改成了向前走時(shí)了,經(jīng)過反復(fù)的比對(duì)時(shí)間,時(shí)鐘準(zhǔn)確了。/*************************************************************
  2. ****     Time: 2018.08.21
  3. ********************************/
  4. #include <reg52.h>
  5. #include<intrins.h>
  6. sbit CLK = P2^0;  //時(shí)鐘信號(hào)
  7. sbit DIO = P2^1;  //數(shù)據(jù)/地址數(shù)據(jù)
  8. unsigned char code SEGData[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};//共陰極數(shù)碼管1-9
  9. unsigned char code SEGDataDp[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef}; //有小數(shù)點(diǎn)只用于地址0xc1
  10. unsigned char dpFlag = 0; //控制第二個(gè)數(shù)碼管的dp的顯示
  11. void TM1637_start( void );
  12. void TM1637_stop( void );
  13. void TM1637_write1Bit(unsigned char mBit);
  14. void TM1637_write1Byte(unsigned char mByte);
  15. void TM1637_writeCammand(unsigned char mData);
  16. void TM1637_writeData(unsigned char addr, unsigned char mData);
  17. void time_set(char hour, char min);
  18. void time_judge( void );
  19. void time_display( void );
  20. void timer0_init( void );
  21. void delay_140us( void );
  22. unsigned int countTime = 0;
  23. unsigned char time, sec;
  24. struct {
  25.         char shi;
  26.         char ge;
  27. }Hour;
  28. struct {
  29.         char shi;
  30.         char ge;
  31. }Min;
  32. /***********************************************************
  33. *****
  34. ***** 主函數(shù)
  35. *****
  36. ***********************************************************/
  37. void main( void )
  38. {
  39.         timer0_init();
  40.         time_set(23, 59);  //設(shè)置5小時(shí)倒計(jì)時(shí)
  41.         while(1)
  42.         {
  43.                 time_display();         //顯示時(shí)間
  44.                 if(countTime <= 10)
  45.                 {
  46.                         dpFlag = 0;
  47.                 }
  48.                 else
  49.                 if(countTime <= 20)
  50.                 {
  51.                         dpFlag = 1;
  52.                 }
  53.                 else
  54.                 {
  55.                         countTime = 0;
  56.                         time_judge();
  57.                 }
  58.         }
  59. }
  60. /********************************************************************
  61. * 名稱 : void time_set(char hour, char min)
  62. * 功能 : 設(shè)置時(shí)間
  63. * 輸入 : char hour, char min
  64. * 輸出 : 無
  65. **************************************************************/
  66. void time_set(char hour, char min)
  67. {
  68.         if((hour < 0) || (min<0))
  69.         {
  70.                 hour = 0;
  71.                 min = 0;
  72.         }
  73.         Hour.shi = hour/10;
  74.         Hour.ge = hour%10;
  75.         Min.shi = min/10;
  76.         Min.ge = min%10;
  77. }
  78. /*************************************************************
  79. * 名稱 : time_judge( void )
  80. * 功能 : 判斷時(shí)間變化
  81. * 輸入 : void
  82. * 輸出 : 無
  83. **************************************************************/
  84. void time_judge( void )
  85. {
  86.                  sec++;
  87.                 if(sec>=60)
  88.        {
  89.         sec=0;
  90.         Min.ge ++;
  91.         }
  92.                 if(Min.ge>=10)
  93.        {
  94.          Min.ge=0;
  95.          Min.shi++;
  96.                 }
  97.                    if(Min.shi>=6)
  98.        {
  99.          Min.ge=0;
  100.                  Min.shi=0;
  101.          Hour.ge++;
  102.                 }
  103.                 if(Hour.ge>=10)
  104.        {
  105.          Hour.ge=0;
  106.          Hour.shi++;
  107.                 }
  108.                 if((Hour.shi>=2) &&(Hour.ge>=4) )
  109.        {
  110.              sec=0;
  111.                  Min.ge        =0;
  112.              Min.shi=0;
  113.              Hour.ge=0;
  114.          Hour.shi=0;
  115.                 }
  116. }
  117. /********************************************************************
  118. * 名稱 : void time_display( void )
  119. * 功能 : 顯示時(shí)間
  120. * 輸入 : void
  121. * 輸出 : 無
  122. **************************************************************/
  123. void time_display( void )
  124. {
  125.         TM1637_writeCammand(0x44);
  126.         TM1637_writeData(0xc0, SEGData[Hour.shi]);
  127.         if(dpFlag)
  128.                 TM1637_writeData(0xc1, SEGDataDp[Hour.ge]); //小數(shù)點(diǎn)標(biāo)志為1則用小數(shù)點(diǎn)那個(gè)數(shù)組
  129.         else
  130.                 TM1637_writeData(0xc1, SEGData[Hour.ge]);
  131.         TM1637_writeData(0xc2, SEGData[Min.shi]);
  132.         TM1637_writeData(0xc3, SEGData[Min.ge]);
  133.         TM1637_writeCammand(0x8a);
  134. }
  135. /********************************************************************
  136. * 名稱 : void TM1637_start( void )
  137. * 功能 : start信號(hào)
  138. * 輸入 : void
  139. * 輸出 : 無
  140. **************************************************************/
  141. void TM1637_start( void )
  142. {
  143.         CLK = 1;
  144.         DIO = 1;
  145.         delay_140us();
  146.         DIO = 0;
  147.         delay_140us();
  148.         CLK = 0;
  149.         delay_140us();
  150. }
  151. /********************************************************************
  152. * 名稱 : void TM1637_stop( void )
  153. * 功能 : stop信號(hào)
  154. * 輸入 : void
  155. * 輸出 : 無
  156. **************************************************************/
  157. void TM1637_stop( void )
  158. {
  159.         CLK = 0;
  160.         delay_140us();
  161.         DIO = 0;
  162.         delay_140us();
  163.         CLK = 1;
  164.         delay_140us();
  165.         DIO = 1;
  166.         delay_140us();
  167. }
  168. /********************************************************************
  169. * 名稱 : void TM1637_write1Bit(unsigned char mBit )
  170. * 功能 : 寫1bit
  171. * 輸入 : unsigned char mBit
  172. * 輸出 : 無
  173. **************************************************************/
  174. void TM1637_write1Bit(unsigned char mBit )
  175. {
  176.         CLK = 0;
  177.         delay_140us();
  178.         if(mBit)
  179.                 DIO = 1;
  180.         else
  181.                 DIO = 0;
  182.         delay_140us();
  183.         CLK        = 1;
  184.         delay_140us();
  185. }
  186. /********************************************************************
  187. * 名稱 : void TM1637_write1Byte(unsigned char mByte)
  188. * 功能 : 寫1byte
  189. * 輸入 : unsigned char mByte
  190. * 輸出 : 無
  191. **************************************************************/
  192. void TM1637_write1Byte(unsigned char mByte)
  193. {
  194.         char loop = 0;
  195.         for(loop = 0; loop < 8; loop++)
  196.         {
  197.                 TM1637_write1Bit((mByte>>loop)&0x01); //取得最低位
  198.         }
  199.         CLK = 0;
  200.         delay_140us();
  201.         DIO = 1;
  202.         delay_140us();
  203.         CLK = 1;
  204.         delay_140us();
  205.         while(DIO == 1);  //獲得應(yīng)答位
  206. }
  207. /********************************************************************
  208. * 名稱 : void TM1637_writeCammand(unsigned char mData)
  209. * 功能 : 寫指令1byte
  210. * 輸入 : unsigned char mData
  211. * 輸出 : 無
  212. **************************************************************/
  213. void TM1637_writeCammand(unsigned char mData)
  214. {
  215.         TM1637_start();
  216.         TM1637_write1Byte(mData);  //數(shù)據(jù)
  217.         TM1637_stop();
  218. }
  219. /********************************************************************
  220. * 名稱 : void TM1637_writeData(unsigned char addr, unsigned char mData)
  221. * 功能 : 固定地址寫數(shù)據(jù)1byte
  222. * 輸入 : unsigned char addr, unsigned char mData
  223. * 輸出 : 無
  224. **************************************************************/
  225. void TM1637_writeData(unsigned char addr, unsigned char mData)
  226. {
  227.         TM1637_start();
  228.         TM1637_write1Byte(addr);  //地址
  229.         TM1637_write1Byte(mData);  //數(shù)據(jù)
  230.         TM1637_stop();
  231. }
  232. /********************************************************************
  233. **************************************************************/
  234. void timer0_init( void )
  235. {
  236.         TMOD=0X01;
  237.         TH0=(65536-35000)/256;
  238.         TL0=(65536-35000)%256;
  239.         ET0=1;
  240.         EA=1;
  241.         TR0=1;
  242. }
TM1637.rar (33.18 KB, 下載次數(shù): 23)
ID:402417 發(fā)表于 2018-12-5 17:41 | 只看該作者
感謝感謝感謝
