利用stm32與串口屏通訊
工程路徑為..\STM32\DCDEMO7\RVMDK\DCDEMO7.uvproj ,請(qǐng)用KEIL4(MDK4)以上版本打開(kāi)
- #include "hmi_driver.h"
- #include "hmi_user_uart.h"
- #include "cmd_queue.h"
- #include "cmd_process.h"
- #include "stdio.h"
- #include "hw_config.h"
- #include "ulitity.h"
- #include "string.h"
- #include "rtc.h"
- #include "stm32f10x_bkp.h"
- #include "stm32f10x_rtc.h"
- #include "stm32f10x_pwr.h"
- //#include "key_IN.h"
- #define TIME_100MS 10 //100毫秒(10個(gè)單位)
- volatile uint32 timer_tick_count = 0; //定時(shí)器節(jié)拍
- uint8 cmd_buffer[CMD_MAX_SIZE]; //指令緩存
- static uint16 current_screen_id = 0; //當(dāng)前畫(huà)面ID
- static int32 test_value = 0; //測(cè)試值
- static uint8 update_en = 0; //更新標(biāo)記
- static int32 meter_flag = 0; //儀表指針往返標(biāo)志位
- static int32 num = 0; //曲線采樣點(diǎn)計(jì)數(shù)
- static uint8 sec = 1; //時(shí)間秒
- static int32 curves_type = 0; //曲線標(biāo)志位 0為正弦波,1為鋸齒波
- static int32 second_flag=0; //時(shí)間標(biāo)志位
- static int32 Progress_Value = 0; //進(jìn)度條的值
- static int32 icon_flag = 0; //圖標(biāo)標(biāo)志位
- //int32 key_flag = 0;
- static uint16 screenid = 0;
- extern uint32 OP_XGUS;
- int t1 = 5;
- void UpdateUI(void); //更新UI數(shù)據(jù)
- void picxdisp(uchar n,int x1,int y1,int x2,int y2) ;
- * \brief 程序入口
- int main()
- uint32 timer_tick_last_update = 0; //上一次更新的時(shí)間
- qsize size = 0;
- //int PRESS ;
- //配置時(shí)鐘
- Set_System();
- //配置串口中斷
- Interrupts_Config();
- //配置時(shí)鐘節(jié)拍
- systicket_init();
- // KEY_Init();
- RTC_int();
- //串口初始化
- Uart2Init(9600);
- UartInit(9600);
- //清空串口接收緩沖區(qū)
- queue_reset();
- //延時(shí)等待串口屏初始化完畢,必須等待300ms
- delay_ms(300);
- while(1)
- size = queue_find_cmd(cmd_buffer,CMD_MAX_SIZE); //從緩沖區(qū)中獲取一條指令
- if(size>0&&cmd_buffer[1]!=0x07)//接收到指令
- ProcessMessage((PCTRL_MSG)cmd_buffer, size);//指令處理
- /*PRESS = KEY_Scan();
- switch(PRESS)
- case 1 :
- while(key_flag)
- KEY_Scan();
- SetScreen(screenid);
- screenid++;
- break;
- case 2 :
- screenid -= 1;
- break;
- case 3 :
- screenid += 1;
- break;
- * \brief 消息處理流程
- * \param msg 待處理消息
- * \param size 消息長(zhǎng)度
- void ProcessMessage( PCTRL_MSG msg, uint16 size )
- uint8 cmd_type = msg->cmd_type; //指令類(lèi)型
- uint8 ctrl_msg = msg->ctrl_msg; //消息的類(lèi)型
- uint8 control_type = msg->control_type; //控件類(lèi)型
- uint16 screen_id = PTR2U16(&msg->screen_id); //畫(huà)面ID
- uint16 control_id = PTR2U16(&msg->control_id); //控件ID
- uint32 value = PTR2U32(msg->param); //數(shù)值
- switch(cmd_type)
- case NOTIFY_TOUCH_PRESS: //觸摸屏按下
- case NOTIFY_TOUCH_RELEASE: //觸摸屏松開(kāi)
- NotifyTouchXY(cmd_buffer[1],PTR2U16(cmd_buffer+2),PTR2U16(cmd_buffer+4));
- break;
- case NOTIFY_WRITE_FLASH_OK: //寫(xiě)FLASH成功
- NotifyWriteFlash(1);
- break;
- case NOTIFY_WRITE_FLASH_FAILD: //寫(xiě)FLASH失敗
- NotifyWriteFlash(0);
- break;
- case NOTIFY_READ_FLASH_OK: //讀取FLASH成功
- NotifyReadFlash(1,cmd_buffer+2,size-6); //去除幀頭幀尾
- break;
- case NOTIFY_READ_FLASH_FAILD: //讀取FLASH失敗
- NotifyReadFlash(0,0,0);
- break;
- case NOTIFY_READ_RTC: //讀取RTC時(shí)間
- NotifyReadRTC(cmd_buffer[2],cmd_buffer[3],cmd_buffer[4],cmd_buffer[5],cmd_buffer[6],cmd_buffer[7],cmd_buffer[8]);
- break;
- case NOTIFY_CONTROL:
- if(ctrl_msg==MSG_GET_CURRENT_SCREEN) //畫(huà)面ID變化通知
- NotifyScreen(screen_id); //畫(huà)面切換調(diào)動(dòng)的函數(shù)
- else
- switch(control_type)
- case kCtrlButton: //按鈕控件
- NotifyButton(screen_id,control_id,msg->param[1]);
- break;
- case kCtrlText: //文本控件
- NotifyText(screen_id,control_id,msg->param);
- break;
- case kCtrlProgress: //進(jìn)度條控件
- NotifyProgress(screen_id,control_id,value);
- break;
- case kCtrlSlider: //滑動(dòng)條控件
- NotifySlider(screen_id,control_id,value);
- break;
- case kCtrlMeter: //儀表控件
- NotifyMeter(screen_id,control_id,value);
- break;
- case kCtrlMenu: //菜單控件
- NotifyMenu(screen_id,control_id,msg->param[0],msg->param[1]);
- break;
- case kCtrlSelector: //選擇控件
- NotifySelector(screen_id,control_id,msg->param[0]);
- break;
- case kCtrlRTC: //倒計(jì)時(shí)控件
- NotifyTimer(screen_id,control_id);
- break;
- default:
- break;
- break;
- default:
- break;
- * \brief 畫(huà)面切換通知
- * \details 當(dāng)前畫(huà)面改變時(shí)(或調(diào)用GetScreen),執(zhí)行此函數(shù)
- * \param screen_id 當(dāng)前畫(huà)面ID
- void NotifyScreen(uint16 screen_id)
- //TODO: 添加用戶代碼
- //在工程配置中開(kāi)啟畫(huà)面切換通知,記錄當(dāng)前畫(huà)面ID
- //進(jìn)到二維碼頁(yè)面生成二維碼
- * \brief 觸摸坐標(biāo)事件響應(yīng)
- * \param press 1按下觸摸屏,3松開(kāi)觸摸屏
- * \param x x坐標(biāo)
- * \param y y坐標(biāo)
- void NotifyTouchXY(uint8 press,uint16 x,uint16 y)
- * \brief 更新數(shù)據(jù)
- void UpdateUI()
- * \brief 按鈕控件通知
- * \details 當(dāng)按鈕狀態(tài)改變(或調(diào)用GetControlValue)時(shí),執(zhí)行此函數(shù)
- * \param screen_id 畫(huà)面ID
- * \param control_id 控件ID
- * \param state 按鈕狀態(tài):0彈起,1按下
- void NotifyButton(uint16 screen_id, uint16 control_id, uint8 state)
- if(screen_id == 0)
- if(control_id==32)
- GetControlValue(0,26);
- if(control_id==33)
- GetControlValue(0,10);
- if(control_id==34)
- GetControlValue(0,22);
- if(control_id==37)
- GetControlValue(0,25);
- if(control_id==35)
- screenid -= 1;
- if(control_id==36)
- screenid += 1;
- * \brief 文本控件通知
- * \details 當(dāng)文本通過(guò)鍵盤(pán)更新(或調(diào)用GetControlValue)時(shí),執(zhí)行此函數(shù)
- * \param str 文本控件內(nèi)容
- void NotifyText(uint16 screen_id, uint16 control_id, uint8 *str)
- int32 value=0;
- int32 zalue;
- sscanf(str,"%ld",&value); //把字符串轉(zhuǎn)換為整數(shù)
- UnlockDeviceConfig();
- if(screen_id==0) //畫(huà)面ID2:文本設(shè)置和顯示
- if(control_id==26) //最高電壓
- //限定數(shù)值范圍(也可以在文本控件屬性中設(shè)置)
- switch(value)
- case 2400:
- zalue=1;
- SetCommBps(zalue);
- UartInit(2400);
- SetTextInt32(0,41,zalue,0,1);
- break;
- case 4800:
- zalue=2;
- UartInit(4800);
- break;
- case 9600:
- zalue=3;
- UartInit(9600);
- break;
- case 19200:
- zalue=4;
- UartInit(19200);
- break;
- case 38400:
- zalue=5;
- UartInit(38400);
- break;
- case 57600:
- zalue=6;
- UartInit(57600);
- break;
- case 115200:
- zalue=7;
- UartInit(115200);
- break;
- LockDeviceConfig();
- * \brief 進(jìn)度條控件通知
- * \details 調(diào)用GetControlValue時(shí),執(zhí)行此函數(shù)
- * \param value 值
- void NotifyProgress(uint16 screen_id, uint16 control_id, uint32 value)
- * \brief 滑動(dòng)條控件通知
- * \details 當(dāng)滑動(dòng)條改變(或調(diào)用GetControlValue)時(shí),執(zhí)行此函數(shù)
- * \param value 值
- void NotifySlider(uint16 screen_id, uint16 control_id, uint32 value)
- * \brief 儀表控件通知
- * \param value 值
- void NotifyMeter(uint16 screen_id, uint16 control_id, uint32 value)
- //TODO: 添加用戶代碼
- * \brief 菜單控件通知
- * \details 當(dāng)菜單項(xiàng)按下或松開(kāi)時(shí),執(zhí)行此函數(shù)
- * \param item 菜單項(xiàng)索引
- * \param state 按鈕狀態(tài):0松開(kāi),1按下
- void NotifyMenu(uint16 screen_id, uint16 control_id, uint8 item, uint8 state)
- //TODO: 添加用戶代碼
- * \brief 選擇控件通知
- * \details 當(dāng)選擇控件變化時(shí),執(zhí)行此函數(shù)
- * \param item 當(dāng)前選項(xiàng)
- void NotifySelector(uint16 screen_id, uint16 control_id, uint8 item)
- * \brief 定時(shí)器超時(shí)通知處理
- void NotifyTimer(uint16 screen_id, uint16 control_id)
- //TODO: 添加用戶代碼
- * \brief 讀取用戶FLASH狀態(tài)返回
- * \param status 0失敗,1成功
- * \param _data 返回?cái)?shù)據(jù)
- * \param length 數(shù)據(jù)長(zhǎng)度
- void NotifyReadFlash(uint8 status,uint8 *_data,uint16 length)
- //TODO: 添加用戶代碼
- * \brief 寫(xiě)用戶FLASH狀態(tài)返回
- void NotifyWriteFlash(uint8 status)
- //TODO: 添加用戶代碼
- * \brief 讀取RTC時(shí)間,注意返回的是BCD碼
- * \param year 年(BCD)
- * \param month 月(BCD)
- * \param week 星期(BCD)
- * \param day 日(BCD)
- * \param hour 時(shí)(BCD)
- * \param minute 分(BCD)
- * \param second 秒(BCD)
- void NotifyReadRTC(uint8 year,uint8 month,uint8 week,uint8 day,uint8 hour,uint8 minute,uint8 second)
- //sec =(0xff & (second>>4))*10 +(0xf & second); //BCD碼轉(zhuǎn)十進(jìn)制
液晶屏測(cè)試工裝程序.rar
(379.37 KB, 下載次數(shù): 76)
2018-8-27 18:28 上傳
點(diǎn)擊文件名下載附件
