查看: 5257|回復(fù): 4
stm32定時(shí)器1PWM控制PA8,定時(shí)器3控制PD2
ID:267583 發(fā)表于 2018-8-27 22:14 | 顯示全部樓層 |閱讀模式
兩個(gè)定時(shí)器同時(shí)打開,pwm不工作,單獨(dú)都可以工作,單步運(yùn)行到紅色字體處出現(xiàn)問題,沒有弄明白請大神幫忙看一下,
定時(shí)器3初始化u16 time_ms=0;
u16 USART1_Heartbeat_time=0;
*            函數(shù)
void time3_init(u16 arr,u16 psc)
                                TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
                                NVIC_InitTypeDef NVIC_InitStructure;
                                RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //時(shí)鐘使能
                                TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)置在下一個(gè)更新事件裝入活動的自動重裝載寄存器周期的值         計(jì)數(shù)到5000為500ms
                                TIM_TimeBaseStructure.TIM_Prescaler =psc; //設(shè)置用來作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值  10Khz的計(jì)數(shù)頻率
                                TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
                                TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計(jì)數(shù)模式
                                TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
                                TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);          //使能指定的TIM2中斷,允許更新中斷
                                NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;  //TIM3中斷
                                NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 3;  //先占優(yōu)先級0級
                                NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3;  //從優(yōu)先級3級
                                NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
                                NVIC_Init(&NVIC_InitStructure);  //根據(jù)NVIC_InitStruct中指定的參數(shù)初始化外設(shè)NVIC寄存器
                                TIM_Cmd(TIM3,ENABLE);                        //使能TIM3定時(shí)器
                                TIM_ClearITPendingBit(TIM3, TIM_IT_Update);  //清除TIMx更新中斷標(biāo)志
//時(shí)間10ms
void TIM3_IRQHandler(void)   //TIM3中斷
        if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //檢查指定的TIM中斷發(fā)生與否:TIM 中斷源
                        TIM_ClearITPendingBit(TIM3, TIM_IT_Update  );  //清除TIMx的中斷待處理位:TIM 中斷源
                        time_ms++;
                        USART1_Heartbeat_time++;               //心跳定時(shí)器
                        if(LED_Red.LED_Start_Flash_Flag==1)    //指示燈定時(shí)器
                                LED_Red.LED_Start_Flash_time++;
                          LED_Red.LED_Start_Flash_Flag=0;
                          LED_Red.LED_Start_Flash_time=0;
                        if(LED_Green.LED_Start_Flash_Flag==1) //指示燈定時(shí)器
                          LED_Green.LED_Start_Flash_time++;
                                LED_Green.LED_Start_Flash_Flag=0;
                                LED_Green.LED_Start_Flash_time=0;
                        if(((USART1_Heartbeat_time>=500)&&(USART1_Heartbeat_flag==0)))//串口1心跳
                         printf("\r\n @@@Heartbeat@@@ \n");;
定時(shí)器1pwm初始化
void TIM1_PWM_Init(u16 arr,u16 psc)
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);//
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_AFIO, ENABLE);  //使能GPIO外設(shè)和AFIO復(fù)用功能模塊時(shí)鐘
   //設(shè)置該引腳為復(fù)用輸出功能,輸出TIM1 CH1的PWM脈沖波形
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //TIM_CH1
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //復(fù)用推挽輸出
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)置在下一個(gè)更新事件裝入活動的自動重裝載寄存器周期的值         80K
        TIM_TimeBaseStructure.TIM_Prescaler =psc; //設(shè)置用來作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值  不分頻
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //選擇定時(shí)器模式:TIM脈沖寬度調(diào)制模式2
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
        TIM_OCInitStructure.TIM_Pulse = 0; //設(shè)置待裝入捕獲比較寄存器的脈沖值
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //輸出極性:TIM輸出比較極性高
        TIM_OC1Init(TIM1, &TIM_OCInitStructure);  //根據(jù)TIM_OCInitStruct中指定的參數(shù)初始化外設(shè)TIMx
  TIM_CtrlPWMOutputs(TIM1,ENABLE);        //MOE 主輸出使能
        TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);  //CH1預(yù)裝載使能
        TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的預(yù)裝載寄存器
        TIM_Cmd(TIM1, ENABLE);  //使能TIM1
ID:267583 發(fā)表于 2018-8-27 22:29 | 顯示全部樓層
初始化必須定時(shí)器1必須在前定時(shí)器3在后
ID:535879 發(fā)表于 2019-7-22 17:57 | 顯示全部樓層
樓主還有源代碼么,能分享一下
ID:363565 發(fā)表于 2020-3-25 11:56 | 顯示全部樓層
解決了嗎,貌似沒有執(zhí)行引腳復(fù)用呀  GPIO_PinRemapConfig(GPIO_FullRemap_TIM1, ENABLE);
我是怎樣都不行呀,用PA3來輸出PWM還好好的
ID:519660 發(fā)表于 2020-4-26 13:35 | 顯示全部樓層
同樣的問題  怎么解決啊
