查看: 4189|回復: 2
arduino 3路PWM輸出
ID:390878 發(fā)表于 2018-8-28 17:03 | 顯示全部樓層 |閱讀模式
輸出的功能是:有加速鍵,減速鍵,啟動停止,按下啟動一個點擊先啟動5秒后第二個電機啟動,按下停止后兩個電機同時停止。
#include <MsTimer2.h>
#include <EEPROM.h>
#define STOP 255
int key1=1;
int key2=2;
int key3=3;
int key4=4;
int btn_start=2;
int btn_stop=3;
int btn_speedup=4;
int btn_speeddown=7;
int pwm1=5;
int pwm2=6;
int pwm3=9;
int pwm4=10;
byte  speed_;
byte delay_ms;
bool flag_btn1;
void setup()
// delay(100);
   pinMode(3,INPUT_PULLUP);
   pinMode(4,INPUT_PULLUP);
   pinMode(2,INPUT_PULLUP);
    pinMode(7,INPUT_PULLUP);
    pinMode(8,INPUT_PULLUP);
    pinMode(12,INPUT_PULLUP);
    pinMode(pwm1,OUTPUT);
    pinMode(pwm2,OUTPUT);
    pinMode(pwm3,OUTPUT);
    pinMode(pwm4,OUTPUT);
    pinMode(9,OUTPUT);//PWM3
    Serial.begin(9600);
   delay_ms=EEPROM.read(1);
    MsTimer2::set((int)delay_ms*100, onTimer); //設(shè)置中斷,每1000ms進入一次中斷服務(wù)程序 onTimer()
  //////////////////////////////////////2-啟動   3-停止 4-加速  5-減速
  speed_=EEPROM.read(0);
   attachInterrupt( digitalPinToInterrupt(2), start_all, FALLING);
   attachInterrupt( digitalPinToInterrupt(3), stop_all, FALLING);
  analogWrite(5,STOP);
  analogWrite(6,STOP);
   analogWrite(9,STOP);
  Serial.println(speed_);
  Serial.println(delay_ms*100);
  delay(100);
  flag_btn1=false;
///////////////////////////全部停止
void speed_up()
    if(speed_<=245)
      speed_+=10;
    analogWrite(6,speed_);
   analogWrite(5,speed_);
    analogWrite(9,speed_);
   delay(100);
   while(!digitalRead(4));
void speed_down()
    if(speed_>=10)
      speed_-=10;
      speed_=0;
   delay(100);
   while(!digitalRead(7));
void stop_all()
      flag_btn1=false;
   delay(100);
   while(!digitalRead(3));
///////////////////////////全部啟動
void start_all()
  flag_btn1=true;
    MsTimer2::start();
   delay(100);
   while(!digitalRead(2));
void onTimer()
  MsTimer2::stop();
//  Serial.print("timer ");
//  Serial.println(tick++);
void loop()
   if(digitalRead(4)==LOW)
         if(speed_<=245)
            speed_=speed_+10;
            speed_=255;
         EEPROM.write(0, speed_);
         delay(100);
         while(digitalRead(4)==LOW);
    if(digitalRead(7)==LOW)
        if(speed_>=10)
           speed_=speed_-10;
           speed_=0;
       delay(100);
       while(digitalRead(7)==LOW);
if(digitalRead(8)==LOW)
      if(delay_ms<50)
        delay_ms++;
       delay_ms=50;
       MsTimer2::set(delay_ms*100, onTimer);
       EEPROM.write(1, delay_ms);
       delay(100);
       while(digitalRead(8)==LOW);
if(digitalRead(12)==LOW)
      if(delay_ms>1)
      delay_ms--;
        delay_ms=0;
       delay(100);
       while(digitalRead(12)==LOW);
ID:312827 發(fā)表于 2018-9-21 11:18 | 顯示全部樓層
sketch_sep21a.cpp: In function 'void loop()':
sketch_sep21a:146: error: 'MsTimer2' has not been declared
sketch_sep21a:158: error: 'MsTimer2' has not been declared
ID:389836 發(fā)表于 2018-12-2 17:49 來自手機 | 顯示全部樓層
上面兩個庫是自帶的還是需要下載的?
