首選需要連接串口,之后就可以進(jìn)行傳輸數(shù)據(jù)操作,
界面圖形化,非常容易上手,源碼都在里面了,有需要的話
串口連接
2018-9-6 15:26 上傳
可以學(xué)習(xí)一下源碼- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.Linq;
- using System.Text;
- using System.Threading.Tasks;
- using System.Windows.Forms;
- using System.IO.Ports;
- using ZedGraph;
- using System.Threading;
- using System.Collections;
- namespace DC_POWER
- public partial class Mainform : Form
- private const float VOLTAGE_MAX = 30.00f, CURRENT_MAX = 4.000f;
- public enum MODE
- MODE_VOLTAGE = 0x00,
- MODE_CURRENT = 0x01,
- private MODE currentMode = MODE.MODE_VOLTAGE;
- //與下位機(jī)通訊相關(guān)
- public enum COM_CMD
- //M2S: master to slave cmd, S2M: slave to master
- USART_M2S_Output = 0x01, //輸出控制(默認(rèn)關(guān))
- USART_M2S_Mode = 0x02, //輸出模式切換(默認(rèn)電壓模式)
- USART_M2S_SetVal = 0x03, //Master2Slave設(shè)置期望值:[1-4]:電壓; [5-8]:電流
- USART_M2S_Cal = 0x04, //進(jìn)入校準(zhǔn)模式(只在下位機(jī)開機(jī)前幾秒內(nèi)能夠進(jìn)入校準(zhǔn)模式)
- USART_M2S_StepAdd = 0x05, //步進(jìn)加
- USART_M2S_StepSub = 0x06, //步進(jìn)減
- USART_M2S_FAN = 0x07, //風(fēng)扇控制:[1]0關(guān);1開;2自動(默認(rèn))
- USART_M2S_STATE = 0x08, //實時數(shù)據(jù)發(fā)送狀態(tài):[1]1發(fā)送數(shù)據(jù) 0停止發(fā)送
- USART_M2S_GetVal = 0x09, //獲取前一次的設(shè)定值
- USART_S2M_PreVal = 0x0A, //Slave2Master返回前一次的設(shè)定值:[1-4]:電壓值; [5-8]:電流值
- USART_S2M_RealVal = 0x0B, //Slave2Master返回的實際值:[1-4]:電壓值; [5-8]:電流值
- USART_S2M_RealTemp= 0x0C, //Slave2Master返回溫度值:[1-4]:當(dāng)前溫度值
- private const byte USART_FRAMEHEAD = 0xAA, USART_FRAMETAIL = 0x55, USART_FRAMECTRL = 0xA5;
- private long m_TotalRxLostPackages = 0; //記錄總的丟包數(shù)
- private long m_RxPackageDataCount = 0; //記錄接收到的一幀的字節(jié)數(shù)
- private const int m_MaxPackageSize = 4096; //一幀最大的字節(jié)數(shù)
- private byte[] m_pRxBuf = new byte[m_MaxPackageSize]; //接收緩存
- float voltageSet = 0.0f, currentSet = 0.0f, voltageGet = 0.0f, currentGet = 0.0f;
- //繪圖相關(guān)
- public struct CurveStruct
- public PointPairList pointList;//曲線數(shù)據(jù)
- public Color lineColor;//曲線顏色
- public SymbolType lineStyle;//線型
- public string curveName;//名稱
- public LineItem curve; //曲線
- public float scaleFactor;//比例系數(shù)
- public byte lineWidth; //線寬
- private Hashtable curveHashTable = new Hashtable();//用來保存所有的曲線
- private GraphPane mGraphPane;
- private long tickStart = 0;
- double currentTime;
- //double previousTime = 0;
- CurveStruct mCurveStructVolSet = new CurveStruct();
- CurveStruct mCurveStructVolGet = new CurveStruct();
- CurveStruct mCurveStructCurSet = new CurveStruct();
- CurveStruct mCurveStructCurGet = new CurveStruct();
- //線程相關(guān)
- private Queue<byte> receiveByteQueue = new Queue<byte>();//串口緩存隊列
- private Thread _dataParseThread = null; //解析串口接收數(shù)據(jù)線程
- private bool _runDataParseThread = false; //決定接收線程是否退出
- public Mainform()
- InitializeComponent();
- private void Mainform_Load(object sender, EventArgs e)
- //初始化串口列表,添加本地可用串口號
- if (SerialPort.GetPortNames().Length != 0)
- foreach (string vPortName in SerialPort.GetPortNames())
- RibbonLabel item = new RibbonLabel();
- item.Text = vPortName;
- ribbonComboBoxCom1.DropDownItems.Add(item);
- ribbonComboBoxCom2.DropDownItems.Add(item);
- ribbonComboBoxCom1.TextBoxText = SerialPort.GetPortNames()[0];
- ribbonComboBoxCom2.TextBoxText = SerialPort.GetPortNames()[0];
- mGraphPane = zedGraphControl1.GraphPane;
- mGraphPane.Title.Text = "DC_POWER";
- //添加兩個Y軸,分別顯示電壓、電流
- mGraphPane.XAxis.Title.Text = "time";
- mGraphPane.YAxis.Title.Text = "Voltage";
- mGraphPane.Y2Axis.Title.Text = "Current";
- mGraphPane.Y2Axis.IsVisible = true;
- mGraphPane.YAxis.Scale.FontSpec.FontColor = Color.Red;
- mGraphPane.YAxis.Title.FontSpec.FontColor = Color.Red;
- mGraphPane.Y2Axis.Scale.FontSpec.FontColor = Color.Blue;
- mGraphPane.Y2Axis.Title.FontSpec.FontColor = Color.Blue;
- knob_Voltage.Enabled = false;
- knob_Current.Enabled = false;
- slideButtonMode.Enabled = false;
- slideButtonOutput.Enabled = false;
- glassButtonStepAdd.Enabled = false;
- glassButtonCAL.Enabled = false;
- glassButtonStepSub.Enabled = false;
- private void Mainform_FormClosing(object sender, FormClosingEventArgs e)
- if (serialPort1.IsOpen)
- ribbonButtonOpenCom1_Click(sender, e);
- if (serialPort2.IsOpen)
- ribbonButtonOpenCom2_Click(sender, e);
- private void ResetGraphPane()
- mGraphPane.XAxis.Scale.Min = 0; //X軸最小值0
- mGraphPane.XAxis.Scale.Max = 30; //X軸最大30
- mGraphPane.XAxis.Scale.MinorStep = 1;//X軸小步長1,也就是小間隔
- mGraphPane.XAxis.Scale.MajorStep = 5;//X軸大步長為5,也就是顯示文字的大間隔
- mGraphPane.YAxis.Scale.Min = 0; //電壓軸最小值0
- mGraphPane.YAxis.Scale.Max = VOLTAGE_MAX;//電壓最大值
- mGraphPane.Y2Axis.Scale.Min = 0; //電流軸最小值0
- mGraphPane.Y2Axis.Scale.Max = CURRENT_MAX;//電流最大值
- //清除原有曲線
- if (mGraphPane.CurveList.Count != 0)
- mGraphPane.CurveList.Clear();
- mGraphPane.GraphObjList.Clear();
- curveHashTable.Clear();
- //更新X和Y軸的范圍
- zedGraphControl1.AxisChange();
- //更新圖表
- zedGraphControl1.Invalidate();
- //添加四條新的曲線:電壓設(shè)定曲線、電壓實際曲線、電流設(shè)定曲線、實際電流曲線
- mCurveStructVolSet.curveName = "SET_V";
- mCurveStructVolSet.pointList = new PointPairList();
- mCurveStructVolSet.lineColor = Color.Brown;
- mCurveStructVolSet.lineStyle = SymbolType.None;
- mCurveStructVolSet.lineWidth = 2;
- mCurveStructVolSet.scaleFactor = 1;// 360.0f / 4000.0f;
- mCurveStructVolSet.curve = mGraphPane.AddCurve(
- mCurveStructVolSet.curveName,
- mCurveStructVolSet.pointList,
- mCurveStructVolSet.lineColor,
- mCurveStructVolSet.lineStyle);
- mCurveStructVolSet.curve.Line.Width = mCurveStructVolSet.lineWidth;
- curveHashTable.Add("SET_V", mCurveStructVolSet);
- mCurveStructVolGet.curveName = "GET_V";
- mCurveStructVolGet.pointList = new PointPairList();
- mCurveStructVolGet.lineColor = Color.Red;
- mCurveStructVolGet.lineStyle = SymbolType.None;
- mCurveStructVolGet.lineWidth = 2;
- mCurveStructVolGet.scaleFactor = 1;// 360.0f / 4000.0f;
- mCurveStructVolGet.curve = mGraphPane.AddCurve(
- mCurveStructVolGet.curveName,
- mCurveStructVolGet.pointList,
- mCurveStructVolGet.lineColor,
- mCurveStructVolGet.lineStyle);
- mCurveStructVolGet.curve.Line.Width = mCurveStructVolGet.lineWidth;
- curveHashTable.Add("GET_V", mCurveStructVolGet);
- mCurveStructCurSet.curveName = "SET_I";
- mCurveStructCurSet.pointList = new PointPairList();
- mCurveStructCurSet.lineColor = Color.DarkBlue;
- mCurveStructCurSet.lineStyle = SymbolType.None;
- mCurveStructCurSet.lineWidth = 2;
- mCurveStructCurSet.scaleFactor = 1;// 360.0f / 4000.0f;
- mCurveStructCurSet.curve = mGraphPane.AddCurve(
- mCurveStructCurSet.curveName,
- mCurveStructCurSet.pointList,
- mCurveStructCurSet.lineColor,
- mCurveStructCurSet.lineStyle);
- mCurveStructCurSet.curve.Line.Width = mCurveStructCurSet.lineWidth;
- curveHashTable.Add("SET_I", mCurveStructCurSet);
- mCurveStructCurSet.curve.IsY2Axis = true;
- mCurveStructCurGet.curveName = "GET_I";
- mCurveStructCurGet.pointList = new PointPairList();
- mCurveStructCurGet.lineColor = Color.Blue;
- mCurveStructCurGet.lineStyle = SymbolType.None;
- mCurveStructCurGet.lineWidth = 2;
- mCurveStructCurGet.scaleFactor = 1;// 360.0f / 4000.0f;
- mCurveStructCurGet.curve = mGraphPane.AddCurve(
- mCurveStructCurGet.curveName,
- mCurveStructCurGet.pointList,
- mCurveStructCurGet.lineColor,
- mCurveStructCurGet.lineStyle);
- mCurveStructCurGet.curve.Line.Width = mCurveStructCurGet.lineWidth;
- curveHashTable.Add("GET_I", mCurveStructCurGet);
- mCurveStructCurGet.curve.IsY2Axis = true;
- private void PrepareReceiveData()
- _dataParseThread = new Thread(new ThreadStart(DataParseThreadFunc));
- _runDataParseThread = true;
- private void StartReciveData()
- PrepareReceiveData();
- if (_dataParseThread != null)
- _dataParseThread.Start();
- private void StopReceiveData()
- _runDataParseThread = false;
- _dataParseThread.Abort();
- _dataParseThread = null;
- private void knob_Voltage_ValueChanged(object sender, EventArgs e)
- thermometerVoltage.Value = (float)knob_Voltage.Value / 10.0f;
- lbDigitalMeter_Voltage_Set.Value = (float)knob_Voltage.Value / 10.0f;
- float voltage = (float)lbDigitalMeter_Voltage_Set.Value;
- float current = (float)lbDigitalMeter_Current_Set.Value;
- byte[] data = new byte[9];
- data[0] = (byte)COM_CMD.USART_M2S_SetVal;
- for(int iter = 0; iter < 4; iter++)
- data[1+iter] = BitConverter.GetBytes(voltage)[iter];
- data[5+iter] = BitConverter.GetBytes(current)[iter];
- PackData2Frame(data);
- private void knob_Current_ValueChanged(object sender, EventArgs e)
- thermometerCurrent.Value = (float)knob_Current.Value / 100.0f;
- lbDigitalMeter_Current_Set.Value = (float)knob_Current.Value / 100.0f;
- for (int iter = 0; iter < 4; iter++)
- data[1 + iter] = BitConverter.GetBytes(voltage)[iter];
- data[5 + iter] = BitConverter.GetBytes(current)[iter];
- private void slideButtonOutput_Click(object sender, EventArgs e)
- if (labelOutput.Text == "OFF")
- labelOutput.Text = "ON";
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_Output});//開輸出
- Thread.Sleep(10);
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_STATE, 0x01 });//開始發(fā)送數(shù)據(jù)
- //開始接收數(shù)據(jù)
- tickStart = Environment.TickCount;
- StartReciveData();
- else
- labelOutput.Text = "OFF";
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_Output });//關(guān)輸出
- Thread.Sleep(10);
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_STATE, 0x00 });//停止發(fā)送數(shù)據(jù)
- //停止接收數(shù)據(jù)
- StopReceiveData();
- private void slideButtonMode_Click(object sender, EventArgs e)
- if(currentMode == MODE.MODE_VOLTAGE)
- labelMode.Text = "Mode: A";
- currentMode = MODE.MODE_CURRENT;
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_Mode, 0x01});//電流模式
- else
- labelMode.Text = "Mode: V";
- currentMode = MODE.MODE_VOLTAGE;
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_Mode, 0x00});//電壓模式
- private void ribbonButtonOpenCom1_Click(object sender, EventArgs e)
- try
- if (ribbonButtonOpenCom1.Text == "打開串口")
- serialPort1.PortName = ribbonComboBoxCom1.TextBoxText;
- serialPort1.BaudRate = int.Parse(ribbonComboBoxBaud1.TextBoxText);
- serialPort1.StopBits = System.IO.Ports.StopBits.One;
- serialPort1.Parity = System.IO.Ports.Parity.None;
- serialPort1.DataBits = 8;
- serialPort1.Open();
- //成功打開后 設(shè)置按鈕相應(yīng)的狀態(tài)
- ribbonButtonOpenCom1.Text = "關(guān)閉串口";
- ribbonButtonOpenCom1.Image = Image.FromFile(Application.StartupPath + "\\ICON\\shutdown.ico");
- ribbonComboBoxCom1.Enabled = false;
- ribbonComboBoxBaud1.Enabled = false;
- //復(fù)位各表盤的數(shù)值
- thermometerVoltage.Value = 0;
- thermometerCurrent.Value = 0;
- thermometerTemp.Value = 30;
- lbDigitalMeter_Voltage_Set.Value = 0;
- lbDigitalMeter_Current_Set.Value = 0;
- lbDigitalMeter_Voltage_Get.Value = 0;
- lbDigitalMeter_Current_Get.Value = 0;
- knob_Voltage.Value = 0;
- knob_Current.Value = 0;
- slideButtonMode.Checked = false;
- slideButtonOutput.Checked = false;
- //重新設(shè)置坐標(biāo),清空原有曲線后添加電壓、電流設(shè)定曲線
- ResetGraphPane();
- knob_Voltage.Enabled = true;
- knob_Current.Enabled = true;
- slideButtonMode.Enabled = true;
- slideButtonOutput.Enabled = true;
- glassButtonStepAdd.Enabled = true;
- glassButtonCAL.Enabled = true;
- glassButtonStepSub.Enabled = true;
- //獲取下位機(jī)前一次電壓、電流的設(shè)定值
- byte[] data = new byte[] { (byte)COM_CMD.USART_M2S_GetVal };
- else
- //關(guān)閉下位機(jī)輸出
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_Output, 0x00 });//關(guān)輸出
- Thread.Sleep(200);
- serialPort1.Close();
- ribbonButtonOpenCom1.Text = "打開串口";
- ribbonButtonOpenCom1.Image = Image.FromFile(Application.StartupPath + "\\icon\\standby.ico");
- ribbonComboBoxCom1.Enabled = true;
- ribbonComboBoxBaud1.Enabled = true;
- //停止接收數(shù)據(jù)
- catch (Exception error)
- MessageBox.Show(error.ToString());
- float voltage = 0, current = 0, temp = 0;
- byte[] tmpArray = new byte[4];
- private void DataParseThreadFunc()
- while (_runDataParseThread)
- lock (this)
- if (receiveByteQueue.Count > 0)
- if (AnalyzePackage(receiveByteQueue.Dequeue()))
- currentTime = (Environment.TickCount - tickStart) / 1000.0;// +previousTime;
- switch (m_pRxBuf[0])
- case (byte)COM_CMD.USART_S2M_PreVal://前一次設(shè)置的電壓、電流
- tmpArray[0] = m_pRxBuf[1];
- tmpArray[1] = m_pRxBuf[2];
- tmpArray[2] = m_pRxBuf[3];
- tmpArray[3] = m_pRxBuf[4];
- voltage = BitConverter.ToSingle(tmpArray, 0);
- tmpArray[0] = m_pRxBuf[5];
- tmpArray[1] = m_pRxBuf[6];
- tmpArray[2] = m_pRxBuf[7];
- tmpArray[3] = m_pRxBuf[8];
- current = BitConverter.ToSingle(tmpArray, 0);
- knob_Voltage.Value = (int)(voltage*10);
- knob_Current.Value = (int)(current*100);
- break;
- case (byte)COM_CMD.USART_S2M_RealVal://實時電壓、電流數(shù)據(jù)
- mCurveStructVolSet.pointList.Add(currentTime, (float)lbDigitalMeter_Voltage_Set.Value);
- mCurveStructVolGet.pointList.Add(currentTime, voltage);
- mCurveStructCurSet.pointList.Add(currentTime, (float)lbDigitalMeter_Current_Set.Value);
- mCurveStructCurGet.pointList.Add(currentTime, current);
- lbDigitalMeter_Voltage_Get.Value = (double)voltage;
- lbDigitalMeter_Current_Get.Value = (double)current;
- thermometerVoltage.Value = voltage;
- thermometerCurrent.Value = current;
- break;
- case (byte)COM_CMD.USART_S2M_RealTemp://當(dāng)前溫度
- temp = BitConverter.ToSingle(tmpArray, 0);
- thermometerTemp.Value = temp;
- if (temp <= 40.0)
- thermometerTemp.BackColor = Color.Green;
- else if (temp <= 50)
- thermometerTemp.BackColor = Color.Brown;
- else
- thermometerTemp.BackColor = Color.Red;
- break;
- Scale xScale = zedGraphControl1.GraphPane.XAxis.Scale;
- if (currentTime > xScale.Max - xScale.MajorStep)
- xScale.Max = currentTime + xScale.MajorStep;
- xScale.Min = xScale.Max - 30.0;
- //更新X和Y軸的范圍
- //更新圖表
- private byte USART_LastByte = 0;
- private bool USART_BeginFlag = false;
- private bool USART_CtrlFlag = false;
- private long USART_RevOffset = 0;
- private byte CheckSum = 0;
- private bool AnalyzePackage(byte data)
- if (((data == USART_FRAMEHEAD) && (USART_LastByte == USART_FRAMEHEAD)) || (USART_RevOffset > m_MaxPackageSize))
- if (USART_RevOffset < 6 && USART_RevOffset > 0)
- m_TotalRxLostPackages++;
- //RESET
- USART_RevOffset = 0;
- USART_BeginFlag = true;
- USART_LastByte = data;
- return false;
- if ((data == USART_FRAMETAIL) && (USART_LastByte == USART_FRAMETAIL) && USART_BeginFlag)
- USART_RevOffset--;//得到除去頭尾和控制符的數(shù)據(jù)的個數(shù)
- m_RxPackageDataCount = USART_RevOffset - 1;
- CheckSum -= USART_FRAMETAIL;
- CheckSum -= m_pRxBuf[m_RxPackageDataCount];
- USART_BeginFlag = false;
- if (CheckSum == m_pRxBuf[m_RxPackageDataCount])
- CheckSum = 0;
- return true;
- CheckSum = 0;
- return false;
- if (USART_BeginFlag)
- if (USART_CtrlFlag)
- m_pRxBuf[USART_RevOffset++] = data;
- CheckSum += data;
- USART_CtrlFlag = false;
- USART_LastByte = USART_FRAMECTRL;
- else if (data == USART_FRAMECTRL)
- USART_CtrlFlag = true;
- else
- CheckSum += data;
- return false;
- private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
- Thread.Sleep(5);
- try
- byte[] byteArray = new byte[serialPort1.ReadBufferSize];
- int len = serialPort1.Read(byteArray, 0, byteArray.Length);
- lock (this)
- for (int i = 0; i < len; i++)
- receiveByteQueue.Enqueue(byteArray[i]);
- MessageBox.Show("serialPort1_DataReceived" + error.ToString());
- private void PackData2Frame(params byte[] byteArray)
- byte[] tmpByteArray = new byte[100];
- byte len = 0;
- tmpByteArray[0] = USART_FRAMEHEAD;
- tmpByteArray[1] = USART_FRAMEHEAD;
- CheckSum = 0;
- len = 2;
- foreach (byte tmp in byteArray)
- if (tmp == USART_FRAMECTRL || tmp == USART_FRAMEHEAD || tmp == USART_FRAMETAIL)
- tmpByteArray[len] = USART_FRAMECTRL;
- len++;
- tmpByteArray[len] = tmp;
- CheckSum += tmp;
- len++;
- if (CheckSum == USART_FRAMECTRL || CheckSum == USART_FRAMEHEAD || CheckSum == USART_FRAMETAIL)
- len++;
- tmpByteArray[len] = CheckSum;
- len++;
- tmpByteArray[len] = USART_FRAMETAIL;
- len++;
- len++;
- serialPort1.Write(tmpByteArray, 0, len);
- private void ribbonButtonOpenCom2_Click(object sender, EventArgs e)
- try
- if (ribbonButtonOpenCom2.Text == "打開串口")
- serialPort2.PortName = ribbonComboBoxCom2.TextBoxText;
- serialPort2.BaudRate = int.Parse(ribbonComboBoxBaud2.TextBoxText);
- serialPort2.StopBits = System.IO.Ports.StopBits.One;
- serialPort2.Parity = System.IO.Ports.Parity.None;
- serialPort2.DataBits = 8;
- serialPort2.Open();
- ribbonButtonOpenCom2.Text = "關(guān)閉串口";
- ribbonButtonOpenCom2.Image = Image.FromFile(Application.StartupPath + "\\ICON\\shutdown.ico");
- ribbonComboBoxCom2.Enabled = false;
- ribbonComboBoxBaud2.Enabled = false;
- else
- serialPort2.Close();
- ribbonButtonOpenCom2.Text = "打開串口";
- ribbonButtonOpenCom2.Image = Image.FromFile(Application.StartupPath + "\\icon\\standby.ico");
- ribbonComboBoxCom2.Enabled = true;
- ribbonComboBoxBaud2.Enabled = true;
- private void glassButtonCAL_Click(object sender, EventArgs e)
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_Cal});
- private void glassButtonStepAdd_Click(object sender, EventArgs e)
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_StepAdd });
- private void glassButtonStepSub_Click(object sender, EventArgs e)
- PackData2Frame(new byte[] { (byte)COM_CMD.USART_M2S_StepSub });
全部資料51hei下載地址:
DC_POWER.rar
(1.32 MB, 下載次數(shù): 18)
2018-9-6 15:29 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
