用8X8點(diǎn)陣流動(dòng)顯示時(shí)間,三個(gè)按鍵用來設(shè)置時(shí)間。- #include<reg51.h>
- #include<intrins.h>
- //--定義要使用的IO口--//
- #define COMMONPORTS P0
- sbit SRCLK= P3 ^ 6;
- sbit RCLK = P3 ^ 5;
- sbit SER = P3 ^ 4;
- sbit KEY1 = P3 ^ 0; //按鍵2用于時(shí)間設(shè)置
- sbit KEY2 = P3 ^ 2; //按鍵3用于時(shí)間設(shè)置加
- sbit KEY3 = P3 ^ 3; //按鍵4用于時(shí)間設(shè)置減
- unsigned char Time,time_hrs=20,time_min=59,time_sec=35;
- unsigned char MENU;//菜單切換標(biāo)志位
- //--列選通控制--//
- unsigned char code TAB[8] = {0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
- //--點(diǎn)陣字碼--//
- unsigned char code CHARCODE [113]=
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, //空白
- 0x3e,0x41,0x41,0x41,0x3e,0x00, //0
- 0x11,0x21,0x7F,0x01,0x01,0x00, //1
- 0x21,0x43,0x45,0x49,0x31,0x00, //2
- 0x22,0x41,0x49,0x49,0x36,0x00, //3
- 0x0C,0x14,0x24,0x7F,0x04,0x00, //4
- 0x72,0x51,0x51,0x51,0x4E,0x00, //5
- 0x3E,0x49,0x49,0x49,0x26,0x00, //6
- 0x40,0x47,0x48,0x50,0x60,0x00, //7
- 0x36,0x49,0x49,0x49,0x36,0x00, //8
- 0x32,0x49,0x49,0x49,0x3E,0x00, //9
- 0x36,0x36,0x00, //:
- 0x3E,0x2A,0x3E,0x00,0x14,0x11,0x7F,0x10,0x00, //時(shí)
- 0xBF,0x40,0xBE,0xAA,0xBE,0x81,0xFF,0x00, //間
- 0xA0,0x60,0x3F,0x02,0x58,0xD5,0x92,0xD6,0x59,0x00, //設(shè)
- 0xD1,0xDF,0xD5,0xF5,0xD5,0xDF,0xD1, //置
- 0x11,0x22,0x54,0x18,0x91,0x5F,0x20,0x10, //分
- unsigned char WS[50];//用來存放要顯示的位數(shù)的值
- * 函數(shù)名 : buffer_normal();
- * 函數(shù)功能 : 正常顯示緩沖數(shù)組
- * 輸入 : 無
- * 輸出 : 無
- void buffer_normal() //正常顯示數(shù)組
- unsigned char a,b,c,d,e,f,g;
- for(g=35;g<43;g++) //空白
- WS[g]=CHARCODE[g-35];
- for(f=29;f<35;f++) //分鐘個(gè)位
- WS[f]=CHARCODE[time_min%10*6+f-21];
- for(e=23;e<29;e++)
- { //分鐘十位
- WS[e]=CHARCODE[time_min%100/10*6+e-15];
- for(d=20;d<23;d++) //秒點(diǎn)
- WS[d]=CHARCODE[d+48];
- for(c=14;c<20;c++) //小時(shí)個(gè)位
- WS[c]=CHARCODE[time_hrs%10*6+c-6];
- for(b=8;b<14;b++) //小時(shí)十位
- WS[b]=CHARCODE[time_hrs%100/10*6+b];
- for(a=0;a<8;a++) //空白
- WS[a]=CHARCODE[a];
- * 函數(shù)名 : timeset();
- * 函數(shù)功能 : 時(shí)間設(shè)置顯示緩沖數(shù)組
- * 輸入 : 無
- * 輸出 : 無
- void timeset() //時(shí)間設(shè)置
- unsigned char a,b,c;
- for(c=42;c<50;c++) //空白
- WS[c]=CHARCODE[c-42];
- for(b=8;b<42;b++) //時(shí)間設(shè)置
- WS[b]=CHARCODE[b+63];
- * 函數(shù)名 : Hour_setting();
- * 函數(shù)功能 : 小時(shí)設(shè)置顯示緩沖數(shù)組
- * 輸入 : 無
- * 輸出 : 無
- void Hour_setting() //小時(shí)設(shè)置顯示緩沖數(shù)組
- unsigned char a,b,c,d,e;
- for(e=28;e<36;e++) //空白
- WS[e]=CHARCODE[e-28];
- for(d=20;d<28;d++) //時(shí)
- WS[d]=CHARCODE[d+51];
- * 函數(shù)名 : Minute_setting();
- * 函數(shù)功能 : 分鐘設(shè)置顯示緩沖數(shù)組
- * 輸入 : 無
- * 輸出 : 無
- void Minute_setting() //分鐘設(shè)置顯示緩沖數(shù)組
- for(d=20;d<28;d++) //分
- WS[d]=CHARCODE[d+85];
- for(c=14;c<20;c++) //分鐘個(gè)位
- WS[c]=CHARCODE[time_min%10*6+c-6];
- for(b=8;b<14;b++)
- { //分鐘十位
- WS[b]=CHARCODE[time_min%100/10*6+b];
- * 函數(shù)名 : delay();
- * 函數(shù)功能 : 延時(shí)
- * 輸入 : 無
- * 輸出 : 無
- void delay(unsigned int time)
- unsigned int i,j;
- for(i=0;i<time;i++)
- for(j=0;j<47;j++);
- * 函數(shù)名 : TimerConfiguration();
- * 函數(shù)功能 : 配置定時(shí)器值
- * 輸入 : 無
- * 輸出 : 無
- void TimerConfiguration()
- TMOD = 0x01; //選擇工作方式1
- TH0 = 0x3C; //設(shè)置初始值,定時(shí)50MS
- TL0 = 0xB0;
- EA = 1; //打開總中斷
- ET0 = 1; //打開定時(shí)器0中斷
- TR0 = 1; //啟動(dòng)定時(shí)器0
- * 函數(shù)名 : Timer0()
- * 函數(shù)功能 : 定時(shí)器0中斷函數(shù)
- * 輸入 : 無
- * 輸出 : 無
- void Timer0() interrupt 1
- TH0 = 0x3C; //設(shè)置初始值50ms
- TL0 = 0xB0;
- Time++;
- if(Time==20)
- Time=0;
- time_sec++;
- if(time_sec==60)
- time_sec=0;
- time_min++;
- if(time_min==60)
- time_min=0;
- time_hrs++;
- if(time_hrs==24)
- time_hrs=0;
- * 函數(shù)名 : Hc595SendByte(unsigned char dat);
- * 函數(shù)功能 : 向74H595發(fā)送一個(gè)字節(jié)的數(shù)據(jù)
- * 輸入 : 無
- * 輸出 : 無
- void Hc595SendByte(unsigned char dat)
- unsigned char a;
- SRCLK=0;
- RCLK=0;
- for(a=0;a<8;a++)
- SER=dat>>7;
- dat<<=1;
- SRCLK=1;
- _nop_();
- _nop_();
- SRCLK=0;
- RCLK=1;
- _nop_();
- _nop_();
- RCLK=0;
- * 函數(shù)名 : display();
- * 函數(shù)功能 : 顯示函數(shù)
- * 輸入 : 無
- * 輸出 : 無
- void display(unsigned char array)
- unsigned char tab;
- unsigned int a,b,c;
- for(a=0;a<8;a++)
- if(a ==7)
- b++;
- if(b==array) //數(shù)組數(shù)量減8
- b=0;
- for(c=0;c<2;c++) //控制流動(dòng)速度
- for(tab=0;tab<8;tab++)
- Hc595SendByte(0x00); //消隱
- COMMONPORTS = TAB[tab]; //P0輸出字碼
- Hc595SendByte(WS[tab+b]);
- delay(1);
- * 函數(shù)名 : array_clear();
- * 函數(shù)功能 : 緩沖數(shù)組清零函數(shù)
- * 輸入 : 無
- * 輸出 : 無
- void array_clear()
- unsigned int a;
- for(a=0;a<50;a++)
- WS[a]=0;
- * 函數(shù)名 : main
- * 函數(shù)功能 : 主函數(shù)
- * 輸入 : 無
- * 輸出 : 無
- void main()
- unsigned char s=0;
- MENU=0;
- TimerConfiguration();
- while(1)
- if(KEY1==0)
- s++;
- if(s>2)
- s=0;MENU++;
- if(MENU==0) //正常走時(shí)
- array_clear();
- buffer_normal();
- display(35);
- if(MENU==1) //顯示時(shí)間設(shè)置
- timeset();
- display(42);
- if(MENU==2) //小時(shí)設(shè)置
- array_clear();
- if(KEY2==0)
- s++;
- if(s>2)
- s=0;time_hrs++; //小時(shí)加
- if(time_hrs>23)
- time_hrs=0;
- if(KEY3==0)
- s++;
- if(s>2)
- s=0;time_hrs--; //小時(shí)減
- if(time_hrs>24)
- time_hrs=23;
- Hour_setting();
- display(28);
- if(MENU==3) //分鐘設(shè)置
- array_clear();
- if(KEY2==0)
- s++;
- if(s>2)
- s=0;time_min++; //分鐘加
- if(time_min>59)
- time_min=0;
- if(KEY3==0)
- s++;
- if(s>2)
- s=0;time_min--; //分鐘減
- if(time_min>60)
- time_min=59;
- Minute_setting();
- display(28);
- if(MENU>3)
- MENU=0;
- time_sec=0;
