查看: 3929|回復(fù): 11
關(guān)于單片機(jī)數(shù)碼管倒計(jì)時(shí)如何變成正計(jì)時(shí)的問(wèn)題?
ID:393625 發(fā)表于 2018-9-17 09:05 | 顯示全部樓層 |閱讀模式
請(qǐng)問(wèn)如何將天數(shù)的倒計(jì)時(shí)變成天數(shù)的正計(jì)時(shí)
  1. #include <REGX52.H>
  2. #include<intrins.h>  //包含_nop_();定義的頭文件
  3. #include<LS595driver.h>
  4. #include<LS595_2driver.h>
  5. #include<ds1302driver.h>
  6. SYSTEMTIME today;                  //2018.1.2 12:00:00 2
  7. unsigned int T0loop;          //記錄進(jìn)入T0的次數(shù)
  8. unsigned int flag;        //約10秒1次,
  9. unsigned int countupday; //記錄正計(jì)時(shí)天數(shù)的參數(shù)
  10. unsigned char olddaytemp,newdaytemp;  //用來(lái)比較是否已經(jīng)過(guò)一天
  11. unsigned char keyvalue;//記錄按鍵掃描函數(shù)的返回值
  12. //******************
  13. //unsigned int test[10]={0,111,222,333,444,555,666,777,888,999}; //記錄倒計(jì)時(shí)天數(shù)的參數(shù)
  14. unsigned char i;
  15. //*******************
  16. sbit key1 = P1^0;
  17. sbit key2 = P1^1;
  18. sbit key3 = P1^2;
  19. sbit LEDr=P1^3;
  20. sbit LEDg=P1^4;
  21. sbit LEDy=P1^5;
  22. void Init_89C52();      //初始化89C52
  23. void InitT0();
  24. char Keyscan();         //按鍵掃描并返回鍵值
  25. void Setcountupday(); //按鍵設(shè)置正計(jì)時(shí)天數(shù)
  26. void main()
  27. {
  28.   Init_89C52();
  29.   Delay_ms(1000);
  30.   countupday = 865;
  31.   LEDr = 1;
  32.   LEDg = 1;
  33.   LEDy = 1;
  34. //*****************************
  35.   Init_1302();  //初始化時(shí)鐘
  36.   InitT0();     //初始化T0定時(shí)器
  37.   Displayround();
  38.   while(1)
  39.   {
  40.    Displaysecond_595(&today);
  41.    Displayday_595(&today);
  42.    Displayhour_595(&today);
  43.    Displayminute_595(&today);
  44.    Setcountupday();
  45.    Displaycountupnum(countupday);
  46.    if(flag==1)
  47.    {
  48.      flag = 0;
  49.          if(olddaytemp=!newdaytemp)
  50.          {
  51.            countupday++;
  52.      }
  53.    }
  54.   }
  55. }
  56. //*************************************************************************
  57. //Time0中斷函數(shù)
  58. //功能:定時(shí)出10秒/50毫秒=200個(gè)循環(huán)
  59. //參數(shù):無(wú)
  60. //*************************************************************************
  61. void Time0(void) interrupt 1 using 1
  62. {
  63.   TR0 = 0;
  64.   T0loop++;
  65.   if(T0loop==200)
  66.   {
  67.     Gettime_1302(&today);
  68.         olddaytemp = today.day;
  69.   }
  70.   if(T0loop==400)
  71.   {
  72.         Gettime_1302(&today);
  73.         newdaytemp = today.day;
  74.         flag = 1;
  75.         T0loop = 0;
  76.   }
  77.   TH0 = (65536-46083)/256;                                  //重新給T0賦初始值
  78.   TL0 = (65536-46083)%256;                                  //
  79.   TR0 = 1;                                //啟動(dòng)T0
  80. }
  81. //*************************************************************************
  82. //Time0中斷函數(shù)
  83. //功能:每8秒進(jìn)入中斷,執(zhí)行開(kāi)門或關(guān)門操作,并重設(shè)Time0
  84. //參數(shù):無(wú)
  85. //*************************************************************************
  86. void InitT0()
  87. {
  88.   TMOD=0x01;    //使用定時(shí)器T0,11.0592MHz晶振的12分頻,16位定時(shí)器65536-1
  89.   TH0 =(65536-46083)/256;  //將定時(shí)器計(jì)時(shí)時(shí)間設(shè)定為46083*1.085微秒=50000微秒=50毫秒
  90.   TL0 =(65536-46083)%256;  //
  91.   EA  = 1;       //開(kāi)啟總中斷
  92.   ET0 = 1;       //T0中斷允許
  93.   TR0 = 1;       //啟動(dòng)定時(shí)器T0
  94.   T0loop = 0;                          //記錄進(jìn)入T0的次數(shù)
  95.   flag = 0;         //10秒一個(gè)周期
  96. }
  97. /*89C52初始化*/
  98. void Init_89C52()
  99. {
  100.   P0 = 0;
  101.   P1 = 1;
  102.   P2 = 0;
  103.   T0loop = 0;
  104. }
  105. /*按鍵掃描函數(shù)*/
  106. char Keyscan()
  107. {
  108.   if(key1==0)
  109.   {
  110.     Delay_ms(200);
  111.         if(key1==0)
  112.         {
  113.           return 1;
  114.         }
  115.   }
  116.   if(key2==1)
  117.   {
  118.     Delay_ms(200);
  119.         if(key2==1)
  120.         {
  121.           return 2;
  122.         }
  123.   }
  124.   if(key3==1)
  125.   {
  126.     Delay_ms(200);
  127.         if(key3==1)
  128.         {
  129.           return 2;
  130.         }
  131.   }
  132.   else
  133.     return 0;
  134. }
  135. /*按鍵調(diào)整函數(shù)*/
  136. void Setcountupday()
  137. {
  138.   switch(Keyscan())
  139.   {
  140.     case 1:
  141.         countupday--;
  142.         Displaycountupnum(countupday);
  143.         break;
  144.         case 2:
  145.         countupday++;
  146.         Displaycountupnum(countupday);
  147.         break;
  148.         default:
  149.         Displaycountupnum(countupday);
  150.         break;
  151.   }
  152. }
ID:277550 發(fā)表于 2018-9-17 09:35 | 顯示全部樓層
這個(gè)Displaycountupnum函數(shù)在哪呢
其實(shí),是把要顯示的變量,換成
這個(gè)變量
參與人數(shù) 1黑幣 +20 收起 理由
ID:393625 發(fā)表于 2018-9-17 14:11 | 顯示全部樓層
devcang 發(fā)表于 2018-9-17 09:35
其實(shí),是把要顯示的變量,換成
請(qǐng)問(wèn)能詳細(xì)說(shuō)一下怎么改嗎,非常感謝
ID:397025 發(fā)表于 2018-9-17 14:36 | 顯示全部樓層
你是想做成日期一樣嗎?
ID:267330 發(fā)表于 2018-9-17 14:51 | 顯示全部樓層
ID:80221 發(fā)表于 2018-9-17 17:56 | 顯示全部樓層
Displaycountupnum(),這個(gè)函數(shù)貼出來(lái)
ID:164602 發(fā)表于 2018-9-18 08:16 | 顯示全部樓層
正計(jì)時(shí),根本不需要你這個(gè)倒計(jì)時(shí)程序嘛,只要正確讀出1302的數(shù)據(jù),就可以了,因?yàn)?302本身就是正計(jì)時(shí)啊。
ID:393625 發(fā)表于 2018-9-19 10:13 | 顯示全部樓層
a庚 發(fā)表于 2018-9-17 17:56
/*                     第二組級(jí)聯(lián)74LS595_2數(shù)碼管驅(qū)動(dòng)程序         */
#ifndef _LS595_2driver_H_
#define _LS595_2driver_H_
sbit RCK_595_2 = P0^4;        //第二組級(jí)聯(lián)595的并行輸出時(shí)鐘
sbit DS_595_2 = P0^3;         //第二組級(jí)聯(lián)595數(shù)據(jù)線
sbit CLK_595_2 = P0^5;        //第二組級(jí)聯(lián)595移位輸入時(shí)鐘
unsigned char code countupseg[] =        //第二組595中定義0~9,高亮低滅
{// 0         1          2           3        4         5          6           7        8         9
        0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F
unsigned char code roundseg[6]={0x01,0x02,0x04,0x08,0x10,0x20}; //花式旋轉(zhuǎn)
/*延時(shí)函數(shù)  1ms為單位*/
void Delay_ms(unsigned int t)           //延時(shí)函數(shù),t/ms
  unsigned int a,b;
  for(a=0;a<t;a++)
    for(b=0;b<100;b++)
       _nop_();
/* 向1個(gè)LS595_2寫入1個(gè)字節(jié)*/
void Send1byte_595_2(unsigned char dat)
  unsigned char i;
  for(i=0;i<8;i++)
        if(dat&0x80)
        DS_595_2 = 1;
        DS_595_2 = 0;
        dat <<=1;
        CLK_595_2 = 0;
        _nop_();
        CLK_595_2 = 1;
/* 向3個(gè)級(jí)聯(lián)LS595_2寫入3個(gè)字節(jié)*/
void Send3byte_595_2(unsigned char dat1,unsigned char dat2,unsigned char dat3)
  Send1byte_595_2(dat1);
  Send1byte_595_2(dat2);
  Send1byte_595_2(dat3);
/*允許將LS595輸出并行數(shù)據(jù)*/
void Out_595_2()
  RCK_595_2 = 0;
  _nop_();
  RCK_595_2 = 1;
/*顯示倒計(jì)時(shí) 3位*/
void Displaycountupnum(unsigned int num)
  unsigned int units,tens,hundreds;
  units = num%10;
  tens = (num/10)%10;
  hundreds = num/100;
  Send3byte_595_2(countupseg[hundreds],countupseg[tens],countupseg[units]);        //顯示倒計(jì)時(shí)的個(gè)、十、百位
  Out_595_2();
/*大字花式轉(zhuǎn)圈*/
void Displayround()
  unsigned char j;
  for(j=0;j<5;j++)
    Send3byte_595_2(roundseg[j],roundseg[j],roundseg[j]);
        Out_595_2();
        Delay_ms(800);
#endif
參與人數(shù) 1黑幣 +40 收起 理由
admin + 40 回帖助人的獎(jiǎng)勵(lì)!
ID:393625 發(fā)表于 2018-9-20 08:47 | 顯示全部樓層
cico 發(fā)表于 2018-9-17 14:36
你是想做成日期一樣嗎?
就是數(shù)碼管000-999的的正計(jì)時(shí),一天加一。
ID:393625 發(fā)表于 2018-9-20 10:26 | 顯示全部樓層
HC6800-ES-V2.0 發(fā)表于 2018-9-18 08:16
/*                     DS1302驅(qū)動(dòng)程序                            */
#ifndef _ds1302driver_H_
#define _ds1302driver_H_
//#include<LS595driver.h>
sbit RST_1302 = P2^2;       //1302的RST
sbit IO_1302 = P2^1;        //1302的IO
sbit SCLK_1302 = P2^0;      //1302的SCLK
sbit ACC0 = ACC^0;          //定義單片機(jī)累加器寄存器ACC
sbit ACC7 = ACC^7;          //定義單片機(jī)累加器寄存器ACC
/*  宏定義DS1302的寫入寄存器  */
#define WDS1302_SECOND  0X80
#define WDS1302_MINUTE  0X82
#define WDS1302_HOUR    0X84
#define WDS1302_WEEK    0X8A
#define WDS1302_DAY     0X86
#define WDS1302_MONTH   0X88
#define WDS1302_YEAR    0X8C
#define WDS1302_BATTERY 0X90
/*  宏定義DS1302的讀取寄存器  */
#define RDS1302_SECOND  0X81
#define RDS1302_MINUTE  0X83
#define RDS1302_HOUR    0X85
#define RDS1302_WEEK    0X8B
#define RDS1302_DAY     0X87
#define RDS1302_MONTH   0X89
#define RDS1302_YEAR    0X8D
#define RDS1302_BATTERY 0X91
/*向DS1302寫入一個(gè)字節(jié)*/
void Send1byte_1302(unsigned char dat)
  unsigned char i;
  ACC = dat;        //將dat放入累加器ACC內(nèi)
  for(i=8;i>0;i--)
    IO_1302 = ACC0;     //將ACC的最低位賦值給IO管腳
        SCLK_1302 = 1;
        SCLK_1302 = 0;
        ACC = ACC>>1;
/*從DS1302讀取一個(gè)字節(jié)*/
unsigned char Get1byte_1302()
  unsigned char i;
  for(i=8;i>0;i--)
    ACC = ACC>>1;                  //挪空最高位
        ACC7 = IO_1302;       //將IO管腳賦值給ACC的最高位
    SCLK_1302 = 1;
        SCLK_1302 = 0;
  return(ACC);
/*向DS1302指定地址寫入數(shù)據(jù)  add--1302的地址,dat--寫入的數(shù)據(jù)*/
void Write_1302(unsigned char add,unsigned char dat)
  RST_1302 = 0;
  SCLK_1302 = 0;
  RST_1302 = 1;
  Send1byte_1302(add);
  Send1byte_1302(dat);
  SCLK_1302 = 1;
  RST_1302 = 0;
/*從DS1302指定地址讀取數(shù)據(jù)  add--1302的地址*/
unsigned char Read_1302(unsigned char add)
  unsigned char temp;
  RST_1302 = 0;
  SCLK_1302 = 0;
  RST_1302 = 1;
  Send1byte_1302(add|0x01);
  temp = Get1byte_1302();
  SCLK_1302 = 1;
  RST_1302 = 0;
  return(temp);
/*設(shè)置寫保護(hù) flag=1~禁止寫  flag=0~允許寫*/
void Protect_1302(unsigned char flag)
  if(flag)
    Write_1302(0x8e,0x80);
    Write_1302(0x8e,0x00);
/*初始化DS1302 的日期*/
void Init_1302()//
  RST_1302 = 0;
  SCLK_1302 = 0;
  Protect_1302(0);                    //允許寫操作
  Write_1302(WDS1302_SECOND,0x00);    //向DS1302秒寄存器80H寫入秒初始00
  Write_1302(WDS1302_MINUTE,0x00);    //向DS1302分寄存器82H寫入分初始00
  Write_1302(WDS1302_HOUR,0x12);      //向DS1302時(shí)寄存器84H寫入時(shí)初始12
  Write_1302(WDS1302_WEEK,0x03);      //向DS1302周寄存器8aH寫入周初始03
  Write_1302(WDS1302_DAY,0x01);       //向DS1302日寄存器86H寫入日初始1
  Write_1302(WDS1302_MONTH,0x08);     //向DS1302月寄存器88H寫入月初始8
  Write_1302(WDS1302_YEAR,0x18);      //向DS1302年寄存器8cH寫入年初始18
  Protect_1302(1);                    //禁止寫操作
/*設(shè)置單個(gè)寄存器日期時(shí)間*/
void Set_time_1302(unsigned char add,unsigned char time)
  unsigned char timeBCD;
  timeBCD = (time/10)<<4 | (time%10);   //將十進(jìn)制轉(zhuǎn)為二進(jìn)制才能寫入
  Write_1302(0x8e,0x00);                                //允許寫入
  Write_1302(add,timeBCD);
  Write_1302(0x8e,0x80);                                //啟動(dòng)保護(hù) 禁止寫
/*獲取DS1302內(nèi)的時(shí)間日期*/
void Gettime_1302(SYSTEMTIME *time)
  unsigned char gettempe;
  gettempe = Read_1302(RDS1302_SECOND);                                                   //獲取秒寄存器
  time->second = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成秒賦值 二進(jìn)制轉(zhuǎn)十進(jìn)制
  gettempe = Read_1302(RDS1302_MINUTE);                                                   //獲取分寄存器
  time->minute = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成分賦值 二進(jìn)制轉(zhuǎn)十進(jìn)制
  gettempe = Read_1302(RDS1302_HOUR);                                                   //獲取時(shí)寄存器
  time->hour = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成時(shí)賦值 二進(jìn)制轉(zhuǎn)十進(jìn)制
  gettempe = Read_1302(RDS1302_WEEK);                                                   //獲取周寄存器
  time->week= ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成周賦值 二進(jìn)制轉(zhuǎn)十進(jìn)制
  gettempe = Read_1302(RDS1302_DAY);                                                   //獲取日寄存器
  time->day = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成日賦值 二進(jìn)制轉(zhuǎn)十進(jìn)制
  gettempe = Read_1302(RDS1302_MONTH);                                                   //獲取月寄存器
  time->month = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成月賦值 二進(jìn)制轉(zhuǎn)十進(jìn)制
  gettempe = Read_1302(RDS1302_YEAR);                                                   //獲取年寄存器
  time->year = ((gettempe&0x70)>>4)*10 + (gettempe&0x0F);           //完成年賦值 二進(jìn)制轉(zhuǎn)十進(jìn)制
#endif
請(qǐng)問(wèn)這個(gè)程序能達(dá)到我想要的效果嗎
ID:393625 發(fā)表于 2018-9-20 10:46 | 顯示全部樓層
  units = num%10;
  tens = (num/10)%10;
  hundreds = num/100;
  Out_595_2();
ID:393625 發(fā)表于 2018-9-20 10:48 | 顯示全部樓層
其實(shí),是把要顯示的變量,換成
  unsigned int a,b;
  for(a=0;a<t;a++)
    for(b=0;b<100;b++)
       _nop_();
  unsigned char i;
  for(i=0;i<8;i++)
        if(dat&0x80)
        DS_595_2 = 1;
        DS_595_2 = 0;
        dat <<=1;
        CLK_595_2 = 0;
        _nop_();
        CLK_595_2 = 1;
void Out_595_2()
  RCK_595_2 = 0;
  _nop_();
  RCK_595_2 = 1;
  units = num%10;
  tens = (num/10)%10;
  hundreds = num/100;
  Out_595_2();
/*大字花式轉(zhuǎn)圈*/
void Displayround()
  unsigned char j;
  for(j=0;j<5;j++)
        Out_595_2();
        Delay_ms(800);
#endif
