查看: 1359|回復(fù): 1
各位求助!這個(gè)lcd1602數(shù)字顯示總有問(wèn)題啊(霍爾元件測(cè)速測(cè)距)
這個(gè)自行車?yán)没魻栐䴗y(cè)速測(cè)距并顯示的程序在速度顯示上總有問(wèn)題,另外還有個(gè)鍵入身高體重顯示建議行駛路程的功能也有問(wèn)題。
速度顯示用數(shù)碼管就沒(méi)用問(wèn)題,數(shù)值大概個(gè)位數(shù)到十幾之間。suggestion是建議路程函數(shù),就是簡(jiǎn)單的height-weight,不知道為什么顯示出來(lái)就是幾百米。
#define MAIN_Fosc                12000000L        //¶¨òåÖ÷ê±Öó
#include        "15W4KxxS4.H"
#include<GPIO.h>
#include<lcd1602.h>
int cesu(int k);
òy½Å±eÃû¶¨òå
int t=0;
uint32 n=0,m;          //è|êyòÔ¼°×aò»è|μÄê±¼ä
uint16 k=0;            //¼ÆêyÆ÷¼Æê±
uint8 a[4];
uint8 p;
uint8 code table1[]="L:";       //òaÏÔê¾μÄÄúèY1·Åèëêy×étable1
uint8 code table2[]="V:";       //òaÏÔê¾μÄÄúèY2·Åèëêy×étable2
uint8 code table5[]="Height:";
uint8 code table6[]="Weight:";
uint8 code table7[]="suggestion:";
uint16 table3[],table4[];
uint8 code ASCII[18] =  {'0','1','2','3','4','5','6','7','8','9','.','-','M','/','S','K','G','C'};
òy½Å±eÃû¶¨òå
sbit COL4=P5^2;            //4*4¾ØÕó¼ì2aáD¼ì2a¶Ë¿ú
sbit COL3=P5^3;            //4*4¾ØÕó¼ì2aáD¼ì2a¶Ë¿ú
sbit COL2=P2^6;            //4*4¾ØÕó¼ì2aáD¼ì2a¶Ë¿ú
sbit COL1=P2^7;            //4*4¾ØÕó¼ì2aáD¼ì2a¶Ë¿ú
sbit ROW4=P4^4;            //4*4¾ØÕó¼ì2aDD¼ì2a¶Ë¿ú
sbit ROW3=P4^5;            //4*4¾ØÕó¼ì2aDD¼ì2a¶Ë¿ú
sbit ROW2=P4^6;            //4*4¾ØÕó¼ì2aDD¼ì2a¶Ë¿ú
sbit ROW1=P4^7;            //4*4¾ØÕó¼ì2aDD¼ì2a¶Ë¿ú
sbit LED_B=P1^4;     //à¶é«LEDóÃIO¿úP06
sbit LED_R=P3^4;     //oìé«LEDóÃIO¿úP07
sbit LED_G=P1^5;     //Âìé«LEDóÃIO¿úP07
sbit beep=P3^7;
* Ãè  êö : °′¼üé¨Ãèoˉêy
* èë  2Î : ÎT
* ·μ»ØÖμ : Äĸö°′¼ü°′ÏÂμĶÔó|Öμ
uint8 KeyScan(void)
        uint8 X_temp,Y_temp,temp;
         X_temp=0xF0;        //áDÖμ¸33õÖμ
         Y_temp=0x0F;        //DDÖμ¸33õÖμ
         P2M1 &= 0x3F;        P2M0 |= 0xC0;          //éèÖÃP2.6~P2.7ÎaÇ¿íÆíìêä3ö
         P4M1 &= 0x0F;        P4M0 |= 0xF0;          //éèÖÃP4.4~P4.7ÎaÇ¿íÆíìêä3ö
         P5M1 &= 0xF3;        P5M0 |= 0x0C;          //éèÖÃP5.2~P5.3ÎaÇ¿íÆíìêä3ö
    ROW1=1;ROW2=1;ROW3=1;ROW4=1;  //DDÖøß
          COL1=0;COL2=0;COL3=0;COL4=0;  //áDÖÃμí
                //ËùóÃμ½DDIO¿úÅäÖÃÎaêäè룬½øDD¼ì2a
          delay_ms(10);
          P4M1 &= 0x0F;        P4M0 &= 0x0F;          //éèÖÃP4.4~P4.7Îa׼˫Ïò¿ú
    delay_ms(10);
                if(ROW1 == 0)         //¼ì2aDD1μçÆ½êÇ·ñÎaμíμçÆ½
                        delay_ms(10);
                        if(ROW1 == 0)
                        Y_temp &= 0x0E;
                if(ROW2 == 0)         //¼ì2aDD2μçÆ½êÇ·ñÎaμíμçÆ½
                        delay_ms(10);
                        if(ROW2 == 0)
                        Y_temp &= 0x0D;
                if(ROW3 == 0)         //¼ì2aDD3μçÆ½êÇ·ñÎaμíμçÆ½
                        delay_ms(10);
                        if(ROW3 == 0)
                        Y_temp &= 0x0B;
                if(ROW4 == 0)         //¼ì2aDD4μçÆ½êÇ·ñÎaμíμçÆ½
                        delay_ms(10);
                        if(ROW4 == 0)
                        Y_temp &= 0x07;
                ROW1=0;ROW2=0;ROW3=0;ROW4=0;  //DDÖÃμí
          COL1=1;COL2=1;COL3=1;COL4=1;  //áDÖøß
                //ËùóÃμ½áDIO¿úÅäÖÃÎaêäè룬½øDD¼ì2a
                delay_ms(10);
          P2M1 &= 0x3F;        P2M0 &= 0x3F;          //éèÖÃP2.6~P2.7Îa׼˫Ïò¿ú
          P5M1 &= 0xF3;        P5M0 &= 0xF3;          //éèÖÃP5.2~P5.3Îa׼˫Ïò¿ú
    delay_ms(10);
                if(COL1 == 0)         //¼ì2aáD1μçÆ½êÇ·ñÎaμíμçÆ½
                        delay_ms(10);
                        if(COL1 == 0)
                        X_temp &= 0xE0;
                if(COL2 == 0)         //¼ì2aáD2μçÆ½êÇ·ñÎaμíμçÆ½
                        delay_ms(10);
                        if(COL2 == 0)
                        X_temp &= 0xD0;
                if(COL3 == 0)         //¼ì2aáD3μçÆ½êÇ·ñÎaμíμçÆ½
                        delay_ms(10);
                        if(COL3 == 0)
                        X_temp &= 0xB0;
                if(COL4 == 0)         //¼ì2aáD4μçÆ½êÇ·ñÎaμíμçÆ½
                        delay_ms(10);
                        if(COL4 == 0)
                        X_temp &= 0x70;
                //½«DDÖμoíáDÖμoÏ2¢£¬μÃμ½°′¼ü¶Ôó|μıàÂëÖ죬¸ÃÖμóë16¸ö°′¼üò»ò»¶Ôó|
                temp = X_temp|Y_temp;
          temp = ~temp;
                //½«°′¼ü¼ì2aμÄÔ-ê¼±àÂëÖμ½aÎö¶Ôó|°′¼üÖμDÅÏ¢
    switch (temp)
                      case 0x11:return 1;        //1
                      case 0x21:return 2;        //2
                      case 0x41:return 3;        //3
                      case 0x81:return 4;        //4
                      case 0x12:return 5;        //5
                      case 0x22:return 6;        //6
                      case 0x42:return 7;        //7
                      case 0x82:return 8;        //8
                      case 0x14:return 9;        //9
                      case 0x24:return 10;        //0
                      case 0x44:return 11;        //a
                      case 0x84:return 12;        //b
                      case 0x18:return 13;        //c
                      case 0x28:return 14;        //d
                      case 0x48:return 15;  //e
                      case 0x88:return 16;        //f
                      default:  return 0;
//¼Æê±Æ÷3õê¼»ˉ
void init(void)
        TMOD|=0X15;
        TH0=65535/256;
  TL0=65535%256;
        TH1=0xFC;
        TL1=0x18;
        EA=1;
        ET0=1;
        ET1=1;
        TR0=1;
        PT0=1;
        PT1=0;
1|ÄüÃèêö£oÑóê±oˉêy
èë¿ú2Îêy£ouint16 x £¬¸ÃÖμÎa1ê±£¬Ñóê±1ms
·μ»ØÖμ£oÎT
void delay_ms(uint16 x)
        uint16 j,i;
        for(j=0;j<x;j++)
                for(i=0;i<1100;i++);
1|ÄüÃèêö£oLCD1602D′Ãüáîoˉêy
èë¿ú2Îêy£uint8 com
·μ»ØÖμ£oÎT
void lcd_wcom(uint8 com)
    rs=0;               //Ñ¡ÔñÖ¸áî¼Ä′æÆ÷
    rw=0;               //Ñ¡ÔñD′
    P0=com;             //°ÑÃüáî×ÖËíèëP0
    delay_ms(1);        //Ñóê±ò»D¡»á¶ù£¬èÃ1602×¼±¸½óêÕêy¾Y
    en=1;               //ê1ÄüÏßμçÆ½±ä»ˉ£¬ÃüáîËíèë1602μÄ8λêy¾Y¿ú
    en=0;
1|ÄüÃèêö£oLCD1602D′êy¾Yoˉêy
èë¿ú2Îêy£ouint8 dat
·μ»ØÖμ£oÎT
void lcd_wdat(uint8 dat)
    rs=1;               //Ñ¡Ôñêy¾Y¼Ä′æÆ÷
    rw=0;               //Ñ¡ÔñD′
    P0=dat;             //°ÑòaÏÔê¾μÄêy¾YËíèëP0
    en=1;               //ê1ÄüÏßμçÆ½±ä»ˉ£¬êy¾YËíèë1602μÄ8λêy¾Y¿ú
    en=0;
1|ÄüÃèêö£oLCD16023õê¼»ˉoˉêy
èë¿ú2Îêy£oÎT
·μ»ØÖμ£oÎT
void lcd_init(void)
    lcd_wcom(0x38);       //8λêy¾Y£¬Ë«áD£¬5*7×ÖDΠ
    lcd_wcom(0x0c);       //¿aÆôÏÔê¾Æá£¬1Ø1a±ê£¬1a±ê2»éá˸
    lcd_wcom(0x06);       //ÏÔê¾μØÖ·μYÔö£¬¼′D′ò»¸öêy¾Yoó£¬ÏÔê¾Î»ÖÃóòòÆò»Î»
    lcd_wcom(0x01);       //ÇåÆá
1|ÄüÃèêö£oLCD1602°′Ö¸¶¨Î»ÖÃÏÔê¾ò»¸ö×Ö·û
èë¿ú2Îêy£ouint8 X, uint8 Y, uint8 DData
·μ»ØÖμ£oÎT
void DisplayOneChar(uint8 X, uint8 Y, uint8 DData)
        Y &= 0x1;
        X &= 0xF; //ÏTÖÆX2»Äü′óóú15£¬Y2»Äü′óóú1
        if (Y) X |= 0x40; //μ±òaÏÔê¾μú¶tDDê±μØÖ·Âë+0x40;
        X |= 0x80; //Ëã3öÖ¸áîÂë
        lcd_wcom(X); //·¢Ãüáî×Ö
        lcd_wdat(DData); //·¢êy¾Y
1|ÄüÃèêö£oLCD1602°′Ö¸¶¨Î»ÖÃÏÔê¾ò»′®×Ö·û
èë¿ú2Îêy£ouint8 X, uint8 Y, uint8 DData  X′ú±íμúX+1áD£¬Y′ú±íμúY+1DD
·μ»ØÖμ£oÎT
void DisplayListChar(uint8 X, uint8 Y, uint8 *DData)
        uint8 ListLength;
  ListLength = 0;
        Y &= 0x1;
        while (DData[ListLength]>0x19) //èôμ½′ï×Ö′®Î2ÔòíË3ö
                        if (X <= 0xF)        //X×ø±êó|D¡óú0xF
                                        DisplayOneChar(X, Y, DData[ListLength]); //ÏÔê¾μ¥¸ö×Ö·û
                                        ListLength++;
                                        X++;
//¼ÆêyÆ÷¼Æêy
void time0(void) interrupt 1
        m=k;
        n++;
        k=0;
        TH0=65535/256;
  TL0=65535%256;
//¼Æê±Æ÷¼Æê±
void time1(void) interrupt 3
        k++;
        TH1=0xFC;
        TL1=0x18;
/速度和路程計(jì)算并顯示
void calculate(float l,float v)
        uint8 length[7], speed[4];
        //·3ì¸÷λ¼ÆËã
        length[0]=l/10000;
        length[1]=l/1000-length[0]*10;
        length[2]=l/100-length[0]*100-length[1]*10;
        length[3]=l/10-length[0]*1000-length[1]*100-length[2]*10;
        length[4]=l-length[0]*10000-length[1]*1000-length[2]*100-length[3]*10;
        length[5]=ASCII[10];
        length[6]=(l-length[0]*10000-length[1]*1000-length[2]*100-length[3]*10-length[4])*10;
        //Ëù¶è¸÷λ¼ÆËã
        speed[0]=(int)(v*10)/100;
        speed[1]=(int)(v*10)/10%10;
        speed[2]=ASCII[10];
        speed[3]=(int)(v*10)%10;
        //ÏÔê¾Â·3ì
        DisplayOneChar( 2,0 , ASCII[length[0]] );
        DisplayOneChar( 3,0 , ASCII[length[1]] );
        DisplayOneChar( 4,0 , ASCII[length[2]] );
        DisplayOneChar( 5,0 , ASCII[length[3]] );
        DisplayOneChar( 6,0 , ASCII[length[4]] );
        DisplayOneChar( 7,0 , ASCII[10] );
        DisplayOneChar( 8,0 , ASCII[length[6]] );
        DisplayOneChar( 9,0 , ASCII[12] );
         //ÏÔê¾Ëù¶è
        DisplayOneChar( 4, 1, ASCII[10] );
        DisplayOneChar( 6, 1, ASCII[12] );
        DisplayOneChar( 7, 1, ASCII[13] );
        DisplayOneChar( 8, 1, ASCII[14] );
        DisplayOneChar( 2, 1, ASCII[         speed[0]               ] );
        DisplayOneChar( 3, 1, ASCII[            speed[1]                         ] );
        DisplayOneChar( 5, 1, ASCII[                speed[3]            ]           );
//===¼üÖμoˉêy
int Keyboard()
        uint8 k,z;
        int count=0;
        k=KeyScan();
        if(k)
       delay_ms(100);
                         switch(k)
                                case 1:        //°′ϰ′¼üD
                                        z=1;
                                        break;
                                case 2:        //°′ϰ′¼üC
                                        z=2;
                                        break;
                                case 3:        //°′ϰ′¼üB
                                        z=3;
                                        break;
                                case 4:        //°′ϰ′¼üA
                                        z=4;
                                        break;
                                case 5:        //°′ϰ′¼ü#
                                        z=5;
                                        break;
                                case 6:        //°′ϰ′¼ü9
                                        z=6;
                                        break;
                                case 7:        //°′ϰ′¼ü6
                                        z=7;
                                        break;
                                case 8:        //°′ϰ′¼ü3
                                        z=8;
                                        break;
                                case 9:        //°′ϰ′¼ü0
                                        z=9;
                                        break;
                                case 10:        //°′ϰ′¼ü8
                                        z=0;
                                        break;
                 break;
        return z;
//===α¼üÖμoˉêy
int keyboard1()
        int z=0;
        uint8 k;
          k=KeyScan();
          if(k)
                        break;
                if(P25==1)
                        z=1;
                        break;
        return z;
//測(cè)速
int cesu(int t)
        int count;
        float l,v;
        count=0;
        DisplayListChar(0,0,table1);
        DisplayListChar(0,1,table2);       //′óμú¶tDDμú9áD¿aê¼ÏÔê¾ÄúèY2
        k=1;
        while(!n)
                v=0;
                l=2.2*n;
          calculate(l,v);
                if(P25==0)
                        count=1;
                if((P25==1)&&(count==1))
                        delay_ms(150);
                        break;
  while(n)
          l=2.2*n;
          v=2200/m;
                calculate(l,v);
                if(P25==0)
                        count=1;
                        delay_ms(150);
                        break;
        return t;
//推薦
uint32 suggest(uint8 Weight,uint8 Height)
        uint8 suggestion;
        suggestion=(Height-Weight)*1000/8;
        return suggestion;
* Ãè  êö : Ö÷oˉêy
* èë  2Î : ÎT
* ·μ»ØÖμ : ÎT
        uint8 height[3],Height,weight[2],Weight;
  GPIO();
        init();
  lcd_init();                          //òo¾§3õê¼»ˉ
        while(P25==0)
                t=0;
                if(P25==0)
                        delay_ms(150);
                DisplayListChar(0,0,table5);
                DisplayListChar(0,1,table6);
                DisplayOneChar( 10, 0, ASCII[17]);
                DisplayOneChar( 11, 0, ASCII[12]);
                DisplayOneChar( 9, 1, ASCII[15]);
                DisplayOneChar( 10, 1, ASCII[16]);
                if(keyboard1())
                        break;
                height[0]=Keyboard();
                DisplayOneChar( 7, 0, ASCII[height[0]]);
                if(keyboard1())
                        break;
                height[1]=Keyboard();
                DisplayOneChar( 8, 0, ASCII[height[1]]);
                if(keyboard1())
                        break;
                height[2]=Keyboard();
                DisplayOneChar( 9, 0, ASCII[height[2]]);
                if(keyboard1())
                        break;
                weight[0]=Keyboard();
                DisplayOneChar( 7, 1, ASCII[weight[0]]);
                if(keyboard1())
                        break;
                weight[1]=Keyboard();
                DisplayOneChar( 8, 1, ASCII[weight[1]]);
                Weight=weight[0]*10+weight[1];
                Height=height[0]*100+height[1]*10+height[2];
                delay_ms(2500);
                lcd_wcom(0x01);
                  DisplayListChar(0,0,table7);
                  DisplayOneChar(5 , 1, ASCII[12]);
                  DisplayOneChar(0 , 1, ASCII[suggest(Weight,Height)/10000]);
                  DisplayOneChar(1 , 1, ASCII[suggest(Weight,Height)/1000%10]);
                  DisplayOneChar(2 , 1, ASCII[suggest(Weight,Height)/100%10]);
                  DisplayOneChar(3 , 1, ASCII[suggest(Weight,Height)%100/10]);
            DisplayOneChar(4 , 1, ASCII[suggest(Weight,Height)%10]);
                  if(P25==1)
                                break;
        lcd_wcom(0x01);
        while(P25==1)
                if(P25==1)
                        delay_ms(100);
                if(!t)
          cesu(t);
        lcd_wcom(0x01);
建議行駛里程
建議行駛里程
鍵入身高體重
鍵入身高體重
ID:385126 發(fā)表于 2018-9-17 12:29 | 只看該作者
嗯漏了一張圖片...輸入身高體重后顯示的建議內(nèi)容是  00093M,反正無(wú)論輸入什么,基本上建議都是兩三位數(shù),為什么計(jì)算的結(jié)果不能正確顯示呢
