查看: 2063|回復(fù): 1
在數(shù)碼管顯示的時候問什么沒有指定的數(shù)碼管會跟著各位或者十位數(shù)字變化顯示,
ID:399373 發(fā)表于 2018-9-18 09:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#define Data_Outport P0
sbit Lotch_Duan=P2^2;
sbit Lotch_Wei=P2^3;
sbit KEY_ADD=P3^3;
sbit KEY_DEC=P3^4;
void delay1(unsigned int t);
void delay2(unsigned int t);
void disply(unsigned char FirstBit,unsigned char Num);
unsigned char code Wei_Ma[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char code Duan_Ma[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
unsigned char Huan_Chun[8];
void Shi_Jian(void);
{         unsigned char num=0;
    Shi_Jian();
                    if(KEY_ADD==0)
                    delay2(10);
                        if(KEY_ADD==0)
                           while(!KEY_ADD);
                                    if(num<99)
                                  num++;
                 if(KEY_DEC==0)
                    delay2(10);
                        if(KEY_DEC==0)
                           while(!KEY_DEC);
                                    if(num>0)
                                  num--;
                 Huan_Chun[0]=Duan_Ma[num/10];
                 Huan_Chun[1]=Duan_Ma[num%10];
   while(--t);
    while(t--)
     //大致延時1mS
     delay1(245);
         delay1(245);
static unsigned char i=0;
    Data_Outport=0;
        Lotch_Duan=1;
        Lotch_Duan=0;
        Data_Outport=Huan_Chun[i];
        Lotch_Duan=1;
        Lotch_Duan=0;
        Data_Outport=Wei_Ma[i+FirstBit];
        Lotch_Wei=1;
        Lotch_Wei=0;
        i++;
        if(i==Num)
            i=0;
void Shi_Jian(void)
   TMOD |=0x01;
   TH0=(65536-2000)/256;
   TL0=(65536-2000)%256;
   EA=1;
   ET0=1;
   TR0=1;
void Ding_Shi(void)interrupt 1
        disply(0,8);
ID:387733 發(fā)表于 2018-9-18 18:59 | 只看該作者
        Data_Outport=0;
        Lotch_Duan=1;
        Lotch_Duan=0;
        Lotch_Wei=1;
        Lotch_Wei=0;
        Lotch_Duan=1;
        Lotch_Duan=0;
        i++;
        if(i==Num)
            i=0;
次序換一下,先關(guān)閉段碼,再設(shè)置位碼,然后打開段碼。否則位還沒換,就打開段碼,顯示就錯位了
參與人數(shù) 1黑幣 +40 收起 理由
admin + 40 回帖助人的獎勵!
