這是我在網(wǎng)上找的最詳細的資料了, 針對 ADXL345 三軸G重力加速 sensor 最新的原理圖, 單芯片說明書, ST源成碼, Arduino 代碼. 希望對你有幫助. 如果覺得好用, 別忘了打賞 !
Arduino .h 代碼: - /**************************************************************************/
- @file Adafruit_ADS1015.h
- @author K. Townsend (Adafruit Industries)
- @license BSD (see license.txt)
- This is a library for the Adafruit ADS1015 breakout board
- ----> https://www.adafruit.com/products/???
- Adafruit invests time and resources providing this open source code,
- please support Adafruit and open-source hardware by purchasing
- products from Adafruit!
- @section HISTORY
- v1.0 - First release
- #if ARDUINO >= 100
- #include "Arduino.h"
- #else
- #include "WProgram.h"
- #endif
- #include <Adafruit_Sensor.h>
- #include <Wire.h>
- I2C ADDRESS/BITS
- #define ADXL345_ADDRESS (0x53) // Assumes ALT address pin low
- REGISTERS
- #define ADXL345_REG_DEVID (0x00) // Device ID
- #define ADXL345_REG_THRESH_TAP (0x1D) // Tap threshold
- #define ADXL345_REG_OFSX (0x1E) // X-axis offset
- #define ADXL345_REG_OFSY (0x1F) // Y-axis offset
- #define ADXL345_REG_OFSZ (0x20) // Z-axis offset
- #define ADXL345_REG_DUR (0x21) // Tap duration
- #define ADXL345_REG_LATENT (0x22) // Tap latency
- #define ADXL345_REG_WINDOW (0x23) // Tap window
- #define ADXL345_REG_THRESH_ACT (0x24) // Activity threshold
- #define ADXL345_REG_THRESH_INACT (0x25) // Inactivity threshold
- #define ADXL345_REG_TIME_INACT (0x26) // Inactivity time
- #define ADXL345_REG_ACT_INACT_CTL (0x27) // Axis enable control for activity and inactivity detection
- #define ADXL345_REG_THRESH_FF (0x28) // Free-fall threshold
- #define ADXL345_REG_TIME_FF (0x29) // Free-fall time
- #define ADXL345_REG_TAP_AXES (0x2A) // Axis control for single/double tap
- #define ADXL345_REG_ACT_TAP_STATUS (0x2B) // Source for single/double tap
- #define ADXL345_REG_BW_RATE (0x2C) // Data rate and power mode control
- #define ADXL345_REG_POWER_CTL (0x2D) // Power-saving features control
- #define ADXL345_REG_INT_ENABLE (0x2E) // Interrupt enable control
- #define ADXL345_REG_INT_MAP (0x2F) // Interrupt mapping control
- #define ADXL345_REG_INT_SOURCE (0x30) // Source of interrupts
- #define ADXL345_REG_DATA_FORMAT (0x31) // Data format control
- #define ADXL345_REG_DATAX0 (0x32) // X-axis data 0
- #define ADXL345_REG_DATAX1 (0x33) // X-axis data 1
- #define ADXL345_REG_DATAY0 (0x34) // Y-axis data 0
- #define ADXL345_REG_DATAY1 (0x35) // Y-axis data 1
- #define ADXL345_REG_DATAZ0 (0x36) // Z-axis data 0
- #define ADXL345_REG_DATAZ1 (0x37) // Z-axis data 1
- #define ADXL345_REG_FIFO_CTL (0x38) // FIFO control
- #define ADXL345_REG_FIFO_STATUS (0x39) // FIFO status
- REGISTERS
- #define ADXL345_MG2G_MULTIPLIER (0.004) // 4mg per lsb
- /* Used with register 0x2C (ADXL345_REG_BW_RATE) to set bandwidth */
- typedef enum
- ADXL345_DATARATE_3200_HZ = 0b1111, // 1600Hz Bandwidth 140渙 IDD
- ADXL345_DATARATE_1600_HZ = 0b1110, // 800Hz Bandwidth 90渙 IDD
- ADXL345_DATARATE_800_HZ = 0b1101, // 400Hz Bandwidth 140渙 IDD
- ADXL345_DATARATE_400_HZ = 0b1100, // 200Hz Bandwidth 140渙 IDD
- ADXL345_DATARATE_200_HZ = 0b1011, // 100Hz Bandwidth 140渙 IDD
- ADXL345_DATARATE_100_HZ = 0b1010, // 50Hz Bandwidth 140渙 IDD
- ADXL345_DATARATE_50_HZ = 0b1001, // 25Hz Bandwidth 90渙 IDD
- ADXL345_DATARATE_25_HZ = 0b1000, // 12.5Hz Bandwidth 60渙 IDD
- ADXL345_DATARATE_12_5_HZ = 0b0111, // 6.25Hz Bandwidth 50渙 IDD
- ADXL345_DATARATE_6_25HZ = 0b0110, // 3.13Hz Bandwidth 45渙 IDD
- ADXL345_DATARATE_3_13_HZ = 0b0101, // 1.56Hz Bandwidth 40渙 IDD
- ADXL345_DATARATE_1_56_HZ = 0b0100, // 0.78Hz Bandwidth 34渙 IDD
- ADXL345_DATARATE_0_78_HZ = 0b0011, // 0.39Hz Bandwidth 23渙 IDD
- ADXL345_DATARATE_0_39_HZ = 0b0010, // 0.20Hz Bandwidth 23渙 IDD
- ADXL345_DATARATE_0_20_HZ = 0b0001, // 0.10Hz Bandwidth 23渙 IDD
- ADXL345_DATARATE_0_10_HZ = 0b0000 // 0.05Hz Bandwidth 23渙 IDD (default value)
- } dataRate_t;
- /* Used with register 0x31 (ADXL345_REG_DATA_FORMAT) to set g range */
- typedef enum
- ADXL345_RANGE_16_G = 0b11, // +/- 16g
- ADXL345_RANGE_8_G = 0b10, // +/- 8g
- ADXL345_RANGE_4_G = 0b01, // +/- 4g
- ADXL345_RANGE_2_G = 0b00 // +/- 2g (default value)
- } range_t;
- class Adafruit_ADXL345_Unified : public Adafruit_Sensor {
- public:
- Adafruit_ADXL345_Unified(int32_t sensorID = -1);
- Adafruit_ADXL345_Unified(uint8_t clock, uint8_t miso, uint8_t mosi, uint8_t cs, int32_t sensorID = -1);
- bool begin(void);
- void setRange(range_t range);
- range_t getRange(void);
- void setDataRate(dataRate_t dataRate);
- dataRate_t getDataRate(void);
- bool getEvent(sensors_event_t*);
- void getSensor(sensor_t*);
- uint8_t getDeviceID(void);
- void writeRegister(uint8_t reg, uint8_t value);
- uint8_t readRegister(uint8_t reg);
- int16_t read16(uint8_t reg);
- int16_t getX(void), getY(void), getZ(void);
- private:
- inline uint8_t i2cread(void);
- inline void i2cwrite(uint8_t x);
- int32_t _sensorID;
- range_t _range;
- uint8_t _clk, _do, _di, _cs;
- bool _i2c;
Arduino .cpp代碼: - /**************************************************************************/
- @file Adafruit_ADXL345.cpp
- @author K.Townsend (Adafruit Industries)
- The ADXL345 is a digital accelerometer with 13-bit resolution, capable
- of measuring up to +/-16g. This driver communicate using I2C.
- This is a library for the Adafruit ADXL345 breakout
- ----> https://www.adafruit.com/products/1231
- @section HISTORY
- v1.1 - Added Adafruit_Sensor library support
- #else
- #endif
- #include <Wire.h>
- #include <limits.h>
- #include "Adafruit_ADXL345_U.h"
- @brief Abstract away platform differences in Arduino wire library
- inline uint8_t Adafruit_ADXL345_Unified::i2cread(void) {
- return Wire.read();
- #else
- return Wire.receive();
- #endif
- inline void Adafruit_ADXL345_Unified::i2cwrite(uint8_t x) {
- Wire.write((uint8_t)x);
- #else
- Wire.send(x);
- #endif
- @brief Abstract away SPI receiver & transmitter
- static uint8_t spixfer(uint8_t clock, uint8_t miso, uint8_t mosi, uint8_t data) {
- uint8_t reply = 0;
- for (int i=7; i>=0; i--) {
- reply <<= 1;
- digitalWrite(clock, LOW);
- digitalWrite(mosi, data & (1<<i));
- digitalWrite(clock, HIGH);
- if (digitalRead(miso))
- reply |= 1;
- return reply;
- @brief Writes 8-bits to the specified destination register
- void Adafruit_ADXL345_Unified::writeRegister(uint8_t reg, uint8_t value) {
- if (_i2c) {
- Wire.beginTransmission(ADXL345_ADDRESS);
- i2cwrite((uint8_t)reg);
- i2cwrite((uint8_t)(value));
- Wire.endTransmission();
- } else {
- digitalWrite(_cs, LOW);
- spixfer(_clk, _di, _do, reg);
- spixfer(_clk, _di, _do, value);
- digitalWrite(_cs, HIGH);
- @brief Reads 8-bits from the specified register
- uint8_t Adafruit_ADXL345_Unified::readRegister(uint8_t reg) {
- if (_i2c) {
- i2cwrite(reg);
- Wire.requestFrom(ADXL345_ADDRESS, 1);
- return (i2cread());
- } else {
- reg |= 0x80; // read byte
- uint8_t reply = spixfer(_clk, _di, _do, 0xFF);
- return reply;
- @brief Reads 16-bits from the specified register
- int16_t Adafruit_ADXL345_Unified::read16(uint8_t reg) {
- if (_i2c) {
- i2cwrite(reg);
- Wire.requestFrom(ADXL345_ADDRESS, 2);
- return (uint16_t)(i2cread() | (i2cread() << 8));
- } else {
- reg |= 0x80 | 0x40; // read byte | multibyte
- uint16_t reply = spixfer(_clk, _di, _do, 0xFF) | (spixfer(_clk, _di, _do, 0xFF) << 8);
- return reply;
- @brief Read the device ID (can be used to check connection)
- uint8_t Adafruit_ADXL345_Unified::getDeviceID(void) {
- // Check device ID register
- return readRegister(ADXL345_REG_DEVID);
- @brief Gets the most recent X axis value
- int16_t Adafruit_ADXL345_Unified::getX(void) {
- return read16(ADXL345_REG_DATAX0);
- @brief Gets the most recent Y axis value
- int16_t Adafruit_ADXL345_Unified::getY(void) {
- return read16(ADXL345_REG_DATAY0);
- @brief Gets the most recent Z axis value
- int16_t Adafruit_ADXL345_Unified::getZ(void) {
- return read16(ADXL345_REG_DATAZ0);
- @brief Instantiates a new ADXL345 class
- Adafruit_ADXL345_Unified::Adafruit_ADXL345_Unified(int32_t sensorID) {
- _sensorID = sensorID;
- _range = ADXL345_RANGE_2_G;
- _i2c = true;
- @brief Instantiates a new ADXL345 class in SPI mode
- Adafruit_ADXL345_Unified::Adafruit_ADXL345_Unified(uint8_t clock, uint8_t miso, uint8_t mosi, uint8_t cs, int32_t sensorID) {
- _cs = cs;
- _clk = clock;
- _do = mosi;
- _di = miso;
- _i2c = false;
- @brief Setups the HW (reads coefficients values, etc.)
- bool Adafruit_ADXL345_Unified::begin() {
- if (_i2c)
- Wire.begin();
- else {
- pinMode(_cs, OUTPUT);
- pinMode(_clk, OUTPUT);
- digitalWrite(_clk, HIGH);
- pinMode(_do, OUTPUT);
- pinMode(_di, INPUT);
- /* Check connection */
- uint8_t deviceid = getDeviceID();
- if (deviceid != 0xE5)
- /* No ADXL345 detected ... return false */
- Serial.println(deviceid, HEX);
- return false;
- // Enable measurements
- writeRegister(ADXL345_REG_POWER_CTL, 0x08);
- return true;
- @brief Sets the g range for the accelerometer
- void Adafruit_ADXL345_Unified::setRange(range_t range)
- /* Red the data format register to preserve bits */
- uint8_t format = readRegister(ADXL345_REG_DATA_FORMAT);
- /* Update the data rate */
- format &= ~0x0F;
- format |= range;
- /* Make sure that the FULL-RES bit is enabled for range scaling */
- format |= 0x08;
- /* Write the register back to the IC */
- writeRegister(ADXL345_REG_DATA_FORMAT, format);
- /* Keep track of the current range (to avoid readbacks) */
- _range = range;
- range_t Adafruit_ADXL345_Unified::getRange(void)
- return (range_t)(readRegister(ADXL345_REG_DATA_FORMAT) & 0x03);
- @brief Sets the data rate for the ADXL345 (controls power consumption)
- void Adafruit_ADXL345_Unified::setDataRate(dataRate_t dataRate)
- /* Note: The LOW_POWER bits are currently ignored and we always keep
- the device in 'normal' mode */
- writeRegister(ADXL345_REG_BW_RATE, dataRate);
- dataRate_t Adafruit_ADXL345_Unified::getDataRate(void)
- return (dataRate_t)(readRegister(ADXL345_REG_BW_RATE) & 0x0F);
- @brief Gets the most recent sensor event
- bool Adafruit_ADXL345_Unified::getEvent(sensors_event_t *event) {
- /* Clear the event */
- memset(event, 0, sizeof(sensors_event_t));
- event->version = sizeof(sensors_event_t);
- event->sensor_id = _sensorID;
- event->type = SENSOR_TYPE_ACCELEROMETER;
- event->timestamp = 0;
- event->acceleration.x = getX() * ADXL345_MG2G_MULTIPLIER * SENSORS_GRAVITY_STANDARD;
- event->acceleration.y = getY() * ADXL345_MG2G_MULTIPLIER * SENSORS_GRAVITY_STANDARD;
- event->acceleration.z = getZ() * ADXL345_MG2G_MULTIPLIER * SENSORS_GRAVITY_STANDARD;
- return true;
- @brief Gets the sensor_t data
- void Adafruit_ADXL345_Unified::getSensor(sensor_t *sensor) {
- /* Clear the sensor_t object */
- memset(sensor, 0, sizeof(sensor_t));
- /* Insert the sensor name in the fixed length char array */
- strncpy (sensor->name, "ADXL345", sizeof(sensor->name) - 1);
- sensor->name[sizeof(sensor->name)- 1] = 0;
- sensor->version = 1;
- sensor->sensor_id = _sensorID;
- sensor->type = SENSOR_TYPE_PRESSURE;
- sensor->min_delay = 0;
- sensor->max_value = -156.9064F; /* -16g = 156.9064 m/s^2 */
- sensor->min_value = 156.9064F; /* 16g = 156.9064 m/s^2 */
- sensor->resolution = 0.03923F; /* 4mg = 0.0392266 m/s^2 */
Arduino 測試程序: - //***************************************
- // GY-29 ADXL345 IIC
- #include <REG51.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- #define DataPort P0 //LCD1602杅擂傷諳
- sbit SCL=P1^0; //IIC奀笘竘褐隅砱
- sbit SDA=P1^1; //IIC杅擂竘褐隅砱
- sbit LCM_RS=P2^0; //LCD1602韜鍔傷諳
- sbit LCM_RW=P2^1; //LCD1602韜鍔傷諳
- sbit LCM_EN=P2^2; //LCD1602韜鍔傷諳
- #define SlaveAddress 0xA6 //隅砱璃婓IIC軞盄笢腔植華硊,跦擂ALT ADDRESS華硊竘褐祥骯黨蜊
- //ALT ADDRESS竘褐諉華奀華硊峈0xA6ㄛ諉萇埭奀華硊峈0x3A
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- BYTE BUF[8]; //諉彶杅擂遣湔
- uchar ge,shi,bai,qian,wan; //珆尨曹講
- int dis_data; //曹講
- void delay(unsigned int k);
- void InitLcd(); //場宎趙lcd1602
- void Init_ADXL345(void); //場宎趙ADXL345
- void WriteDataLCM(uchar dataW);
- void WriteCommandLCM(uchar CMD,uchar Attribc);
- void DisplayOneChar(uchar X,uchar Y,uchar DData);
- void conversion(uint temp_data);
- void Single_Write_ADXL345(uchar REG_Address,uchar REG_data); //等跺迡杅擂
- uchar Single_Read_ADXL345(uchar REG_Address); //等跺黍囀窒敵湔杅擂
- void Multiple_Read_ADXL345(); //蟀哿腔黍囀窒敵湔杅擂
- void Delay5us();
- void Delay5ms();
- void ADXL345_Start();
- void ADXL345_Stop();
- void ADXL345_SendACK(bit ack);
- bit ADXL345_RecvACK();
- void ADXL345_SendByte(BYTE dat);
- BYTE ADXL345_RecvByte();
- void ADXL345_ReadPage();
- void ADXL345_WritePage();
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //豻堍呾
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //豻堍呾
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //豻堍呾
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //豻堍呾
- ge=temp_data+0x30;
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- void WaitForEnable(void)
- DataPort=0xff;
- LCM_RS=0;LCM_RW=1;_nop_();
- LCM_EN=1;_nop_();_nop_();
- while(DataPort&0x80);
- LCM_EN=0;
- if(Attribc)WaitForEnable();
- LCM_RS=0;LCM_RW=0;_nop_();
- DataPort=CMD;_nop_();
- LCM_EN=1;_nop_();_nop_();LCM_EN=0;
- WaitForEnable();
- LCM_RS=1;LCM_RW=0;_nop_();
- DataPort=dataW;_nop_();
- void InitLcd()
- WriteCommandLCM(0x38,1);
- WriteCommandLCM(0x08,1);
- WriteCommandLCM(0x01,1);
- WriteCommandLCM(0x06,1);
- WriteCommandLCM(0x0c,1);
- Y&=1;
- X&=15;
- if(Y)X|=0x40;
- X|=0x80;
- WriteCommandLCM(X,0);
- WriteDataLCM(DData);
- 晊奀5峚鏃(STC90C52RC@12M)
- 祥骯腔馱釬遠噫,剒猁覃淕森滲杅ㄛ蛁砩奀笘徹辦奀剒猁黨蜊
- 絞蜊蚚1T腔MCU奀,覃淕森晊奀滲杅
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- 晊奀5瑭鏃(STC90C52RC@12M)
- 祥骯腔馱釬遠噫,剒猁覃淕森滲杅
- void Delay5ms()
- WORD n = 560;
- while (n--);
- 宎陓瘍
- SDA = 1; //嶺詢杅擂盄
- SCL = 1; //嶺詢奀笘盄
- Delay5us(); //晊奀
- SDA = 0; //莉汜狟蔥朓
- Delay5us(); //晊奀
- SCL = 0; //嶺腴奀笘盄
- 礿砦陓瘍
- SDA = 0; //嶺腴杅擂盄
- SCL = 1; //嶺詢奀笘盄
- Delay5us(); //晊奀
- SDA = 1; //莉汜奻汔朓
- Delay5us(); //晊奀
- 楷冞茼湘陓瘍
- 諳統(tǒng)杅:ack (0:ACK 1:NAK)
- SDA = ack; //迡茼湘陓瘍
- SCL = 1; //嶺詢奀笘盄
- Delay5us(); //晊奀
- SCL = 0; //嶺腴奀笘盄
- Delay5us(); //晊奀
- 諉彶茼湘陓瘍
- SCL = 1; //嶺詢奀笘盄
- Delay5us(); //晊奀
- CY = SDA; //黍茼湘陓瘍
- SCL = 0; //嶺腴奀笘盄
- Delay5us(); //晊奀
- return CY;
- 砃IIC軞盄楷冞珨跺趼誹杅擂
- BYTE i;
- for (i=0; i<8; i++) //8弇數(shù)杅
- dat <<= 1; //痄堤杅擂腔郔詢弇
- SDA = CY; //冞杅擂諳
- SCL = 1; //嶺詢奀笘盄
- Delay5us(); //晊奀
- SCL = 0; //嶺腴奀笘盄
- Delay5us(); //晊奀
- ADXL345_RecvACK();
- 植IIC軞盄諉彶珨跺趼誹杅擂
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //妏夔囀窒奻嶺,袧掘黍杅擂,
- dat <<= 1;
- SCL = 1; //嶺詢奀笘盄
- Delay5us(); //晊奀
- dat |= SDA; //黍杅擂
- SCL = 0; //嶺腴奀笘盄
- Delay5us(); //晊奀
- return dat;
- //******等趼誹迡*******************************************
- ADXL345_Start(); //宎陓瘍
- ADXL345_SendByte(SlaveAddress); //楷冞扢掘華硊+迡陓瘍
- ADXL345_SendByte(REG_Address); //囀窒敵湔華硊ㄛ統(tǒng)蕉笢恅pdf22珜
- ADXL345_SendByte(REG_data); //囀窒敵湔杅擂ㄛ統(tǒng)蕉笢恅pdf22珜
- ADXL345_Stop(); //楷冞礿砦陓瘍
- //********等趼誹黍*****************************************
- { uchar REG_data;
- ADXL345_SendByte(REG_Address); //楷冞湔揣等啋華硊ㄛ植0羲宎
- ADXL345_SendByte(SlaveAddress+1); //楷冞扢掘華硊+黍陓瘍
- REG_data=ADXL345_RecvByte(); //黍堤敵湔杅擂
- ADXL345_SendACK(1);
- ADXL345_Stop(); //礿砦陓瘍
- return REG_data;
- //蟀哿黍堤ADXL345囀窒樓厒僅杅擂ㄛ華硊毓峓0x32~0x37
- void Multiple_read_ADXL345(void)
- { uchar i;
- ADXL345_SendByte(0x32); //楷冞湔揣等啋華硊ㄛ植0x32羲宎
- for (i=0; i<6; i++) //蟀哿黍6跺華硊杅擂ㄛ湔揣笢BUF
- BUF[i] = ADXL345_RecvByte(); //BUF[0]湔揣0x32華硊笢腔杅擂
- if (i == 5)
- ADXL345_SendACK(1); //郔綴珨跺杅擂剒猁隙NOACK
- else
- ADXL345_SendACK(0); //隙茼ACK
- Delay5ms();
- //場宎趙ADXL345ㄛ跦擂剒猁統(tǒng)蕉pdf輛俴黨蜊************************
- void Init_ADXL345()
- Single_Write_ADXL345(0x31,0x0B); //聆講毓峓,淏蛹16gㄛ13弇耀宒
- Single_Write_ADXL345(0x2C,0x08); //厒薹扢隅峈12.5 統(tǒng)蕉pdf13珜
- Single_Write_ADXL345(0x2D,0x08); //恁寁萇埭耀宒 統(tǒng)蕉pdf24珜
- Single_Write_ADXL345(0x2E,0x80); //妏夔 DATA_READY 笢剿
- Single_Write_ADXL345(0x1E,0x00); //X 痄講 跦擂聆彸換覜腔袨怓迡pdf29珜
- Single_Write_ADXL345(0x1F,0x00); //Y 痄講 跦擂聆彸換覜腔袨怓迡pdf29珜
- Single_Write_ADXL345(0x20,0x05); //Z 痄講 跦擂聆彸換覜腔袨怓迡pdf29珜
- //珆尨x粣
- void display_x()
- { float temp;
- dis_data=(BUF[1]<<8)+BUF[0]; //磁傖杅擂
- if(dis_data<0){
- dis_data=-dis_data;
- DisplayOneChar(2,0,'-'); //珆尨淏蛹睫瘍弇
- else DisplayOneChar(2,0,' '); //珆尨諾跡
- temp=(float)dis_data*3.9; //數(shù)呾杅擂睿珆尨,脤蕉ADXL345辦厒藷菴4珜
- conversion(temp); //蛌遙堤珆尨剒猁腔杅擂
- DisplayOneChar(0,0,'X'); //菴0俴ㄛ菴0蹈 珆尨X
- DisplayOneChar(1,0,':');
- DisplayOneChar(3,0,qian);
- DisplayOneChar(4,0,'.');
- DisplayOneChar(5,0,bai);
- DisplayOneChar(6,0,shi);
- DisplayOneChar(7,0,'g');
- //珆尨y粣
- void display_y()
- { float temp;
- dis_data=(BUF[3]<<8)+BUF[2]; //磁傖杅擂
- if(dis_data<0){
- DisplayOneChar(2,1,'-'); //珆尨淏蛹睫瘍弇
- else DisplayOneChar(2,1,' '); //珆尨諾跡
- DisplayOneChar(0,1,'Y'); //菴1俴ㄛ菴0蹈 珆尨y
- DisplayOneChar(1,1,':');
- DisplayOneChar(3,1,qian);
- DisplayOneChar(4,1,'.');
- DisplayOneChar(5,1,bai);
- DisplayOneChar(6,1,shi);
- DisplayOneChar(7,1,'g');
- //珆尨z粣
- void display_z()
- { float temp;
- dis_data=(BUF[5]<<8)+BUF[4]; //磁傖杅擂
- if(dis_data<0){
- DisplayOneChar(10,1,'-'); //珆尨蛹睫瘍弇
- else DisplayOneChar(10,1,' '); //珆尨諾跡
- DisplayOneChar(10,0,'Z'); //菴0俴ㄛ菴10蹈 珆尨Z
- DisplayOneChar(11,0,':');
- DisplayOneChar(11,1,qian);
- DisplayOneChar(12,1,'.');
- DisplayOneChar(13,1,bai);
- DisplayOneChar(14,1,shi);
- DisplayOneChar(15,1,'g');
- //******翋最唗********
- void main()
- uchar devid;
- delay(500); //奻萇晊奀
- InitLcd(); //珘儒場宎趙ADXL345
- Init_ADXL345(); //場宎趙ADXL345
- devid=Single_Read_ADXL345(0X00);//黍堤腔杅擂峈0XE5,桶尨淏
- while(1) //悜遠
- Multiple_Read_ADXL345(); //蟀哿黍堤杅擂ㄛ湔揣婓BUF笢
- display_x(); //---------珆尨X粣
- display_y(); //---------珆尨Y粣
- display_z(); //---------珆尨Z粣
- delay(200); //晊奀
