fdc2214 oled 電容測試程序,用的是msp430f5529單片機
2018-9-20 04:29 上傳
單片機源程序如下:
- * @file FDC2214.c
- * @author BOB
- * @version V1.0
- * @date 2018-07-5
- * @email
- * @brief FDC2214配置及數(shù)據(jù)讀取函數(shù)
- #include <io430.h>
- #include "fdc2214.h"
- #include "iic.h"
- #include "math.h"
- #include "Config.h"
- //ADDR和SD引腳初始化
- #define FDC_ADDR_0 P1OUT &= ~BIT4 //FDC_ADDR置低
- #define FDC_ADDR_1 P1OUT |= BIT4 //FDC_ADDR置高
- #define FDC_SD_0 P1OUT &= ~BIT5 //FDC_SD置低
- #define FDC_SD_1 P1OUT |= BIT5 //FDC_SD置高
- * 函數(shù)名:ADDR_SD_Init
- * 描述 :配置LDC用到的I/O口
- ADDR--PC11
- SD --PC12
- * 輸入 :無
- * 輸出 :無
- void ADDR_SD_Init(void) //ADDR和SD引腳初始化
- * 函數(shù)名:InitFDC2214
- * 描述 :初始化FDC2214
- * 輸入 :無
- * 輸出 :retVal 0 and 1
- u8 FDC2214_init(void)
- u16 id;
- u8 retVal=1;
- u8 ErrCount = 0;
- FDC_ADDR_0;// ADDR=0(FDC2214_IIC地址選擇=0X2A) // ADDR=1(FDC2214_IIC地址選擇=0X2B)
- FDC_SD_0; // SD=0開啟輸入 // SD=1關閉輸入
- default_addr = EVM_DEFAULT_I2CADDR; //FDC2214地址選擇暫存
- delay_ms(10);
- // software reset
- MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_RESET_DEVICE,0x8000);
- delay_ms(10);
- do
- if (ErrCount++ > 50)
- return 0;
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_REF_COUNT_CH0,0xFFFF); // 4 clock periods
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_REF_COUNT_CH1,0xFFFF);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_REF_COUNT_CH2,0xFFFF);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_REF_COUNT_CH3,0xFFFF);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_OFFSET_CH0,0x0000); //補償值
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_OFFSET_CH1,0x0000);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_OFFSET_CH2,0x0000);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_OFFSET_CH3,0x0000);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_SETTLE_COUNT_CH0,0x0400); // 1 clock period
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_SETTLE_COUNT_CH1,0x0400);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_SETTLE_COUNT_CH2,0x0400);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_SETTLE_COUNT_CH3,0x0400);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_CLOCK_DIVIDERS_CH0,0x1001); // 1000
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_CLOCK_DIVIDERS_CH1,0x1001);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_CLOCK_DIVIDERS_CH2,0x1001);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_CLOCK_DIVIDERS_CH3,0x1001);
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_DRIVE_CURRENT_CH0,0xF800); //
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_DRIVE_CURRENT_CH1,0xF800); //
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_DRIVE_CURRENT_CH2,0xF800); //
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_DRIVE_CURRENT_CH3,0xF800); //
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_ERROR_CONFIG,0x0001); // report only DRDYs to INT
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_MUX_CONFIG,0xC20C); // ch0, ch1,ch2,ch3-> Wipro for 4 ch
- retVal &= MPU_Write_2Byte(default_addr,LDC13xx16xx_CMD_CONFIG,0x1E01); // CLKIN pin1281
- }while(retVal!=0);
- // id=MPU_Read_2Byte(default_addr,LDC13xx16xx_CMD_DEVID);//讀設備ID
- // if(id==0x3055||id==0x3054)
- // return 1;
- // else
- // return 0;
- return 1;
- * 函數(shù)名:evm_processDRDY
- * 描述 :讀取寄存器數(shù)據(jù)
- * 輸入 :無
- * 輸出 :無
- void evm_processDRDY(unsigned long allData[4])
- u8 i=0;
- unsigned long reading = 0;
- float CAP_Data[4];
- float conver = 0; //最終的轉換的結果
- for(i=0;i<=3;i++)
- { //0x0FFF 最高到只28位
- reading = (unsigned long)(MPU_Read_2Byte(default_addr,i*2) & 0x0FFF) << 16;
- reading |= MPU_Read_2Byte(default_addr,(i*2)+1);
- allData[i]=reading;
- //CAP_Data[i]=reading;
- reading=0;
- //***注意Init中各通道寄存器0x10-0x17的時鐘分頻***//
- //*******以下四步計算根據(jù)datasheet P19公式*******//
- for(i=0;i<=3;i++)
- CAP_Data[i] = (CAP_Data[i] * 40000000.0F)/268435456.0F;//得到F(sensorx)
- CAP_Data[i] = CAP_Data[i] * 2.0F *3.1515926F;
- CAP_Data[i] = 1.0F/((CAP_Data[i] * CAP_Data[i]) * 0.000018F);
- CAP_Data[i] = CAP_Data[i] - 0.000000000033F;
- CAP_Data[i] = CAP_Data[i] * 1000000000000.0F;//F轉換pF;
- //allData[i]=CAP_Data[i];
- /******FDC2214檢測電容值程序********/
- double GetCapacitance(unsigned long value)
- double pi = 3.14159265359;
- double L = 18; //uH
- double Cboard = 33; //pf
- double Cparacitic = 3; //pf
- unsigned long long fsensor;
- double temp;
- fsensor = 1 * 40000000 * value;
- fsensor = fsensor / pow(2,28);
- temp = 2 * pi * fsensor;
- temp = temp * temp;
- temp = temp / 1000000; //uH
- temp *= L;
- return temp;
復制代碼
FDC2214程序TI430 OLED0.96(V3.0).zip
(1.52 MB, 下載次數(shù): 68)
2018-9-19 21:20 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
