查看: 11375|回復(fù): 1
A4950引腳圖與pdf數(shù)據(jù)手冊下載
ID:401298 發(fā)表于 2018-9-22 13:45 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
A4950引腳圖和管腳功能定義如下:
A4950內(nèi)部結(jié)構(gòu)框圖:
A4950數(shù)據(jù)手冊
Description
Designed for pulse width modulated (PWM) control of DC
motors, the A4950 is capable of peak output currents to ±3.5 A
and operating voltages to 40 V.
Input terminals are provided for use in controlling the speed and
direction of a DC motor with externally applied PWM control
signals. Internal synchronous rectification control circuitry is
provided to lower power dissipation during PWM operation.
Internal circuit protection includes overcurrent protection,
motor lead short to ground or supply, thermal shutdown with
hysteresis, undervoltage monitoring of VBB, and crossover-
current protection.
For high ambient operating temperature applications, an
automotive grade device is offered (A4950K). The K grade
device is tested across extended temperature and voltage
ranges to ensure compliance in automotive or industrial
applications.
The A4950 is provided in a low-profile 8-pin SOICN package
with exposed thermal pad (suffix LJ) that is lead (Pb) free, with
100% matte tin leadframe plating.
完整的pdf格式文檔51黑下載地址:
a4950-datasheet.pdf (225.81 KB, 下載次數(shù): 111)
收藏收藏1 分享淘帖 頂1 踩
ID:333249 發(fā)表于 2020-7-18 14:58 | 只看該作者
為什么這MOS管會有4個引腳?
