#include "INT.h"
void INT_Initial(void)
INTEDG = 0; //0 下降沿觸發(fā) 1 上升沿觸發(fā)
TRISBbits.TRISB0 = 1; //RB0設(shè)置為輸入
LATBbits.LATB0 = 1; //設(shè)置初始狀態(tài)位高電平 , 為下降沿觸發(fā)中斷做準(zhǔn)備
INTCONbits.GIE = 1; //允許所有中斷
INTCONbits.PEIE = 1; //允許外設(shè)中斷
/*外部中斷初始位*/
INTCONbits.INTE = 1; //允許外部中斷
INTCONbits.INTF = 0; //外部中斷標(biāo)志位清0
/*定時(shí)器0中斷初始位*/
INTCONbits.TMR0IE = 1; //允許定時(shí)器0溢出中斷
INTCONbits.TMR0IF = 0; //定時(shí)器0溢出中斷標(biāo)志位清0
/*定時(shí)器1中斷初始位*/
PIE1bits.TMR1IE = 1; //允許定時(shí)器1溢出中斷
PIR1bits.TMR1IF = 0; //定時(shí)器1溢出中斷標(biāo)志位清0
/*ADC中斷初始位*/
PIE1bits.ADIE = 1; //允許ADC中斷
PIR1bits.ADIF = 0; //ADC中斷標(biāo)志位清0
void Get_KeyValue(void)
if((timing_s_count2 - key_keep_time) < 1)
switch (key_value_buffer){
case 0xFE://S1 K1 RF0
KeyCode = KEY_ENTER;
break;
// case 0xFD://S3 K2 RF1
// KeyCode = KEY_UP;
// break;
case 0xFB://S5 K3 RF2
KeyCode = KEY_LIGHT;
break;
// case 0xF7://S7 K4 RF3
// KeyCode = KEY_DOWN;
// break;
case 0xEF://S2 K5 RF4
KeyCode = KEY_BACK;
break;
case 0xDF://S4 K6 RF5
KeyCode = KEY_FAN;
break;
// case 0xBF://S6 K7 RF6
// KeyCode = KEY_STDBY;
// break;
case 0x7F://S8 K8 RF7
KeyCode = KEY_SETUP;
break;
default:
KeyCode = 0;
break;
key_action_flag = 0;
void Get_key_valve_Long_press(void)
if((timing_s_count2 - key_keep_time) > 1)
case 0xFE:
break;
break;
default:
key_action_flag_Long_press = 0;
break;
void Get_key_valve_continuty(void)
if(key_action_flag_continuty == 1)
switch (PORTF){
test_show_num = KEY_UP;
break;
test_show_num = KEY_DOWN;
break;
default:
test_show_num = 0;
break;
void interrupt ISR(void)
/*定時(shí)器0中斷服務(wù)程序段*/
if(TMR0IE & TMR0IF)
TMR0 = 0x07;
timing_ms_count1++;
timing_ms_count3++;
if(timing_ms_count1 % 300 == 0 && timing_ms_count1 != 0)
if(S16 == 1)
S15 = ~S15;
if(S11 == 1)
S12 = ~S12;
if(warning_flag == 1)
S1 = ~ S1;
if(timing_ms_count1 % 500 == 0 && timing_ms_count1 != 0)
timing_half_s_count1++;
if(timing_ms_count1 % 450 == 0 && timing_ms_count1 != 0)
LCD_showFanrun();
TMR0IF = 0;
/*定時(shí)器1中斷服務(wù)程序段*/
if(TMR1IE & TMR1IF)
TMR1H = 0xFF;
TMR1L = 0x08;
timing_ms_count2++;
if(timing_ms_count2 % 1000 == 0)
/*計(jì)時(shí)時(shí)間處理*/
if(S13 == 1)
timing_count_sec_set--;
Key_isrelease_time++; //按鍵釋放時(shí)間計(jì)時(shí)
timing_s_count1++; //秒計(jì)時(shí)器1(未用)
/*系統(tǒng)運(yùn)行時(shí)間處理*/
timing_s_count2++;
if(timing_s_count2 % 60 == 0)
timing_s_count2 = 0;
sys_time_minute++;
if(sys_time_minute % 30 == 0)
sys_time_minute=0;
sys_time_half_hour++; //運(yùn)行半小時(shí)計(jì)時(shí)
if(sys_time_half_hour % 1440 == 0)
sys_time_half_hour = 0;
sys_time_month++;//運(yùn)行月份計(jì)時(shí)
if((PORTF != 0xFF) && (key_action_flag == 1))
Get_KeyValue();
key_count = 0;
if((PORTF != 0xFF) && (key_action_flag_Long_press == 1))
Get_key_valve_Long_press();
if((PORTF != 0xFF) && (key_action_flag_continuty == 1))
Get_key_valve_continuty();
if(timing_ms_count2 % 200 == 0)
if((test_show_num == KEY_UP) || (test_show_num == KEY_DOWN))
KeyCode = test_show_num;
if(PORTF == 0xFF)
test_show_num = 0;
key_action_flag_continuty == 0;
if((KeyCode == KEY_UP) || (KeyCode == KEY_DOWN))
Key_isrelease_time = 0;
TMR1IF = 0;
/*外部中斷服務(wù)程序段*/
if(INTF == 1)
if(PORTF != 0xFF && key_action_flag == 0)
key_action_flag = 1;
key_action_flag_Long_press = 1;
key_action_flag_continuty = 1;
key_value_buffer = PORTF;
key_keep_time = timing_s_count2;
INTF = 0;
INTE = 0;
TRISBbits.TRISB0 = 0;
LATBbits.LATB0 = 1;
/*ADC中斷服務(wù)程序段*/
// if(ADIE & ADIF)
// ADIF = 0;
