查看: 4683|回復(fù): 1
單片機(jī)驅(qū)動(dòng)8位動(dòng)態(tài)數(shù)碼管仿真與源程序
8位動(dòng)態(tài)數(shù)碼管仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載)
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. #include<ctype.h>
  4. #include<string.h>
  5. #include<math.h>
  6. #include<stdio.h>
  7. #define uchar unsigned char
  8. #define uint unsigned int
  9. sbit dula=P2^0;
  10. sbit wela=P2^1;
  11. uint time=0;
  12. uint hh=23;
  13. uint mm=59;
  14. uint ss=49;
  15. uchar code table[]={
  16. 0x3f,0x06,0x5b,0x4f,
  17. 0x66,0x6d,0x7d,0x07,
  18. 0x7f,0x6f,0x77,0x7c,
  19. 0x39,0x5e,0x79,0x71
  20. };
  21. void delayms(uint t)
  22. {
  23.         uint i,j;
  24.         for(i=t;i>0;i--)
  25.                 for(j=110;j>0;j--)
  26.                         ;
  27. }
  28. void print_string_LED(char* str)
  29. {
  30.         uint len=strlen(str);
  31.         uint index=strpos(str,'.');
  32.         uchar t=0x7f;
  33.         uint i=0;
  34.         for(i=0;i<len;i++)
  35.         {
  36.                 if(isdigit(str[len-i-1])==1)
  37.                 {
  38.                         P0=0xff;
  39.                         wela=1;
  40.                         P0=t;
  41.                         wela=0;
  42.                         P0=0x00;
  43.                         dula=1;
  44.                         if(i==len-index)
  45.                                 P0=table[str[len-i-1]-'0']|0x80;
  46.                         else
  47.                                 P0=table[str[len-i-1]-'0'];
  48.                         dula=0;
  49.                 }
  50.                 else if(isalpha(str[len-i-1])==1)
  51.                 {
  52.                         P0=0xff;
  53.                         wela=1;
  54.                         P0=t;
  55.                         wela=0;
  56.                         P0=0x00;
  57.                         dula=1;
  58.                         str[len-i-1]=tolower(str[len-i-1]);
  59.                         if(i==len-index)
  60.                                 P0=table[str[len-i-1]-'a'+10]|0x80;
  61.                         else
  62.                                 P0=table[str[len-i-1]-'a'+10];
  63.                         dula=0;
  64.                 }
  65.                 else if(str[len-i-1]=='-')
  66.                 {
  67.                         P0=0xff;
  68.                         wela=1;
  69.                         P0=t;
  70.                         wela=0;
  71.                         P0=0x00;
  72.                         dula=1;
  73.                         P0=0x40;
  74.                         dula=0;
  75.                 }
  76.                 else
  77.                         continue;
  78.                 t=_cror_(t,1);
  79.                 delayms(2);
  80.         }
  81. }
  82. void main()
  83. {
  84.         char str[9];
  85.         char str_h[3];
  86.         char str_m[3];
  87.         char str_s[3];
  88.         uchar i,j,k;
  89.         TMOD=0x01;//計(jì)時(shí)器0以工作方式1計(jì)時(shí)
  90.         EA=1;//打開全局中斷允許
  91.         ET0=1;//打開定時(shí)器0中斷允許位
  92.         TR0=1;//啟動(dòng)定時(shí)器0
  93.         TH0=55535/256;
  94.         TL0=55535%256;
  95.         while(1)
  96.         {
  97.                 if(ss==60)
  98.                 {
  99.                         ss=0;
  100.                         mm++;
  101.                 }
  102.                 if(mm==60)
  103.                 {
  104.                         mm=0;
  105.                         hh=(++hh)%24;
  106.                 }
  107.                 sprintf(str_h,"%u",hh);
  108.                 sprintf(str_m,"%u",mm);
  109.                 sprintf(str_s,"%u",ss);
  110.                 i=0;
  111.
  112.                 //if(hh!=0)
  113.                 {
  114.                         for(i=0;str_h[i]!='\0';i++)
  115.                                 str[i]=str_h[i];
  116.                         str[i++]='-';
  117.                 }
  118.                 //if(mm!=0)
  119.                 {
  120.                         for(j=0;str_m[j]!='\0';j++)
  121.                                 str[i++]=str_m[j];
  122.                         str[i++]='-';
  123.                 }
  124.                 for(k=0;str_s[k]!='\0';k++)
  125.                         str[i++]=str_s[k];
  126.                 str[i]='\0';
  127.                 print_string_LED(str);
  128.         }
  129. }
  130. void ET_T0() interrupt 1
  131. {
  132.         TH0=55535/256;
  133.         TL0=55535%256;
  134.         time++;
  135.         if(time==100)
  136.         {
  137.                 ss++;
  138.                 time=0;
  139.         }
  140. }
八位數(shù)碼管.zip (21.89 KB, 下載次數(shù): 83)
ID:755823 發(fā)表于 2020-5-19 16:43 | 只看該作者
為下載了不能用?
