    查看: 6189|回復(fù): 1
    Arduino單總線多路18b20測溫源碼
    ID:398397 發(fā)表于 2018-9-28 09:24 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
    Arduino多路18b20測溫,使用單總線協(xié)議,優(yōu)點是只占一個io口,且測溫路數(shù)可以任意設(shè)定。
    源程序如下:
    1. #include <OneWire.h>
    2. #include <DallasTemperature.h>
    3. // Data wire is plugged into port 2 on the Arduino
    4. #define ONE_WIRE_BUS 2
    5. #define TEMPERATURE_PRECISION 12
    6. // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    7. OneWire oneWire(ONE_WIRE_BUS);
    8. // Pass our oneWire reference to Dallas Temperature.
    9. DallasTemperature sensors(&oneWire);
    10. int numberOfDevices; // Number of temperature devices found
    11. DeviceAddress tempDeviceAddress; // We'll use this variable to store a found device address
    12. void setup(void)
    13. {
    14.   // start serial port
    15.   Serial.begin(9600);
    16.   Serial.println("Dallas Temperature IC Control Library Demo");
    17.   // Start up the library
    18.   sensors.begin();
    19.
    20.   // Grab a count of devices on the wire
    21.   numberOfDevices = sensors.getDeviceCount();
    22.
    23.   // locate devices on the bus
    24.   Serial.print("Locating devices...");
    25.
    26.   Serial.print("Found ");
    27.   Serial.print(numberOfDevices, DEC);
    28.   Serial.println(" devices.");
    29.   // report parasite power requirements
    30.   Serial.print("Parasite power is: ");
    31.   if (sensors.isParasitePowerMode()) Serial.println("ON");
    32.   else Serial.println("OFF");
    33.
    34.   // Loop through each device, print out address
    35.   for(int i=0;i<numberOfDevices; i++)
    36.   {
    37.     // Search the wire for address
    38.     if(sensors.getAddress(tempDeviceAddress, i))
    39.         {
    40.                 Serial.print("Found device ");
    41.                 Serial.print(i, DEC);
    42.                 Serial.print(" with address: ");
    43.                 printAddress(tempDeviceAddress);
    44.                 Serial.println();
    45.
    46.                 Serial.print("Setting resolution to ");
    47.                 Serial.println(TEMPERATURE_PRECISION,DEC);
    48.
    49.                 // set the resolution to 9 bit (Each Dallas/Maxim device is capable of several different resolutions)
    50.                 sensors.setResolution(tempDeviceAddress, TEMPERATURE_PRECISION);
    51.
    52.                  Serial.print("Resolution actually set to: ");
    53.                 Serial.print(sensors.getResolution(tempDeviceAddress), DEC);
    54.                 Serial.println();
    55.         }else{
    56.                 Serial.print("Found ghost device at ");
    57.                 Serial.print(i, DEC);
    58.                 Serial.print(" but could not detect address. Check power and cabling");
    59.         }
    60.   }
    61. }
    62. // function to print the temperature for a device
    63. void printTemperature(DeviceAddress deviceAddress)
    64. {
    65.   // method 1 - slower
    66.   //Serial.print("Temp C: ");
    67.   //Serial.print(sensors.getTempC(deviceAddress));
    68.   //Serial.print(" Temp F: ");
    69.   //Serial.print(sensors.getTempF(deviceAddress)); // Makes a second call to getTempC and then converts to Fahrenheit
    70.   // method 2 - faster
    71.   float tempC = sensors.getTempC(deviceAddress);
    72.   Serial.print("Temp C: ");
    73.   Serial.print(tempC);
    74.   Serial.print(" Temp F: ");
    75.   Serial.println(DallasTemperature::toFahrenheit(tempC)); // Converts tempC to Fahrenheit
    76. }
    77. void loop(void)
    78. {
    79.   // call sensors.requestTemperatures() to issue a global temperature
    80.   // request to all devices on the bus
    81.   Serial.print("Requesting temperatures...");
    82.   sensors.requestTemperatures(); // Send the command to get temperatures
    83.   Serial.println("DONE");
    84.
    85.
    86.   // Loop through each device, print out temperature data
    87.   for(int i=0;i<numberOfDevices; i++)
    88.   {
    89.     // Search the wire for address
    90.     if(sensors.getAddress(tempDeviceAddress, i))
    91.         {
    92.                 // Output the device ID
    93.                 Serial.print("Temperature for device: ");
    94.                 Serial.println(i,DEC);
    95.
    96.                 // It responds almost immediately. Let's print out the data
    97.                 printTemperature(tempDeviceAddress); // Use a simple function to print out the data
    98.         }
    99.         //else ghost device! Check your power requirements and cabling
    100.
    101.   }
    102.   delay(10000);
    103.   Serial.println(":");
    104.   Serial.println(":");
    105.   Serial.println(":");
    106. }
    107. // function to print a device address
    108. void printAddress(DeviceAddress deviceAddress)
    109. {
    110.   for (uint8_t i = 0; i < 8; i++)
    111.   {
    112.     if (deviceAddress[i] < 16) Serial.print("0");
    113.     Serial.print(deviceAddress[i], HEX);
    114.   }
    115. }
    18b20.zip (1.41 KB, 下載次數(shù): 22)
    ID:243394 發(fā)表于 2018-9-29 14:39 | 只看該作者
    謝謝分享
