51單片機(jī)的頭文件可以直接在15單片機(jī)上使用嗎?例如15使用“reg51.h”頭文件時(shí)需要注意哪些事項(xiàng)。
我寫了一個(gè)智能車的紅外跟隨程序 大神幫忙看看哪里出錯(cuò)了
#include <REGX52.H>
sbit LeftIR=P0^0; //定義前方左側(cè)紅外探頭端口
sbit RightIR=P0^1; //定義前方右側(cè)紅外探頭端口
sbit ZhongIR=P0^2; //定義中間紅外探頭端口
sbit xiao=P0^3; //根據(jù)此紅外信號(hào)有無,判斷跟隨距離是否過近
sbit M1A=P1^0; //電機(jī)左右引腳口
sbit M1B=P1^1;
sbit M2A=P1^2;
sbit M2B=P1^3;
sbit ENA0=P1^4; //電機(jī)控制使能端
sbit ENA1=P1^5;
unsigned char Xinhao;
/**********毫秒延時(shí)**********/
void delay_nms(unsigned int t) //毫秒延時(shí)
unsigned int i,j;
for(i=0;i<t;i++)
for(j=0;j<120;j++);
/**********信號(hào)處理**********/
void Xhao(Xinhao)
if(xiao==0)
Xinhao=0;
if( LeftIR ==1 && ZhongIR==1 && RightIR ==1 )
Xinhao=1;
if( LeftIR ==0 && ZhongIR==0 && RightIR ==0 )
Xinhao=2;
if( LeftIR ==0 && ZhongIR==1 && RightIR ==1 )
Xinhao=3;
if( LeftIR ==1 && ZhongIR==0 && RightIR ==1 )
Xinhao=4;
if( LeftIR ==1 && ZhongIR==1 && RightIR ==0 )
Xinhao=5;
if( LeftIR ==0 && ZhongIR==0 && RightIR ==1 )
Xinhao=6;
if( LeftIR ==0 && ZhongIR==1 && RightIR ==0 )
Xinhao=7;
if( LeftIR ==1 && ZhongIR==0 && RightIR ==0 )
Xinhao=8;
/**********電機(jī)運(yùn)行方式**********/
void tingzhi()
M1A=0; //將M1電機(jī)A端初始化為0
M1B=0; //將M1電機(jī)B端初始化為0
M2A=0; //將M2電機(jī)A端初始化為0
M2B=0;
void qianjin()
M1A=1;
M1B=0;
M2A=1;
M2B=0;
void houtui()
delay_nms(30);
M1A=0;
M1B=1;
M2A=0;
M2B=1;
void zuozhuan()
M1A=1;
M1B=0;
M2A=0;
M2B=0;
void youzhuan()
M1A=0;
M1B=0;
M2A=1;
M2B=0;
/**********信號(hào)電機(jī)綜合方式**********/
void Yunxing(unsigned char Yxing)
switch(Yxing)
case 0:
tingzhi();
break;
case 1:
tingzhi();
break;
case 2:
qianjin();
break;
case 3:
zuozhuan();
break;
case 4:
qianjin();
break;
case 5:
youzhuan();
break;
case 6:
zuozhuan();
break;
case 7:
qianjin();
break;
case 8:
youzhuan();
break;
/**********主程序**********/
Yunxing(0);
switch(Xinhao)
case 0:
Yunxing(0);
break;
case 1:
Yunxing(1);
break;
case 2:
Yunxing(2);
break;
case 3:
Yunxing(3);
break;
case 4:
Yunxing(4);
break;
case 5:
Yunxing(5);
break;
case 6:
Yunxing(6);
break;
case 7:
Yunxing(7);
break;
case 8:
Yunxing(8);
break;
