查看: 3666|回復(fù): 2
在數(shù)碼管秒計(jì)時(shí)程序基礎(chǔ)上添加流水燈功能,演示二者如何同時(shí)工作
ID:403141 發(fā)表于 2018-10-4 11:17 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char code LedChar[] = {  //數(shù)碼管顯示字符轉(zhuǎn)換表
    0xC0, 0xF9, 0xA4, 0xB0, 0x99, 0x92, 0x82, 0xF8,
    0x80, 0x90, 0x88, 0x83, 0xC6, 0xA1, 0x86, 0x8E
unsigned char LedBuff[7] = {  //數(shù)碼管+獨(dú)立LED顯示緩沖區(qū),初值0xFF確保啟動(dòng)時(shí)都不亮
    0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
bit flag200ms = 0;  //200ms定時(shí)標(biāo)志
bit flag1s = 0;     //1s定時(shí)標(biāo)志
void ShowCount();
void FlowingLight();
    EA = 1;       //使能總中斷
    ENLED = 0;    //使能U3
    ADDR3 = 1;    //因?yàn)樾枰獎(jiǎng)討B(tài)改變ADDR0-2的值,所以不需要再初始化了
    TMOD = 0x01;  //設(shè)置T0為模式1
    TH0  = 0xFC;  //為T0賦初值0xFC67,定時(shí)1ms
    TL0  = 0x67;
    ET0  = 1;     //使能T0中斷
    TR0  = 1;     //啟動(dòng)T0
    while (1)
        if (flag200ms)  //200ms刷新一次流水燈
            flag200ms = 0;
            FlowingLight();
        if (flag1s)   //1s刷新一次計(jì)數(shù)值
            flag1s = 0;
            ShowCount();
/* 流水燈實(shí)現(xiàn)函數(shù) */
void FlowingLight()
    static unsigned char dir = 0;   //移位方向變量dir,用于控制移位的方向
    static unsigned char shift = 0x01;  //循環(huán)移位變量shift,并賦初值0x01
    LedBuff[6] = ~shift;      //循環(huán)移位變量取反,控制8個(gè)LED
    if (dir == 0)             //移位方向變量為0時(shí),左移
        shift = shift << 1;   //循環(huán)移位變量左移1位
        if (shift == 0x80)    //左移到最左端后,改變移位方向
            dir = 1;
    else                      //移位方向變量不為0時(shí),右移
        shift = shift >> 1;   //循環(huán)移位變量右移1位
        if (shift == 0x01)    //右移到最右端后,改變移位方向
            dir = 0;
/* 秒計(jì)數(shù)顯示函數(shù) */
void ShowCount()
    char i;  //循環(huán)變量
    unsigned char buf[6];   //中間轉(zhuǎn)換緩沖區(qū)
    static unsigned long sec = 0;  //記錄經(jīng)過的秒數(shù)
    sec++;  //秒計(jì)數(shù)自加1
    buf[0] = sec%10;  //將sec按十進(jìn)制位從低到高依次提取到buf數(shù)組中
    buf[1] = sec/10%10;
    buf[2] = sec/100%10;
    buf[3] = sec/1000%10;
    buf[4] = sec/10000%10;
    buf[5] = sec/100000%10;
    for (i=5; i>=1; i--)  //從最高為開始,遇到0不顯示,遇到非0退出循環(huán)
        if (buf[i] == 0)
            LedBuff[i] = 0xFF;
            break;
    for ( ; i>=0; i--)  //將剩余的有效數(shù)字位如實(shí)轉(zhuǎn)換
        LedBuff[i] = LedChar[buf[i]];
/* 定時(shí)器0中斷服務(wù)函數(shù) */
void InterruptTimer0() interrupt 1
    static unsigned char i = 0;   //動(dòng)態(tài)掃描的索引
    static unsigned char cnt200 = 0;  //200ms定時(shí)
    static unsigned int cnt1000 = 0;  //1000ms即1s定時(shí)
    TH0 = 0xFC;  //重新加載初值
    TL0 = 0x67;
    cnt200++;    //200ms定時(shí)
    if (cnt200 >= 200)
        cnt200 = 0;
        flag200ms = 1;
    cnt1000++;   //1s定時(shí)
    if (cnt1000 >= 1000)
        cnt1000 = 0;
        flag1s = 1;
    //以下代碼完成數(shù)碼管動(dòng)態(tài)掃描刷新
    P0 = 0xFF;   //顯示消隱
    switch (i)
        case 0: ADDR2=0; ADDR1=0; ADDR0=0; i++; P0=LedBuff[0]; break;
        case 1: ADDR2=0; ADDR1=0; ADDR0=1; i++; P0=LedBuff[1]; break;
        case 2: ADDR2=0; ADDR1=1; ADDR0=0; i++; P0=LedBuff[2]; break;
        case 3: ADDR2=0; ADDR1=1; ADDR0=1; i++; P0=LedBuff[3]; break;
        case 4: ADDR2=1; ADDR1=0; ADDR0=0; i++; P0=LedBuff[4]; break;
        case 5: ADDR2=1; ADDR1=0; ADDR0=1; i++; P0=LedBuff[5]; break;
        case 6: ADDR2=1; ADDR1=1; ADDR0=0; i=0; P0=LedBuff[6]; break;
        default: break;
ID:1 發(fā)表于 2018-10-6 20:57 | 顯示全部樓層
補(bǔ)全原理圖或者詳細(xì)說明一下電路連接即可獲得100+黑幣
ID:229361 發(fā)表于 2018-10-7 00:39 | 顯示全部樓層
學(xué)習(xí)中,謝謝��!
