查看: 5082|回復(fù): 4
單片機(jī)可調(diào)智能定時(shí)鬧鐘proteus仿真與源碼
ID:405992 發(fā)表于 2018-10-7 00:27 | 顯示全部樓層 |閱讀模式
這是一個(gè)可調(diào)電子時(shí)鐘的代碼和仿真圖!
  1. #include<reg52.h>
  2. typedef unsigned char uint8;
  3. typedef unsigned int uint16;
  4. sbit rs=P2^6;         // 數(shù)據(jù)命令選擇
  5. sbit rw=P2^5;         //讀寫選擇
  6. sbit e=P2^7;          //使能
  7. sbit k1=P3^3;        //設(shè)置
  8. sbit k2=P3^0;        //分加
  9. sbit k3=P3^1;  //時(shí)加
  10. sbit k4=P3^2;  //鬧鐘分加
  11. sbit k5=P3^4;  //鬧鐘時(shí)加
  12. sbit SPK = P1^0;
  13. void baojing();
  14. void alarm();
  15. uint8 a[]="time:  ";  //要顯示的字符
  16. uint8 num[]="0123456789";
  17. uint8 b[8],shi,fen,miao;
  18. uint8 c[]="alarm: ";
  19. uint8 d[8],nshi,nfen= 1,nmiao;
  20. uint8 num1[]="0123456789";
  21. uint8 timeset;
  22. uint8 sum;
  23. void delay(uint16 i)
  24. {
  25.         while(i--);
  26. }
  27. void wrc(uint8 c)         //寫命令
  28. {
  29.         delay(1000);
  30.         rs=0;
  31.         rw=0;
  32.         e=0;
  33.         P0=c;
  34.         e=1;
  35.         delay(10);
  36.         e=0;
  37.         /*
  38.         P0=c<<4;
  39.         e=1;
  40.         e=0;*/       //四位的LCD要加上
  41. }
  42. void wrd(uint8 dat)          //寫數(shù)據(jù)
  43. {
  44.         delay(1000);
  45.         rs=1;
  46.         rw=0;
  47.         e=0;
  48.         P0=dat;
  49.         e=1;
  50.         delay(10);
  51.         e=0;
  52.         /*
  53.         P0=dat<<4;
  54.         e=1;
  55.         e=0;*/           //四位的LCD要加上
  56.         rs=0;
  57. }
  58. void lcdinit()
  59. {
  60.         delay(1000);
  61. /*        wrc(0x32);
  62.         wrc(0x28);
  63.         wrc(0x28);        */        //四位的LCD要加上
  64.         wrc(0x38);
  65.         wrc(0x38);
  66.         wrc(0x38);
  67.         wrc(0x06);
  68.         wrc(0x0c);
  69.         wrc(0x01);
  70. }
  71. void time0init()
  72. {
  73.         TMOD=0X01;
  74.         TH0=0XFC;
  75.         TL0=0X18; //1ms
  76.         TR0=1;
  77.         ET0=1;
  78.         EA=1;
  79. }
  80. void int0init()
  81. {
  82.         EA=1;
  83.         EX0=1;
  84.         IT0=1;
  85. }
  86. void int1init()
  87. {
  88.         EA=1;
  89.         EX1=1;
  90.         IT1=1;
  91. }
  92. void timepros()
  93. {
  94.
  95.         b[0]=num[shi/10];
  96.         b[1]=num[shi%10];
  97.         b[2]=0x3a;
  98.         b[3]=num[fen/10];
  99.         b[4]=num[fen%10];
  100.         b[5]=0x3a;
  101.         b[6]=num[miao/10];
  102.         b[7]=num[miao%10];
  103.         d[0]=num[nshi/10];
  104.         d[1]=num[nshi%10];
  105.         d[2]=0x3a;
  106.         d[3]=num[nfen/10];
  107.         d[4]=num[nfen%10];
  108.         d[5]=0x3a;
  109.         d[6]=num[nmiao/10];
  110.         d[7]=num[nmiao%10];
  111.
  112. }
  113. void display()
  114. {
  115.         uint8 i;
  116.         timepros();
  117.         wrc(0x00+0x80);
  118.         for(i=0;i<16;i++)
  119.         {
  120.                 wrd(a[i]);
  121.         }
  122. //        wrc(0x00+0x86);
  123.         wrd(b[0]);
  124.         wrd(b[1]);
  125.         wrd(b[2]);
  126.         wrd(b[3]);
  127.         wrd(b[4]);
  128.         wrd(b[5]);
  129.         wrd(b[6]);
  130.         wrd(b[7]);
  131.            wrc(0x40+0x80);
  132.         for(i=0;i<16;i++)
  133.         {
  134.                 wrd(c[i]);
  135.         }
  136.         wrd(d[0]);
  137.         wrd(d[1]);
  138.         wrd(d[2]);
  139.         wrd(d[3]);
  140.         wrd(d[4]);
  141.         wrd(d[5]);
  142.         wrd(d[6]);
  143.         wrd(d[7]);
  144. }
  145. void main()
  146. {
  147.         lcdinit();
  148.         time0init();
  149.         int1init();
  150.         while(1)
  151.         {
  152.                 if(timeset==1)                //可以調(diào)整時(shí)間
  153.                 {
  154.                         if(k2==0)                //分設(shè)置
  155.                         {
  156.                                 delay(5);
  157.                                 if(k2==0)
  158.                                 {
  159.                                         fen++;
  160.                                         if(fen==60)fen=0;
  161.                                 }
  162.                                 while(!k2);
  163.                         }
  164.                         if(k3==0)                //時(shí)設(shè)置
  165.                         {
  166.                                 delay(5);
  167.                                 if(k3==0)
  168.                                 {
  169.                                         shi++;
  170.                                         if(shi==12)shi=0;
  171.                                 }
  172.                                 while(!k3);
  173.                         }
  174.                 }
  175.                         if(timeset==2)                //可以調(diào)整鬧鐘
  176.                 {
  177.
  178.                         if(k4==0)                //分設(shè)置
  179.                         {
  180.                                 delay(5);
  181.                                 if(k4==0)
  182.                                 {
  183.                                         nfen++;
  184.                                         if(nfen==60)nfen=0;
  185.                                 }
  186.                                 while(!k4);
  187.                         }
  188.                         if(k5==0)                //時(shí)設(shè)置
  189.                         {
  190.                                 delay(5);
  191.                                 if(k5==0)
  192.                                 {
  193.                                         nshi++;
  194.                                         if(nshi==12)nshi=0;
  195.                                 }
  196.                                 while(!k3);
  197.                         }
  198.                 }
  199.                 display();
  200.                 alarm();
  201.         }
  202. }
  203. void alarm()
  204. {
  205.   SPK=1;
  206. if(fen==nfen && shi == nshi)
  207.   {
  208.           SPK=~SPK;
  209.         delay(50);
  210.         SPK=~SPK;
  211.         }
  212.         else
  213.       ;
  214. }
  215. void tim0() interrupt 1
  216. {
  217.         static uint16 n;
  218.         TH0=0XFC;
  219.         TL0=0X18;//1ms
  220.         n++;
  221.         if(n==1000)
  222.         {
  223.                 n=0;
  224.                 miao++;
  225.                 if(miao==60)
  226.                 {
  227.                         miao=0;
  228.                         fen++;
  229.                         if(fen==60)
  230.                         {
  231.                                 fen=0;
  232.                                 shi++;
  233.                                 if(shi==60)
  234.                                 {
  235.                                         shi=0;
  236.                                         miao=0;
  237.                                         fen=0;
  238.                                 }
  239.                         }
  240.                 }
  241.         }
  242. }
  243. void int1() interrupt 2
  244. {
  245.         delay(1000);
  246.         if(k1==0)
  247.         {
  248.                 sum++;
  249.                 if(sum==1)
  250.                 {
  251.                     TR0=0;
  252.                         timeset=1;
  253.                 }
  254.                         if(sum==2)
  255.                 {
  256.                          TR0=0;
  257.                         timeset=2;
  258.                 }
  259.                 if(sum==3)
  260.                 {
  261.                          TR0=1;
  262.                         timeset=0;
  263.                         sum=0;
  264.                 }
  265.         }
  266. }
2362486-1FS1105153.zip (92.84 KB, 下載次數(shù): 138)
ID:404878 發(fā)表于 2018-10-8 15:17 | 顯示全部樓層
看上去不錯(cuò)的樣子
ID:668832 發(fā)表于 2019-12-19 23:39 | 顯示全部樓層
請(qǐng)問(wèn)C語(yǔ)言如何轉(zhuǎn)為匯編語(yǔ)言
ID:668832 發(fā)表于 2019-12-19 23:42 | 顯示全部樓層
lzDestiny 發(fā)表于 2018-10-8 15:17
看上去不錯(cuò)的樣子
C語(yǔ)言怎么轉(zhuǎn)為匯編語(yǔ)言
ID:668557 發(fā)表于 2019-12-24 18:06 | 顯示全部樓層
我試著自己寫了個(gè)差不多的,我的問(wèn)題很大難受
