查看: 2671|回復(fù): 6
51單片機保存數(shù)據(jù)問題
ID:34216 發(fā)表于 2018-10-10 06:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
單片機驅(qū)動數(shù)碼管顯示1,按一下鍵盤+1顯示2,,怎么保存 ? 斷電開機顯示2
ID:7485 發(fā)表于 2018-10-10 08:17 | 只看該作者
必須有ROM,如flash、eeprom eprom等。
ID:330198 發(fā)表于 2018-10-10 09:00 | 只看該作者
可以利用51單片機的EEPROM每次按下把數(shù)據(jù)存入,下次上電自動讀取。下面的程序是讀寫EEPROM程序。僅供參考。
#include "reg52.h"
#include "intrins.h"
typedef unsigned char BYTE;
typedef unsigned int WORD;
/*Declare SFR associated with the IAP */
sfr IAP_DATA    =   0xC2;           //Flash data register
sfr IAP_ADDRH   =   0xC3;           //Flash address HIGH
sfr IAP_ADDRL   =   0xC4;           //Flash address LOW
sfr IAP_CMD     =   0xC5;           //Flash command register
sfr IAP_TRIG    =   0xC6;           //Flash command trigger
sfr IAP_CONTR   =   0xC7;           //Flash control register
/*Define ISP/IAP/EEPROM command*/
#define CMD_IDLE    0               //Stand-By
#define CMD_READ    1               //Byte-Read
#define CMD_PROGRAM 2               //Byte-Program
#define CMD_ERASE   3               //Sector-Erase
/*Define ISP/IAP/EEPROM operation const for IAP_CONTR*/
//#define ENABLE_IAP 0x80           //if SYSCLK<30MHz
//#define ENABLE_IAP   0x81           //if SYSCLK<24MHz
#define ENABLE_IAP 0x82            //if SYSCLK<20MHz
//#define ENABLE_IAP 0x83           //if SYSCLK<12MHz
//Start address for STC15w204s EEPROM
#define IAP_ADDRESS1 0x0000   //型號不同,地址不同,具體見datasheet
#define IAP_ADDRESS2 0x0200
Disable ISP/IAP/EEPROM function
Make MCU in a safe state
void IapIdle()
    IAP_CONTR = 0;                  //Close IAP function
    IAP_CMD = 0;                    //Clear command to standby
    IAP_TRIG = 0;                   //Clear trigger register
    IAP_ADDRH = 0x80;               //Data ptr point to non-EEPROM area
    IAP_ADDRL = 0;                  //Clear IAP address to prevent misuse
Read one byte from ISP/IAP/EEPROM area
Input: addr (ISP/IAP/EEPROM address)
Output:Flash data
BYTE IapReadByte(WORD addr)
    BYTE dat;                       //Data buffer
    IAP_CONTR = ENABLE_IAP;         //Open IAP function, and set wait time
    IAP_CMD = CMD_READ;             //Set ISP/IAP/EEPROM READ command
    IAP_ADDRL = addr;               //Set ISP/IAP/EEPROM address low
    IAP_ADDRH = addr >> 8;          //Set ISP/IAP/EEPROM address high
    IAP_TRIG = 0x5a;                //Send trigger command1 (0x46)
    IAP_TRIG = 0xa5;                //Send trigger command2 (0xb9)
    _nop_();                        //MCU will hold here until ISP/IAP/EEPROM operation complete
    dat = IAP_DATA;                 //Read ISP/IAP/EEPROM data
    IapIdle();                      //Close ISP/IAP/EEPROM function
    return dat;                     //Return Flash data
Program one byte to ISP/IAP/EEPROM area
       dat (ISP/IAP/EEPROM data)
Output:-
void IapProgramByte(WORD addr, BYTE dat)
    IAP_CMD = CMD_PROGRAM;          //Set ISP/IAP/EEPROM PROGRAM command
    IAP_DATA = dat;                 //Write ISP/IAP/EEPROM data
    IapIdle();
Erase one sector area
Output:-
void IapEraseSector(WORD addr)
    IAP_CMD = CMD_ERASE;            //Set ISP/IAP/EEPROM ERASE command
    IapIdle();
ID:386381 發(fā)表于 2018-10-10 09:44 來自手機 | 只看該作者
可以在51復(fù)位腳那接個備用電池
ID:407393 發(fā)表于 2018-10-10 10:20 | 只看該作者
ID:23606 發(fā)表于 2018-10-10 10:41 | 只看該作者
把數(shù)碼管顯示的值寫入eeprom,斷電后從新上電讀取eeprom相應(yīng)地址的值再顯示
ID:407408 發(fā)表于 2018-10-10 10:43 | 只看該作者
單片機有EEPROM的話,在單片機掉電過程中將數(shù)碼管顯示值保存到EEPROM,再上電時,數(shù)碼顯示值先從EEPROMZ中加載
