關(guān)于STM32F030的具體模板,共開發(fā)者參考
- STM32F030C8T6模板
- 時(shí)鐘都在system_stm32f0xxx.里設(shè)定。用那個(gè)開那個(gè),輸出都是48MHZ,最大頻率,可以在里面改變大小頻率
- #define PLL_SOURCE_HSI // HSI (~8MHz) used to clock the PLL, and the PLL is used as system clock source(~ 8MHz)
- //#define PLL_SOURCE_HSE // HSE (8MHz) used to clock the PLL, and the PLL is used as system clock source
- //#define PLL_SOURCE_HSE_BYPASS // HSE bypassed with an external clock (8MHz, coming from ST-Link) used to clock
- 使用內(nèi)部時(shí)鐘 48MHZ
- #include "stm32f0xx.h"
- #include "delay.h"
- void LedInit(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA,ENABLE); //GPIOF時(shí)鐘打開
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; //模式:輸出
- GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL; //輸入類型:上拉/下拉/無
- GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; //輸出類型:推挽輸出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //輸出速率
- GPIO_Init(GPIOA,&GPIO_InitStructure);
- int main(void)
- delay_init();///定時(shí)器初始化,
- LedInit();///LED燈初始代,
- while (1)
- GPIO_ResetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2);
- delay_ms(200); //延時(shí)
- GPIO_SetBits(GPIOA,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2);
- delay_ms(200);
工程模板-F030.zip
(297.96 KB, 下載次數(shù): 222)
2018-10-10 12:43 上傳
點(diǎn)擊文件名下載附件
STM32F030
