基于51單片機(jī)進(jìn)行 彩屏圖片顯示
- Copytight : Yihetech Co,.Ltd, All rightd reserved. 版權(quán)歸屬億和電子工作室
- File Name : lcd.c
- Description : LCD module operations
- Date : 2009-7-19 21:17:45
- Version : V1.0
- Author : LiYong(李勇), yihe_liyong@126.com
- Target device : C8051F340
- Compiler : KeilC51 V8.16
- Note : 轉(zhuǎn)載時務(wù)必保留此信息,否則無權(quán)以任何形式傳播本文件
- #define _LCD_C_
- #include "LCD.H"
- #define LCDCOM 0
- #define LCDDAT 1
- sbit LED_RD = P2^5;
- sbit LED_CS = P2^7;
- sbit LED_WR = P2^4;
- sbit LED_A0 = P2^3;
- sbit BLACKLIGHT = P2^0;
- sbit RESET = P2^6;
- void _delay_ms(unsigned char del)
- unsigned int i,j;
- for(i=0; i<del; i++)
- for(j=0; j<182; j++)
- * Name : LCD_Init( )
- * Description : Initialize the LCD module
- * Input : None
- * Output : None
- * Note : None
- void LCDWR( INT8U cmd_dt, INT8U value )
- LED_RD = 1;
- LED_CS = 1;
- LED_WR = 1;
- if(cmd_dt)
- LED_A0 = 1;
- else
- LED_A0 = 0;
- P0 = value;
- LED_CS = 0;
- LED_WR = 0;
- LED_WR = 1;
- LED_CS = 1;
- * Input : None
- * Output : None
- * Note : None
- void LCD_Init( void )
- RESET=1;
- _delay_ms(10); //Delay 1ms
- RESET=0;
- RESET=1;
- _delay_ms(10); //Delay 120ms
- LCDWR( LCDCOM, 0x01);//software reset
- _delay_ms(50); //delay 150ms
- LCDWR( LCDCOM, 0x11);//software reset
- LCDWR( LCDCOM,0xB1); // Auto load set
- LCDWR ( LCDDAT,0x02);//auto load disable//0x9f
- LCDWR ( LCDDAT,0x35);
- LCDWR ( LCDDAT,0x36);
- LCDWR( LCDCOM,0xB2); //EE read/write mode
- LCDWR ( LCDDAT,0x02); //set read mode
- LCDWR( LCDCOM,0xB3); //EE read/write mode
- LCDWR( LCDCOM,0xB4); //EE read/write mode
- LCDWR ( LCDDAT,0x07); //set read mode
- LCDWR( LCDCOM,0xb6);
- LCDWR ( LCDDAT,0xb4);
- LCDWR ( LCDDAT,0xf0);
- LCDWR( LCDCOM,0xc0);
- LCDWR ( LCDDAT,0xa2);
- LCDWR ( LCDDAT,0x84);
- LCDWR( LCDCOM,0xc1);
- LCDWR ( LCDDAT,0x05);
- //LCDWR( LCDCOM,0xc2);
- //LCDWR ( LCDDAT,0x0a);
- //LCDWR ( LCDDAT,0x00);
- //LCDWR( LCDCOM,0xc3);
- //LCDWR ( LCDDAT,0x8a);
- //LCDWR ( LCDDAT,0x2a);
- //LCDWR( LCDCOM,0xc4);
- //LCDWR ( LCDDAT,0xee);
- //LCDWR( LCDCOM,0xd9);
- //LCDWR ( LCDDAT,0x40);
- LCDWR( LCDCOM,0xc5);
- LCDWR( LCDCOM,0xc7);
- LCDWR ( LCDDAT,0x00);
- LCDWR( LCDCOM,0x36);
- LCDWR ( LCDDAT,0xc8);
- LCDWR( LCDCOM,0xe0); //write contrast for mobile
- LCDWR ( LCDDAT,0x12);
- LCDWR ( LCDDAT,0x1c);
- LCDWR ( LCDDAT,0x10);
- LCDWR ( LCDDAT,0x18);
- LCDWR ( LCDDAT,0x33);
- LCDWR ( LCDDAT,0x2c);
- LCDWR ( LCDDAT,0x25);
- LCDWR ( LCDDAT,0x28);
- LCDWR ( LCDDAT,0x27);
- LCDWR ( LCDDAT,0x2f);
- LCDWR ( LCDDAT,0x3c);
- LCDWR ( LCDDAT,0x03);
- //-----------OTPB SET----------------------//
- LCDWR( LCDCOM,0xe1);// bias set
- LCDWR( LCDCOM,0x2a);// bias set
- LCDWR ( LCDDAT,0x81);
- LCDWR( LCDCOM,0x2b);// bias set
- LCDWR ( LCDDAT,0x82);
- LCDWR( LCDCOM,0xf0);// bias set
- LCDWR ( LCDDAT,0x01);
- LCDWR( LCDCOM,0xf6);// bias set
- LCDWR( LCDCOM,0x3a);// bias set
- _delay_ms(50);
- LCDWR( LCDCOM,0x29); //booster set
- _delay_ms(50);
- //LCDWR( LCDCOM,0x2c); //booster efficiency set
- Name: LCDDrawDollop
- Function: Draw a dollop at a special area
- Input: 1. *dollop : The pointer of a DOLLOP struct
- Output: None
- Note: The value of the input structrue must be correct, This function does not check the parameters.
- Author: LiYong
- Date : 2008.08.09
- void LCDSetArea( INT16U x1, INT16U y1, INT16U x2, INT16U y2 )
- x1+=2;
- x2+=2;
- y1+=3;
- y2+=3;
- LCDWR ( LCDCOM, 0x2A);
- LCDWR ( LCDDAT, x1>>8);
- LCDWR ( LCDDAT, x1);
- LCDWR ( LCDDAT, x2>>8);
- LCDWR ( LCDDAT, x2 + 0);
- LCDWR ( LCDCOM, 0x2B);
- LCDWR ( LCDDAT, y1>>8);
- LCDWR ( LCDDAT, y1);
- LCDWR ( LCDDAT, y2>>8);
- LCDWR ( LCDDAT, y2);
- LCDWR ( LCDCOM, 0x2C);
- void LCDDrawDollop( DOLLOP* dollop )
- INT16U x,y;
- LCDSetArea(dollop->xs, dollop->ys, dollop->xe, dollop->ye); //Set a area at the screen
- for( x = 0; x < dollop->xe - dollop->xs + 1; x ++ ) //Display rows
- for( y = 0; y < dollop->ye - dollop->ys + 1; y ++ ) //Display columns
- LCDWR( LCDDAT, dollop->Color>>8 );
- LCDWR( LCDDAT, dollop->Color );
- Name: LCDDrawPoint( );
- Function: Draw a point
- Input: -pPoint, A structure pointer
- Output: None
- void LCDDrawPoint( POINT* pPoint )
- LCDSetArea( pPoint->x, pPoint->y, pPoint->x, pPoint->y );
- LCDWR ( LCDDAT, ( pPoint->Color >> 8 ) & 0xff );
- LCDWR ( LCDDAT, pPoint->Color & 0xff );
- Name: LCDDrawHRLine( );
- Function: Draw a line
- Input: -pLine, A structure pointer to a line
- Output: None
- void LCDDrawHRLine( LINE* pLine )
- INT8U x0, x1, y0, y1;
- if( pLine->xs != pLine->xe && pLine->ys != pLine->ye ) return;
- if( pLine->ys > pLine->ye )
- y0 = pLine->ye;
- y1 = pLine->ys;
- else
- y0 = pLine->ys;
- y1 = pLine->ye;
- if( pLine->xs > pLine->xe )
- x0 = pLine->xe;
- x1 = pLine->xs;
- else
- x0 = pLine->xs;
- x1 = pLine->xe;
- LCDSetArea( x0, y0, x1, y1 );
- x0 = x1 - x0;
- if( x0 == 0 ) x0 = y1 - y0;
- for( y0 = 0; y0 < x0; y0 ++ )
- LCDWR( LCDDAT, pLine->Color >> 8 );
- LCDWR( LCDDAT, pLine->Color );
- Name: PrintBitBlock
- Function: Print a special block in the screen.
- Input: pBitBlock: This is a pointer, It points to a block whitch contains informations of the block,
- eg. height, width, and so on.
- Output: None
- Note: None
- Author: LiYong
- Date : 2008.08.09
- void PrintBitBlock( BitBlock *pBitBlock )
- INT8U Row, Column;
- INT32U BytesAbs;
- INT8U RowBytes;
- LCDSetArea( pBitBlock->xs, pBitBlock->ys,
- pBitBlock->xs + pBitBlock->Width - 1, pBitBlock->ys + pBitBlock->Height - 1 );
- RowBytes = pBitBlock->Width >> 3;
- if( pBitBlock->Width & 0x07 )
- RowBytes ++;
- for( Row = 0; Row < pBitBlock->Height; Row ++ )
- for( Column = 0; Column < pBitBlock->Width; Column ++ )
- BytesAbs = Row * RowBytes + ( Column >> 3 ) ;
- if( *( pBitBlock->pData + BytesAbs ) & ( 1<<( Column & 0x07 )) )
- LCDWR( LCDDAT, pBitBlock->Color >> 8 );
- LCDWR( LCDDAT, pBitBlock->Color );
- else
- LCDWR( LCDDAT, pBitBlock->BackColor >> 8 );
- LCDWR( LCDDAT, pBitBlock->BackColor );
- Name: GUI_Image( )
- Function: Print a image
- Input: point to a struct which contains the informations of the image
- Output: None
- Note: None
- Author: LiYong
- Date : 2008.08.09
- void GUI_Image( IMAGE *pImage )
- INT16U x, y;
- INT32U datacount = 0;
- LCDSetArea( pImage->xs, pImage->ys, pImage->xs + pImage->length - 1, pImage->ys + pImage->height - 1 );
- for( x = 0; x < pImage->length; x ++ )
- for( y = 0; y < pImage->height; y ++ )
- LCDWR( LCDDAT, *( pImage->pData + datacount++ ) );
- -----------------------------------End of file----------------------------------
彩屏圖片顯示.rar
(208.52 KB, 下載次數(shù): 10)
2018-10-13 00:06 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
