查看: 3078|回復: 1
51單片機 有中斷函數(shù)0-9999的計數(shù)(原理圖+源程序)
ID:409773 發(fā)表于 2018-10-17 11:48 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
51單片機的,有中斷函數(shù),沒0.5s計數(shù)一次
然后用LED數(shù)碼管顯示的,做的很爛,分享一下原理圖
單片機
LED數(shù)碼管
LED
單片機源程序如下:
  1. #include"STC12C5a60s2.H"
  2. //------------------------
  3. //LED接口
  4. sbit  D2 = P3^0;
  5. sbit  D3 = P3^1;
  6. sbit  D4 = P3^2;
  7. sbit  D5 = P3^3;
  8. //數(shù)碼管接口
  9. sbit  COM1 = P1^3;
  10. sbit  COM2 = P1^4;
  11. sbit  COM3 = P1^5;
  12. sbit  COM4 = P1^6;
  13.   //變量定義
  14. unsigned char segTab [] = {0XA0,0XBB,0X62,0X2A,0X39,0X2C,0X24,0XBA,0X20,0X28};
  15. unsigned char segTab2 [] = {0X80,0X9B,0X42,0X0A,0X19,0X0C,0X04,0X9A,0X00,0X08};
  16. unsigned int to1s=0;
  17. unsigned int to2ms = 0;
  18. unsigned int number = 0;
  19. unsigned int segDisplayBit = 0;
  20. unsigned int i = 0;
  21. //==================================
  22. //主函數(shù)
  23. void main()
  24. { P1M1 &=~0X78;
  25.   P1M0 |= 0X78;
  26.      //定時器初始化        T0約為100uS
  27.     TMOD = 0x02;   //定時器T0,方式2(8位計數(shù),自動重載)
  28.     TH0 = 163;     //11.0592M晶振,約100uS
  29.     TL0 = TH0;     //自動重載計數(shù)值,計數(shù)值存于TH0中,而用TL0計數(shù)
  30.     TR0 = 1;       //開定時器T0
  31.     ET0 = 1;       //開定時器中斷
  32.         EA  = 1;       //開總中斷
  33.
  34.
  35.
  36. while(1)                //無限循環(huán)體
  37. {
  38.
  39.    }
  40. }
  41. //==================
  42. //定時器中斷函數(shù)
  43. void Timer0_ISR(void) interrupt 1 using 1
  44. {        to2ms++;
  45.         if(to2ms == 20)
  46.         {  to2ms = 0;
  47.
  48.             segDisplayBit++;
  49.                 if(segDisplayBit>4) segDisplayBit = 1;
  50.
  51.                 if(segDisplayBit==1)                 //千位
  52.                 { COM1=0; COM2=0; COM3=0; COM4=0;
  53.                   P0 = segTab[number/1000];
  54.                   if(number/1000!=0)COM1=1;}
  55.
  56.                 if(segDisplayBit==2)          //百位
  57.                 { COM1=0; COM2=0; COM3=0; COM4=0;
  58.                   P0 = segTab[number%1000/100]&0xDF;
  59.                    COM2=1;}
  60.
  61.                 if(segDisplayBit==3)        //十位
  62.                 { COM1=0; COM2=0; COM3=0; COM4=0;
  63.                   P0 = segTab[number%100/10];
  64.                  COM3=1;}
  65.
  66.                         if(segDisplayBit==4) //個位
  67.                 { COM1=0; COM2=0; COM3=0; COM4=0;
  68.                   P0 = segTab[number%10];
  69.                   COM4=1;}
  70.            to1s++;
  71.                 if(to1s == 50)
  72.                 {         to1s=0;
  73.                   number++;
  74.                   if(number==9999)number=0;
  75.                                            }
  76.           }
  77.                   i++;
  78.                  if(i==1000)
  79.                 {
  80.                  D5=0;D4=1;D3=1;D2=1; }
  81.                  if(i==2000)
  82.                  { D5=1;D4=0;D3=1;D2=1;}
  83.
  84.                  if(i==3000)
  85.                  {D5=1;D4=1;D3=0;D2=1;}
  86.                  if(i==4000)
  87.                  { i=0; D5=1;D4=1;D3=1;D2=0;}
  88.    }
復制代碼
定時中斷0-9999程序.zip (26.93 KB, 下載次數(shù): 18)
參與人數(shù) 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
ID:1 發(fā)表于 2018-10-17 14:41 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
