查看: 5811|回復(fù): 0
求助蜂鳴器能夠發(fā)出1到7這七個音調(diào),不知程序那里有問題
ID:303240 發(fā)表于 2018-10-17 15:10 來自觸屏版 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
sbit beep=P1^5;
uint code high[]={0xf8,0xf9,0xfa,0xfa,0xfb,0xfb,0xfc};
uint code low[]={0x89,0x5b,0x15,0x67,0x04,0x90,0x0c};
uint i=0;
uint m=0;
void init()
  TMOD=0x01;
  EA=1;
  ET0=1;
  init();
  while(m%2==0)
  TH0=high[i];
  TL0=low[i];
  TR0=1;
void t0()interrupt 1
        TH0=high[i];
  TL0=low[i];
  beep=~beep;
        m++;
        if(m%2==0)
                i++;
        if(i>7)
                i=0;
