查看: 4118|回復(fù): 1
大家好!c8051F的ad采樣,幫我看下程序哪里的設(shè)置有問(wèn)題!
ID:35884 發(fā)表于 2012-3-9 09:35 | 顯示全部樓層 |閱讀模式
c51F350 部分程序
#define SYSCLK       49000000             // SYSCLK frequency (Hz)
#define BAUDRATE     57600                 // UART0 Baudrate (bps)
#define MDCLK        2457600              // Modulator Clock (Hz)
void ADC_Buffered(void)
    unsigned int i;
  float average;
         for (i = 0; i < Sampling_times; i++)
          while(!AD0INT);
         AD0INT = 0;
         ADC_OutputVal = ADC0H;
          ADC_OutputVal =ADC_OutputVal<< 16;
          ADC_OutputVal += (long)ADC0L + ((long)ADC0M << 8);
          sample_array = ADC_OutputVal;
        for(i=0;i<Sampling_times;i++)
          average=average+(float)sample_array;
       average=average/(Sampling_times);
    average=average/256/256/256;
    average=average*VREF;
    average=average*2;
     average=average;
    ADC_VIN= (int)average;
void ADC0_Init (void)
     unsigned ADC0_decimation;
      REF0CN &= ~0x01;                       // disable internal vref
       // REF0CN |= 0x01;                        // (enable if using internal vref)
      // ADC0CN = 0x00;                         // unipolar output codes, GAIN=1
   ADC0CN = 0x10;                         // Bipolar output codes, GAIN=1
       //ADC0CF = 0x00;                         // interrupts upon SINC3 filter output
                                          // and uses internal VREF
       ADC0CF = 0x04;                         // interrupts upon SINC3 filter output
                                          // and ê1ó?ía2?VREF
      ADC0CLK = (SYSCLK/MDCLK)-1;  // Ideally, MDCLK =2.457MHz
                                          // Generate MDCLK for modulator.
   // program decimation rate for desired OWR
     ADC0_decimation = (unsigned long) SYSCLK/ (unsigned long) OWR /
                     (unsigned long) (ADC0CLK+1)/(unsigned long)128;
     ADC0_decimation--;
       ADC0DEC = ADC0_decimation;
       ADC0BUF = 0x00;                        // 1?±?ê?è??o3?
     ADC0MUX = 0x0b;                       // 2?·?ê?è?
                                          // AIN+ => AIN0.0
         ADC0DAC = 0x00;
         ADC0STA = 0x00;                                 // AIN- => AIN0.1
//   ADC0MUX = 0x08;
          ADC0MD |= 0x80;                      // ê1?ü(IDLE Mode)
輸入信號(hào)進(jìn)行采樣調(diào)制器在頻率的MDCLK / 128.
ADC0CLK 是調(diào)制器時(shí)鐘分頻系數(shù)
為獲得最佳性能,應(yīng)選擇使調(diào)制器時(shí)鐘等于2.4576 MHz(調(diào)制器采樣速率= 19.2千赫)的分頻系數(shù)
系統(tǒng)時(shí)鐘分按照公式:
MDCLK=系統(tǒng)時(shí)鐘/ (ADC0CLK + 1)
這樣的話 速度應(yīng)該很快啊 ~  怎么 程序打出來(lái)的ADC_VIN 很慢???
知道大神解釋下  為什么呢???
怎么設(shè)置才能最快@!@
ID:35884 發(fā)表于 2012-3-9 09:37 | 顯示全部樓層
Sampling_times=128的話 采樣速率應(yīng)該是  19200 Hz啊  實(shí)驗(yàn)結(jié)果目測(cè)還不到1Hz~  啊啊啊 啊啊啊
