51單片機外部中斷int0應(yīng)用電路原理圖如下:
2018-10-21 17:34 上傳
單片機源程序如下:
- #include <reg52.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code DSY_CODE[]=
- 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x7f,0x6f,0x00
- uchar Display_Buffer[3]={0,0,0};//依次存放個位,十位,百位
- uint Count = 0;
- sbit Clear_Key = P3^6;
- void Show_Count_ON_DSY()
- Display_Buffer[2] = Count / 100; //取百位值
- Display_Buffer[1] = Count % 100 /10; //取十位值
- Display_Buffer[0] = Count % 10; //取個位置
- if(Display_Buffer[2]==0)
- Display_Buffer[2] = 0x0a;
- if(Display_Buffer[1]==0)
- Display_Buffer[1]=0x0a;
- P0 = DSY_CODE[Display_Buffer[0]];
- P1 = DSY_CODE[Display_Buffer[1]];
- P2 = DSY_CODE[Display_Buffer[2]];
- void main()
- P0 = 0xff; //關(guān)閉所有的數(shù)碼管顯示
- P1 = 0xff;
- P2 = 0xff;
- IE = 0x81; //0x81=10000001B,定義:EA/-/ET2/ES/ET1/EX1/ET0/EX0。打開EA總中斷開和EX0外部中斷開關(guān)。
- IT0 = 1; //跳變沿出發(fā)方式(下降沿)
- while(1)
- if(Clear_Key == 0)
- Count = 0;
- Show_Count_NO_DSY();
- void EX_INT0() interrupt 0 //外部中斷0服務(wù)函數(shù)
- Count ++;
復(fù)制代碼 知識點:1 數(shù)碼管段碼表
共陰數(shù)碼管段碼表
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
共陽段碼表
unsigned char code stab[]={0xff,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,
0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e};
001INT0中斷計數(shù).docx
(120.56 KB, 下載次數(shù): 8)
2018-10-21 17:35 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
