系統(tǒng)采用51單片機為主控,rc522為檢測裝置,主要是模擬,紅綠燈通過定時器控制,原理就是邏輯判斷,在紅燈時有車(卡)掃過,就會存儲下車牌號,通過液晶顯示車牌,以及紅燈信息,有闖紅燈信息。代碼如下。
單片機源程序如下:
- #include "common.h"
- #include "RC522.h"
- #include "stdio.h"
- #include "12864.h"
- #define uchar unsigned char
- #define uint unsigned int
- char serNum[5];
- char Old_serNum[5]=0,Card_serNum[20][5]=0,buf[9];
- char str[MAX_LEN];
- char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
- int num,flag,i,j,num1=0;
- char temp=29,flag0=0,flag1=0,flag2,flag3,aa;
- char temp1=1;
- void T1_time1(void) interrupt 1
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- aa++;
- if(aa==20)
- aa=0;
- temp--;
- if(flag1==0)
- if((temp>0)&&(temp<30)) {RED=0;YELLOW=1;GREEN=1;flag=1;}
- if(flag0==0)
- if(temp==0)
- temp=29;
- flag1=1;
- if(flag1==1)
- if((temp>5)&&(temp<30)) {RED=1;YELLOW=1;GREEN=0;flag=0;}
- if((temp<=5)&&(temp>=0)) {RED=1;YELLOW=0;GREEN=1;flag=0;}
- flag0=1;
- if(temp==0)
- temp=29;
- flag1=0;
- flag0=0;
- void ShowCard_Id()
- int i;
- char *ptr=buf;
- for(i=0; i<4; i++,ptr+=2)
- sprintf(ptr,"%02x",Card_serNum[num1][i]);
- buf[8]='\0';
- Lcd_Display(1,5,buf);
- void show_card()
- char card;
- card=Card_serNum[num1][0];
- switch(card)
- { case 0x25:
- Lcd_Display(3,4,"吉A 88888");
- break;
- case 0x63:
- Lcd_Display(3,4,"吉B 66J67");
- break;
- case 0x96:
- Lcd_Display(3,4,"吉C 98889");
- break;
- case 0x80:
- Lcd_Display(3,4,"吉A YIJ88");
- break;
- case 0x00:
- Lcd_Display(3,4,"00 00000 ");
- break;
- void InoutHandle()
- unsigned char state;
- unsigned char readBuf[16];
- state = PcdRequest(PICC_REQIDL, str);
- if(state != MI_OK) return;
- state = PcdAnticoll(serNum);
- state = PcdSelect(serNum);
- state = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey , serNum);
- state = PcdRead(1, readBuf);
- for(j=0;j<5;j++)
- if(Old_serNum[j]!=serNum[j])
- flag2=1;
- if(flag2==1)
- for(j=0;j<5;j++)
- Old_serNum[j]=serNum[j];
- Card_serNum[temp1][0]=Old_serNum[0];
- Card_serNum[temp1][1]=Old_serNum[1];
- Card_serNum[temp1][2]=Old_serNum[2];
- Card_serNum[temp1][3]=Old_serNum[3];
- temp1++;
- if(temp1==20)
- temp1=0;
- flag2=0;
- PcdHalt();
- void key_stck()
- key0 = 1;
- key1 = 1;
- key2 = 1;
- key3 = 1;
- if( key0 == 0 )
- delay_10ms(5);
- if( key0 == 0 )
- while(!key0);
- if(num1!=0) num1--;
- else num1=0;
- if( key1 == 0 )
- delay_10ms(5);
- if( key1 == 0 )
- while(!key1);
- num1++;
- if(num1==20)
- num1=0;
- if( key2 == 0 )
- delay_10ms(5);
- if( key2 == 0 )
- while(!key2);
- if( key3 == 0 )
- delay_10ms(5);
- if( key3 == 0 )
- while(!key3);
- Lcd_Num_Display(4,1,num1);
- Lcd_Display(3,1,"車牌:");
- Lcd_Display(2,1,"違章車輛: 臺");
- Lcd_Num_Display(2,6,temp1-1);
- if(Card_serNum[1][0]!=0)
- Lcd_Display(1,1,"有違章");
- if(Card_serNum[1][0]==0)
- Lcd_Display(1,1,"無違章");
- show_card();
復制代碼
2018-10-22 21:24 上傳
RFID闖紅燈檢測.zip
(166.88 KB, 下載次數(shù): 26)
2018-10-22 21:04 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
