查看: 2367|回復(fù): 1
基于單片機(jī)+RC522的地鐵卡的設(shè)計(jì)源碼
ID:201598 發(fā)表于 2018-10-22 21:09 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
   通過(guò)RC522裝置,能夠給卡片充值金額,記錄地鐵站位置以及抵達(dá)的地鐵站位置,將地鐵站的位置進(jìn)行計(jì)算,將充值的金額減去,如果不能大于等于0則無(wú)法出站,顯示屏?xí)霈F(xiàn)請(qǐng)充值字樣。
  1. #include "common.h"
  2. #include "RC522.h"
  3. #include "uart.h"
  4. #include "juzhenanjian.h"
  5. #include "12864.h"
  6. #define DEBUG
  7. unsigned char code DefaultKey[6] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  8. //unsigned char writeBuf[16] = {0x01, 0x00, 0x03, 0x00, 0x00, 0x00};
  9. int num,flag,i,fig,mode=0,fig1=0;
  10. static        volatile int s=0;
  11. /*     充值
  12. **            金額數(shù)
  13. **
  14. */
  15. void  Value()
  16. {        num =keyscan();
  17.         switch (num)
  18.         {
  19.                 case 1:fig=0x01;fig1=1;
  20.                 Lcd_Num_Display1(1,6,fig1);
  21.                            break;
  22.                 case 2:fig=0x02;fig1=2;
  23.                 Lcd_Num_Display1(1,6,fig1);
  24.                            break;
  25.                 case 3:fig=0x03;fig1=3;
  26.                 Lcd_Num_Display1(1,6,fig1);
  27.                            break;
  28.                 case 4:mode=1  ;
  29.                 Lcd_Write_Com(0x01);
  30.                 Lcd_Display(1,1,"充值金額:  元");
  31.                        break;
  32.                 case 5:fig=0x04;fig1=4;
  33.                 Lcd_Num_Display1(1,6,fig1);
  34.                        break;
  35.                 case 8:mode=2  ;
  36.                 Lcd_Write_Com(0x01);
  37.                 Lcd_Display(1,1,"刷卡模式:");
  38.                        break;
  39.         }
  40. }
  41. /*     金額充值
  42. **            value 金額數(shù)
  43. **           *sernum 序列號(hào)
  44. */
  45. void ChangeValue(unsigned char  *sernum, unsigned int value)
  46. {
  47.         unsigned char status;
  48.         unsigned char readBuf[16];
  49.         unsigned char writeBuf[16]=0;
  50.
  51. #ifdef DEBUG
  52.         UART_TC("You will be select!\n");
  53. #endif
  54.         status = PcdSelect(sernum);
  55.         if(status == MI_OK){
  56. #ifdef DEBUG
  57.                 UART_TC("Select card ok!\n");
  58. #endif
  59.                 status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey, sernum);
  60.                 if(status == MI_OK){
  61. #ifdef DEBUG
  62.                         UART_TC("Authent A success!\n");
  63. #endif
  64.                         status = PcdRead(1, readBuf);
  65.                         if(status == MI_OK){
  66. #ifdef DEBUG
  67.                                 UART_TC("Read OK\n");
  68.                                 for(i=0; i<16; i++)
  69.                                         {tochar(readBuf[i]);}
  70. #endif
  71.                         if(status == MI_OK)
  72.                         {
  73.                                 writeBuf[2] = value;
  74.                                 PcdWrite(1,writeBuf);
  75.                                 UART_TC("Write OK\n");
  76.                         }
  77.                         if(readBuf[2]==1 || readBuf[2]==2 || readBuf[2]==3)
  78.                         {
  79.                                         Lcd_Write_Com(0x01);
  80.                                         Lcd_Display(1,1,"充值成功:  元");
  81.                                         Lcd_Num_Display1(1,6,fig1);
  82.                         }
  83.                          }
  84.                 }
  85.         }
  86. }
  87. void ShowCardType(unsigned char *type)
  88. {
  89.         UART_TC("Card Type: ");
  90.
  91.         if(type[0]==0x04 && type[1]==0x00)
  92.                 UART_TC("MFone-S50\n");
  93.         else if(type[0]==0x02 && type[1]==0x00)
  94.                 UART_TC("MFone-S70\n");
  95.         else if(type[0]==0x44 && type[1]==0x00)
  96.                 UART_TC("MF-UltraLight\n");
  97.         else if(type[0]==0x08 && type[1]==0x00)
  98.                 UART_TC("MF-Pro\n");
  99.         else if(type[0]==0x44 && type[1]==0x03)
  100.                 UART_TC("MF Desire\n");
  101.         else
  102.                 UART_TC("Unknow Card Type\n");
  103. }
  104. void ShowCardId(unsigned char *id)
  105. {
  106.         int IdLen = 4;
  107.         int i;
  108.
  109.         for(i=0; i<IdLen; i++){
  110.                 tochar(id[i]);
  111.         }
  112.         UART_TC("\n");
  113. }
  114. void InoutHandle(const unsigned char  *sernum)
  115. {
  116.         unsigned char status;
  117.         unsigned char readBuf[16];
  118.         unsigned char writeBuf[16];
  119.
  120. #ifdef DEBUG
  121.         UART_TC("You will be select!\n");
  122. #endif
  123.         status = PcdSelect(sernum);
  124.         if(status == MI_OK){
  125. #ifdef DEBUG
  126.                 UART_TC("Select card ok!\n");
  127. #endif
  128.                 status = PcdAuthState(PICC_AUTHENT1A, 1, DefaultKey , sernum);
  129.                 if(status == MI_OK){
  130. #ifdef DEBUG
  131.                         UART_TC("Authent A success!\n");
  132. #endif
  133.                         status = PcdRead(1, readBuf);
  134.                         if(status == MI_OK){
  135. #ifdef DEBUG
  136.                                 UART_TC("Read OK\n");
  137.                                 for(i=0; i<16; i++)
  138.                                         {tochar(readBuf[i]);
  139.                                         }
  140. #endif
  141.                                 writeBuf[2] = readBuf[2];
  142.                                 switch(flag)
  143.                                 {
  144.                                         case 0x0A :tochar(flag);
  145.                                         if(readBuf[1]==0)  // 第一位 0進(jìn)站1出站    第0位記錄進(jìn)站位置   第2位金額                                                        {
  146.                                                         {
  147.        writeBuf[0]=0x0A;
  148.        writeBuf[1]=1;
  149.        PcdWrite(1,writeBuf);
  150.        UART_TC("Int success!\n");
  151.        Lcd_Display(1,6,"進(jìn)站");
  152.                                                         }
  153.                                                         else
  154.                                                         {
  155.                                                             if(readBuf[0]==0x0B)
  156.        {
  157.        if(readBuf[2]>=0x01)
  158.        {LED_OK=0;
  159.        writeBuf[0]=0;
  160.        writeBuf[1]=0;
  161.        writeBuf[2]=0;
  162.        PcdWrite(1,writeBuf);
  163.        Lcd_Display(1,6,"出站");
  164.        Lcd_Display(2,2,"Success Thank you!");
  165.        LED_FAILED=1;
  166.        ALARM=1;}
  167.        else
  168.        {LED_FAILED=0;
  169.        ALARM=0;
  170.        Lcd_Display(1,6,"出站");
  171.        Lcd_Display(2,2,"失敗,請(qǐng)充值");
  172.        }
  173.        }
  174.        else if(readBuf[0]==0x0C)
  175.        {
  176.        if(readBuf[2]>=0x02)
  177.        {LED_OK=0;
  178.        writeBuf[0]=0;
  179.        writeBuf[1]=0;
  180.        writeBuf[2]=0;
  181.        PcdWrite(1,writeBuf);
  182.        Lcd_Display(1,6,"出站");
  183.        Lcd_Display(2,1,"Success Thanks");
  184.        LED_FAILED=1;
  185.        ALARM=1;}
  186.        else
  187.        {LED_FAILED=0;
  188.        ALARM=0;
  189.        Lcd_Display(1,6,"出站");
  190.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  191.        }
  192.        else if(readBuf[0]==0x0D)
  193.        {
  194.        if(readBuf[2]>=0x03)
  195.        {LED_OK=0;
  196.        writeBuf[0]=0;
  197.        writeBuf[1]=0;
  198.        writeBuf[2]=0;
  199.        PcdWrite(1,writeBuf);
  200.        Lcd_Display(1,6,"出站");
  201.        Lcd_Display(2,1,"Success Thanks");
  202.        LED_FAILED=1;
  203.        ALARM=1;}
  204.        else
  205.        {LED_FAILED=0;
  206.        ALARM=0;
  207.        Lcd_Display(1,6,"出站");
  208.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  209.        }
  210.        else if(readBuf[0]==0x0E)
  211.        {
  212.        if(readBuf[2]>=0x02)
  213.        {LED_OK=0;
  214.        writeBuf[0]=0;
  215.        writeBuf[1]=0;
  216.        writeBuf[2]=0;
  217.        PcdWrite(1,writeBuf);
  218.        Lcd_Display(1,6,"出站");
  219.        Lcd_Display(2,1,"Success Thanks");
  220.        LED_FAILED=1;
  221.        ALARM=1;}
  222.        else
  223.        {LED_FAILED=0;
  224.        ALARM=0;
  225.        Lcd_Display(1,6,"出站");
  226.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  227.                                                             }
  228.                                                         }
  229.                                                             break;
  230.                                         case 0x0B :tochar(flag);
  231.                                                         if(readBuf[1]==0)
  232.                                                         {
  233.        writeBuf[0]=0x0B;
  234.        writeBuf[1]=1;
  235.        PcdWrite(1,writeBuf);
  236.        Lcd_Display(1,6,"進(jìn)站");
  237.
  238.                                                         }
  239.                                                         else
  240.                                                         {
  241.                                                             if(readBuf[0]==0x0A)
  242.        {
  243.        if(readBuf[2]>=0x01)
  244.        {LED_OK=0;
  245.        writeBuf[0]=0;
  246.        writeBuf[1]=0;
  247.        writeBuf[2]=0;
  248.        PcdWrite(1,writeBuf);
  249.        Lcd_Display(1,6,"出站");
  250.        Lcd_Display(2,1,"Success Thanks");
  251.        LED_FAILED=1;
  252.        ALARM=1;}
  253.        else
  254.        {LED_FAILED=0;
  255.        ALARM=0;
  256.        Lcd_Display(1,6,"出站");
  257.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  258.        }
  259.        else if(readBuf[0]==0x0C)
  260.        {
  261.        if(readBuf[2]>=0x01)
  262.        {LED_OK=0;
  263.        writeBuf[0]=0;
  264.        writeBuf[1]=0;
  265.        writeBuf[2]=0;
  266.        PcdWrite(1,writeBuf);
  267.        Lcd_Display(1,6,"出站");
  268.        Lcd_Display(2,1,"Success Thanks");
  269.        LED_FAILED=1;
  270.        ALARM=1;}
  271.        else
  272.        {LED_FAILED=0;
  273.        ALARM=0;
  274.        Lcd_Display(1,6,"出站");
  275.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  276.        }
  277.        else if(readBuf[0]==0x0D)
  278.        {
  279.        if(readBuf[2]>=0x02)
  280.        {LED_OK=0;
  281.        writeBuf[0]=0;
  282.        writeBuf[1]=0;
  283.        writeBuf[2]=0;
  284.        PcdWrite(1,writeBuf);
  285.        Lcd_Display(1,6,"出站");
  286.        Lcd_Display(2,1,"Success Thanks");
  287.        LED_FAILED=1;
  288.        ALARM=1;}
  289.        else
  290.        {LED_FAILED=0;
  291.        ALARM=0;
  292.        Lcd_Display(1,6,"出站");
  293.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  294.        }
  295.        else if(readBuf[0]==0x0E)
  296.        {
  297.        if(readBuf[2]>=0x04)
  298.        {LED_OK=0;
  299.        writeBuf[0]=0;
  300.        writeBuf[1]=0;
  301.        writeBuf[2]=0;
  302.        PcdWrite(1,writeBuf);
  303.        Lcd_Display(1,6,"出站");
  304.        Lcd_Display(2,1,"Success Thanks");
  305.        LED_FAILED=1;
  306.        ALARM=1;}
  307.        else
  308.        {LED_FAILED=0;
  309.        ALARM=0;
  310.        Lcd_Display(1,6,"出站");
  311.        Lcd_Display(2,2,"失敗,請(qǐng)充值  ");}
  312.                                                             }
  313.                                                         }
  314.        break;
  315.                                         case 0x0C :tochar(flag);
  316.                                                         if(readBuf[1]==0)
  317.                                                         {
  318.        writeBuf[0]=0x0C;
  319.        writeBuf[1]=1;
  320.        PcdWrite(1,writeBuf);
  321.        Lcd_Display(1,6,"進(jìn)站");
  322.                                                         }
  323.                                                         else
  324.                                                         {
  325.                                                             if(readBuf[0]==0x0B)
  326.        {
  327.        if(readBuf[2]>=0x01)
  328.        {LED_OK=0;
  329.        writeBuf[0]=0;
  330.        writeBuf[1]=0;
  331.        writeBuf[2]=0;
  332.        PcdWrite(1,writeBuf);
  333.        Lcd_Display(1,6,"出站");
  334.        Lcd_Display(2,1,"Success Thanks");
  335.        LED_FAILED=1;
  336.        ALARM=1;}
  337.        else
  338.        {LED_FAILED=0;
  339.        ALARM=0;
  340.        Lcd_Display(1,6,"出站");
  341.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  342.        }
  343.        else if(readBuf[0]==0x0A)
  344.        {
  345.        if(readBuf[2]>=0x02)
  346.        {LED_OK=0;
  347.        writeBuf[0]=0;
  348.        writeBuf[1]=0;
  349.        writeBuf[2]=0;
  350.        PcdWrite(1,writeBuf);
  351.        Lcd_Display(1,6,"出站");
  352.        Lcd_Display(2,1,"Success Thanks");
  353.        LED_FAILED=1;
  354.        ALARM=1;}
  355.        else
  356.        {LED_FAILED=0;
  357.        ALARM=0;
  358.        Lcd_Display(1,6,"出站");
  359.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  360.        }
  361.        else if(readBuf[0]==0x0D)
  362.        {
  363.        if(readBuf[2]>=0x01)
  364.        {LED_OK=0;
  365.        writeBuf[0]=0;
  366.        writeBuf[1]=0;
  367.        writeBuf[2]=0;
  368.        PcdWrite(1,writeBuf);
  369.        Lcd_Display(1,6,"出站");
  370.        Lcd_Display(2,1,"Success Thanks");
  371.        LED_FAILED=1;
  372.        ALARM=1;}
  373.        else
  374.        {LED_FAILED=0;
  375.        ALARM=0;
  376.        Lcd_Display(1,6,"出站");
  377.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  378.        }
  379.        else if(readBuf[0]==0x0E)
  380.        {
  381.        if(readBuf[2]>=0x03)
  382.        {LED_OK=0;
  383.        writeBuf[0]=0;
  384.        writeBuf[1]=0;
  385.        writeBuf[2]=0;
  386.        PcdWrite(1,writeBuf);
  387.        Lcd_Display(1,6,"出站");
  388.        Lcd_Display(2,1,"Success Thanks");
  389.        LED_FAILED=1;
  390.        ALARM=1;}
  391.        else
  392.        {LED_FAILED=0;
  393.        ALARM=0;
  394.        Lcd_Display(1,6,"出站");
  395.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  396.                                                             }
  397.                                                         }
  398.        break;
  399.                                         case 0x0D :tochar(flag);
  400.                                                         if(readBuf[1]==0)
  401.                                                         {
  402.        writeBuf[0]=0x0D;
  403.        writeBuf[1]=1;
  404.        PcdWrite(1,writeBuf);
  405.        Lcd_Display(1,6,"進(jìn)站");
  406.
  407.                                                         }
  408.                                                         else
  409.                                                         {
  410.                                                             if(readBuf[0]==0x0B)
  411.        {
  412.        if(readBuf[2]>=2)
  413.        {LED_OK=0;
  414.        writeBuf[0]=0;
  415.        writeBuf[1]=0;
  416.        writeBuf[2]=0;
  417.        PcdWrite(1,writeBuf);
  418.        Lcd_Display(1,6,"出站");
  419.        Lcd_Display(2,1,"Success Thanks");
  420.        LED_FAILED=1;
  421.        ALARM=1;}
  422.        else
  423.        {LED_FAILED=0;
  424.        ALARM=0;
  425.        Lcd_Display(1,6,"出站");
  426.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  427.        }
  428.        else if(readBuf[0]==0x0C)
  429.        {
  430.        if(readBuf[2]>=0x01)
  431.        {LED_OK=0;
  432.        writeBuf[0]=0;
  433.        writeBuf[1]=0;
  434.        writeBuf[2]=0;
  435.        PcdWrite(1,writeBuf);
  436.        Lcd_Display(1,6,"出站");
  437.        Lcd_Display(2,1,"Success Thanks");
  438.        LED_FAILED=1;
  439.        ALARM=1;}
  440.        else
  441.        {LED_FAILED=0;
  442.        ALARM=0;
  443.        Lcd_Display(1,6,"出站");
  444.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  445.        }
  446.        else if(readBuf[0]==0x0A)
  447.        {
  448.        if(readBuf[2]>=0x03)
  449.        {LED_OK=0;
  450.        writeBuf[0]=0;
  451.        writeBuf[1]=0;
  452.        writeBuf[2]=0;
  453.        PcdWrite(1,writeBuf);
  454.        Lcd_Display(1,6,"出站");
  455.        Lcd_Display(2,1,"Success Thanks");
  456.        LED_FAILED=1;
  457.        ALARM=1;}
  458.        else
  459.        {LED_FAILED=0;
  460.        ALARM=0;
  461.        Lcd_Display(1,6,"出站");
  462.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  463.        }
  464.        else if(readBuf[0]==0x0E)
  465.        {
  466.        if(readBuf[2]>=0x02)
  467.        {LED_OK=0;
  468.        writeBuf[0]=0;
  469.        writeBuf[1]=0;
  470.        writeBuf[2]=0;
  471.        PcdWrite(1,writeBuf);
  472.        Lcd_Display(1,6,"出站");
  473.        Lcd_Display(2,1,"Success Thanks");
  474.        LED_FAILED=1;
  475.        ALARM=1;}
  476.        else
  477.        {LED_FAILED=0;
  478.        ALARM=0;
  479.        Lcd_Display(1,6,"出站");
  480.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  481.                                                             }
  482.                                                         }
  483.        break;
  484.                                         case 0x0E :tochar(flag);
  485.                                                         if(readBuf[1]==0)
  486.                                                         {
  487.        writeBuf[0]=0x0E;
  488.        writeBuf[1]=1;
  489.        PcdWrite(1,writeBuf);
  490.        Lcd_Display(1,6,"進(jìn)站");
  491.
  492.                                                         }
  493.                                                         else
  494.                                                         {
  495.                                                             if(readBuf[0]==0x0B)
  496.        {
  497.        if(readBuf[2]>=0x03)
  498.        {LED_OK=0;
  499.        writeBuf[0]=0;
  500.        writeBuf[1]=0;
  501.        writeBuf[2]=0;
  502.        PcdWrite(1,writeBuf);
  503.        Lcd_Display(1,6,"出站");
  504.        Lcd_Display(2,1,"Success Thanks");
  505.        LED_FAILED=1;
  506.        ALARM=1;}
  507.        else
  508.        {LED_FAILED=0;
  509.        ALARM=0;
  510.        Lcd_Display(1,6,"出站");
  511.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  512.        }
  513.        else if(readBuf[0]==0x0C)
  514.        {
  515.        if(readBuf[2]>=0x03)
  516.        {LED_OK=0;
  517.        writeBuf[0]=0;
  518.        writeBuf[1]=0;
  519.        writeBuf[2]=0;
  520.        PcdWrite(1,writeBuf);
  521.        Lcd_Display(1,6,"出站");
  522.        Lcd_Display(2,1,"Success Thanks");
  523.        LED_FAILED=1;
  524.        ALARM=1;}
  525.        else
  526.        {LED_FAILED=0;
  527.        ALARM=0;
  528.        Lcd_Display(1,6,"出站");
  529.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  530.        }
  531.        else if(readBuf[0]==0x0D)
  532.        {
  533.        if(readBuf[2]>=0x02)
  534.        {LED_OK=0;
  535.        writeBuf[0]=0;
  536.        writeBuf[1]=0;
  537.        writeBuf[2]=0;
  538.        PcdWrite(1,writeBuf);
  539.        Lcd_Display(1,6,"出站");
  540.        Lcd_Display(2,1,"Success Thanks");
  541.        LED_FAILED=1;
  542.        ALARM=1;}
  543.        else
  544.        {LED_FAILED=0;
  545.        ALARM=0;
  546.        Lcd_Display(1,6,"出站");
  547.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  548.        }
  549.        else if(readBuf[0]==0x0A)
  550.        {
  551.        if(readBuf[2]>=0x02)
  552.        {LED_OK=0;
  553.        writeBuf[0]=0;
  554.        writeBuf[1]=0;
  555.        writeBuf[2]=0;
  556.        PcdWrite(1,writeBuf);
  557.        Lcd_Display(1,6,"出站");
  558.        Lcd_Display(2,2,"Success Thank you!");
  559.        LED_FAILED=1;
  560.        ALARM=1;}
  561.        else
  562.        {LED_FAILED=0;
  563.        ALARM=0;
  564.        Lcd_Display(1,6,"出站");
  565.        Lcd_Display(2,2,"失敗,請(qǐng)充值");}
  566.                                                             }
  567.           }
  568.        break;
  569.        default:
  570.        LED_FAILED=0;
  571.        ALARM=0;
  572.        Lcd_Display(2,2,"error");
  573.                                 }
  574.         }
  575. }
  576. }
  577. }
RFID 最終程序.zip (185.06 KB, 下載次數(shù): 27)
ID:564281 發(fā)表于 2019-9-25 12:44 來(lái)自手機(jī) | 只看該作者
樓主這個(gè)有仿真圖嗎?
