查看: 3552|回復(fù): 6
一個(gè)PIC單片機(jī)AD采樣的程序沒給注釋,有些不懂,請教大神紅字部分
ID:306032 發(fā)表于 2018-10-24 10:58 | 顯示全部樓層 |閱讀模式
論壇里大神用pic18f4520寫的8路AD采樣,沒給注釋,新手有些地方看不太懂,請教大神!
請問紅字部分是什么意思,實(shí)現(xiàn)的什么功能?
謝謝!
//******Multi_ADChannel converter**********//
#include <pic18.h>
__PROG_CONFIG(1,0xc200);
__PROG_CONFIG(2,0x0a16);
__PROG_CONFIG(3,0x8100);
__PROG_CONFIG(4,0x0081);
__PROG_CONFIG(5,0xc00f);
__PROG_CONFIG(6,0xe00f);
__PROG_CONFIG(7,0x400f);
#define uint  unsigned int
uchar temp;
void multi_convertor(void);
void port_check(void);
uint ADbuf[10];
void delay_ms(uint t)
   uint m,n;
   for (m=0;m<t; m++)
     for (n=0; n<1140;n++);
void GPIO_Init(void)
  TRISA=0xff;
  TRISB=0xff;
  TRISC=0xff;
  TRISD=0xff;
  TRISE=0xff;
  PSPMODE=0;
  PSPIE=0;
  PSPIP=0;
  TRISBbits.RB2 =1;                  //set direction of RB2 to be An input;
  TRISBbits.RB3 =1;                  //set direction of RB3 to be An input;
void ADC_Init(void)
  ADCON1 = 0x05;                  //seting AN0~AN9 to be analog input;
  ADCON2 = 0xBE;                  //20TAD,FOSC/64 and right justified;
void timer0_init(void)
  INTCON =0xE0;//GIE,PEIE,TMR0IE to set;
  T0CON = 0x1F;// timer0 to be 16-bit;
  TMR0H = (65536-1000)/256;
  TMR0L = (65536-1000)%256;
  T0CON |=0x80;
  TMR0ON=1;
void EUART_init(void)
  TRISC7=1;
  TRISC6=1;
  SPBRG=0x40;
  TXSTA=0x24;
  RCSTA=0x90;
  RCIE=0;
  TXIE=0;
  PEIE=1;
  GIE=1;
void transmit_udata(uchar udata)
   TXREG=udata;
   while(!TRMT);
uchar receive_udata(void)
   uchar temp;
   if (RCIF==1)
     temp=RCREG;
   return temp;
uint data_average(uint buffer[30])
  uchar i,j;
  uint temp;
  float temp1;
  for(i=1; i<30; i++)
  for(j=29; j>=i; --j)
   if(buffer[j-1] > buffer[j])
    temp = buffer[j-1];
    buffer[j-1] = buffer[j];
    buffer[j] = temp;
temp1 = 0;
for(i=5; i<25; i++)
  temp1 += buffer[ i];
temp = (uint)(((float)temp1) / 20 + 0.5);
return(temp);
void main(void)
  EUART_init();
  GPIO_Init();
  ADC_Init();
  timer0_init();
       temp=receive_udata();
      if (temp==0x01)
         temp=0;
         port_check();
         multi_convertor();
   uchar num1, num2;
   num1=PORTD;
   num2=PORTB&0X03;
   transmit_udata(num2);
   transmit_udata(num1);
   uchar data1,data2,i;
   static uchar ADC_channel=0;
   uint adc[30]={0};
     // ADC_channel++;
      for (ADC_channel=0; ADC_channel<10; ADC_channel++)
               switch(ADC_channel)
                        case 0: ADCON0=0x01;break;//AN0 channel;
                        case 1: ADCON0=0x05;break;//AN1 channel;
                        case 2: ADCON0=0x09;break;//AN2 channel;
                        case 3: ADCON0=0x0D;break;//AN3 channel;
                        case 4: ADCON0=0x11;break;//AN4 channel;
                        case 5: ADCON0=0x15;break;//AN5 channel;
                        case 6: ADCON0=0x19;break;//AN6 channel;
                        case 7: ADCON0=0x1D;break;//AN7 channel;
                        case 8: ADCON0=0x21;break;//AN8 channel;
                        case 9: ADCON0=0x25;break;//AN9 channel;
                        default:break;
                     for(i=0;i<30;i++)
                            ADCON0 |=0x01;
                            asm("NOP");
                            asm("NOP");
                            GODONE=1;
                            while(GODONE);
                            adc[ i]=(ADRESH*256)+ADRESL;
                        ADbuf[ADC_channel]=data_average(adc);
                        data1=ADbuf[ADC_channel]/255;
                        data2=ADbuf[ADC_channel]%255;
                        transmit_udata(data1);
                        transmit_udata(data2);
ID:414550 發(fā)表于 2018-10-24 11:55 來自觸屏版 | 顯示全部樓層
排序,冒泡法排序
ID:89515 發(fā)表于 2018-10-24 12:32 | 顯示全部樓層
對數(shù)組排序,去掉最小的5個(gè)和最大的5個(gè),再進(jìn)行算數(shù)平均値濾波。主要是提高采樣的精度。檢測端口就不知道要干什么了,什么都沒做
ID:276663 發(fā)表于 2018-10-24 12:45 | 顯示全部樓層
第一段紅色部分的那個(gè)for循環(huán)是30個(gè)數(shù)據(jù)排序,然后取5-25的20個(gè)數(shù)據(jù)平均值。
我沒用過PIC所以不知道寄存器都是啥意思分析推測,
第二段紅色部分應(yīng)該是串口收到命令0x01后將D口的數(shù)據(jù)和B口與上0x03得到的數(shù)據(jù)用串口發(fā)送出去。
ID:414562 發(fā)表于 2018-10-24 12:47 來自觸屏版 | 顯示全部樓層
排序,把最小的5個(gè)過濾,再取平均
ID:23606 發(fā)表于 2018-10-24 14:21 | 顯示全部樓層
temp = (uint)(((float)temp1) / 20 + 0.5);中為什么要加0.5
ID:89515 發(fā)表于 2018-10-24 16:53 | 顯示全部樓層
YJGG 發(fā)表于 2018-10-24 14:21
四舍五入
