查看: 2161|回復(fù): 4
已經(jīng)寫好的程序 差整點報時功能 設(shè)置鬧鐘功能 求個大神幫忙看看 想了很久了
ID:412862 發(fā)表于 2018-10-24 14:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include"lcd.h"
#include"ds1302.h"
typedef unsigned int u16;          //?????????????????????
typedef unsigned char u8;
sbit K1=P3^1;
sbit K2=P3^0;
sbit K3=P3^2;
sbit K4=P3^3;
sbit beep=P1^5;
u8 start=0;
void Int0Configuration();
void LcdDisplay();
unsigned char SetState,SetPlace;
void Delay10ms(void);   //??? 0us
* ??????         : main
void delay(u16 y)
        while(y--);
void sound()
        u8 y=100;
        while(y--)
                beep=~beep;
                delay(100);
void keypros()
        if(K1==0&&K2==0)                         //???
                delay(1000);
                if(K1==0&&K2==0)
                        start=1;
                while(!(K1&&K2));
        if(K4==0&&K1==0)                          //??
                delay(1000);
                if(K4==0&&K1==0)
                        start=0;
                while(!K4&&K1);
                unsigned char i;
                unsigned char U;
        LcdInit();
        Ds1302Init();
                if(SetState==0)
                        Ds1302ReadTime();
                        if(K1==0)                //?????K1?????
                                Delay10ms();        //????????
                                if(K1==0)
                                        SetPlace++;
                                        if(SetPlace>=7)
                                                SetPlace=0;
                                while((i<50)&&(K1==0))         //???????????
                                        Delay10ms();
                                        i++;
                                i=0;
                        if(K2==0)                //?????K2?????
                                if(K2==0)
                                        TIME[SetPlace]++;
                                        if((TIME[SetPlace]&0x0f)>9)                                         //????BCD??
                                                TIME[SetPlace]=TIME[SetPlace]+6;
                                        if((TIME[SetPlace]>=0x60)&&(SetPlace<2))                //????????59
                                                TIME[SetPlace]=0;
                                        if((TIME[SetPlace]>=0x24)&&(SetPlace==2))                //С?????23
                                                TIME[SetPlace]=0;
                                        if((TIME[SetPlace]>=0x32)&&(SetPlace==3))                //??????31
                                                TIME[SetPlace]=0;
                                        if((TIME[SetPlace]>=0x13)&&(SetPlace==4))                //??????12
                                                TIME[SetPlace]=1;
                                        if((TIME[SetPlace]>=0x7)&&(SetPlace==5))                //??????7
                                                TIME[SetPlace]=1;
//                                        if(SetPlace==5)                //??????12
//                                                TIME[SetPlace]=;
                                while((i<50)&&(K2==0))         //???????????
                                        Delay10ms();
                                        i++;
                                i=0;
                                if(K4==0)                //?????K2?????
                                if(K4==0)
                                        TIME[SetPlace]--;
                                        if((TIME[SetPlace]==0x00)&&(SetPlace<2))                //????????59
                                                TIME[SetPlace]=60;
                                        if((TIME[SetPlace]==0x00)&&(SetPlace==2))                //С?????23
                                                TIME[SetPlace]=24;
                                        if((TIME[SetPlace]==0x00)&&(SetPlace==3))                //??????31
                                                TIME[SetPlace]=31;
                                        if((TIME[SetPlace]==0x01)&&(SetPlace==4))                //??????12
                                                TIME[SetPlace]=12;
                                        if((TIME[SetPlace]==0x1)&&(SetPlace==5))                //??????7
                                                TIME[SetPlace]=7;
                                while((U<50)&&(K4==0))         //???????????
                                        Delay10ms();
                                        U++;
                                U=0;
                LcdDisplay();
                        keypros();
                if(start==1)
                        sound();
                        beep=1;
                if((TIME[1]==0)&&(TIME[2]==0))
                sound();
/*        if(TIME[1]==0&&TIME[2]==0)
         sound();
* ??????         : LcdDisplay()
void LcdDisplay()
        LcdWriteCom(0x80+0X40);
        LcdWriteData('0'+TIME[2]/16);                                //?
        LcdWriteData('0'+(TIME[2]&0x0f));
        LcdWriteData('-');
        LcdWriteData('0'+TIME[1]/16);                                //??
        LcdWriteData('0'+(TIME[1]&0x0f));
        LcdWriteData('-');
        LcdWriteData('0'+TIME[0]/16);                                //??
        LcdWriteData('0'+(TIME[0]&0x0f));
        LcdWriteCom(0x80);
        LcdWriteData('2');
        LcdWriteData('0');
        LcdWriteData('0'+TIME[6]/16);                        //??
        LcdWriteData('0'+(TIME[6]&0x0f));
        LcdWriteData('-');
        LcdWriteData('0'+TIME[4]/16);                        //??
        LcdWriteData('0'+(TIME[4]&0x0f));
        LcdWriteData('-');
        LcdWriteData('0'+TIME[3]/16);                        //??
        LcdWriteData('0'+(TIME[3]&0x0f));
        LcdWriteCom(0x8D);
        LcdWriteData('0'+(TIME[5]&0x07));        //????
* ??????         : Int0Configuration()
* ????????                   : ???????ж?0
        //????INT0
        IT0=1;//????????????????????
        EX0=1;//??INT0???ж??????
        EA=1;//?????ж?
* ??????         : Int0()
* ????????                   : ???ж?0 ?ж????
void Int0() interrupt 0
        Delay10ms();
        if(K3==0)
                SetState=~SetState;
                SetPlace=0;
                Ds1302Init();
* ??????         : Delay10ms
* ????????                   : ????????????10ms
void Delay10ms(void)   //??? 0us
    unsigned char a,b,c;
    for(c=1;c>0;c--)
        for(b=38;b>0;b--)
            for(a=130;a>0;a--);
下面是
#include"lcd.h"
* ?? ?? ??         : Lcd1602_Delay1ms
* ????????                   : ????????????1ms
* ??    ??         : c
* ?    ??         : ?ú???????12MHZ?????£?12???????????????
void Lcd1602_Delay1ms(uint c)   //??? 0us
    uchar a,b;
        for (; c>0; c--)
                 for (b=199;b>0;b--)
                          for(a=1;a>0;a--);
* ?? ?? ??         : LcdWriteCom
* ????????                   : ??LCDд?????????????
* ??    ??         : com
#ifndef         LCD1602_4PINS         //????ж??????LCD1602_4PINS?
void LcdWriteCom(uchar com)          //д??????
        LCD1602_E = 0;     //???
        LCD1602_RS = 0;           //?????????
        LCD1602_RW = 0;           //???д??
        LCD1602_DATAPINS = com;     //????????
        Lcd1602_Delay1ms(1);                //??????????
        LCD1602_E = 1;                  //д?????
        Lcd1602_Delay1ms(5);          //???????
        LCD1602_E = 0;
#else
        LCD1602_E = 0;         //???????
        LCD1602_RS = 0;         //???д??????
        LCD1602_DATAPINS = com;        //????4λ?????????P0??????λ????????????λ?????
        LCD1602_E = 0;
//        Lcd1602_Delay1ms(1);
        LCD1602_DATAPINS = com << 4; //???????λ
        LCD1602_E = 0;
#endif
* ?? ?? ??         : LcdWriteData
* ??    ??         : dat
void LcdWriteData(uchar dat)                        //д??????
        LCD1602_RS = 1;        //???????????
        LCD1602_DATAPINS = dat; //д??????
        LCD1602_E = 0;
#else
        LCD1602_RS = 1;          //???д??????
        LCD1602_DATAPINS = dat;        //????4λ?????????P0??????λ????????????λ?????
        LCD1602_E = 0;
        LCD1602_DATAPINS = dat << 4; //д?????λ
        LCD1602_E = 0;
#endif
* ?? ?? ??       : LcdInit()
* ????????                 : ?????LCD??
void LcdInit()                                                  //LCD??????????
        LcdWriteCom(0x38);  //?????
        LcdWriteCom(0x0c);  //?????????????
        LcdWriteCom(0x06);  //д???????1
        LcdWriteCom(0x01);  //????
        LcdWriteCom(0x80);  //??????????????
#else
        LcdWriteCom(0x32);         //??8λ??????4λ????
        LcdWriteCom(0x28);         //????λ???μ?????
#endif
再是ds1302時鐘芯片的程序
#include"ds1302.h"
uchar code READ_RTC_ADDR[7] = {0x81, 0x83, 0x85, 0x87, 0x89, 0x8b, 0x8d};
uchar code WRITE_RTC_ADDR[7] = {0x80, 0x82, 0x84, 0x86, 0x88, 0x8a, 0x8c};
uchar TIME[7] = {0, 0, 0x12, 0x20, 0x10, 0x02, 0x18};
void Ds1302Write(uchar addr, uchar dat)
        uchar n;
        RST = 0;
        _nop_();
        SCLK = 0;
        _nop_();
        RST = 1;
        _nop_();
        for (n=0; n<8; n++)
                DSIO = addr & 0x01;
                addr >>= 1;
                SCLK = 1;
                _nop_();
                SCLK = 0;
                _nop_();
        for (n=0; n<8; n++)
                DSIO = dat & 0x01;
                dat >>= 1;
                SCLK = 1;
                _nop_();
                SCLK = 0;
                _nop_();
        RST = 0;
        _nop_();
uchar Ds1302Read(uchar addr)
        uchar n,dat,dat1;
        RST = 0;
        _nop_();
        SCLK = 0;
        _nop_();
        RST = 1;
        _nop_();
        for(n=0; n<8; n++)
                DSIO = addr & 0x01;
                addr >>= 1;
                SCLK = 1;//???????????????DS1302???????
                _nop_();
                SCLK = 0;//DS1302????????????????
                _nop_();
        _nop_();
        for(n=0; n<8; n++)//???8λ????
                dat1 = DSIO;//?????λ???????
                dat = (dat>>1) | (dat1<<7);
                SCLK = 1;
                _nop_();
                _nop_();
        RST = 0;
        _nop_();        //?????DS1302??λ????????,??????
        SCLK = 1;
        _nop_();
        DSIO = 0;
        _nop_();
        DSIO = 1;
        _nop_();
        return dat;
* ?? ?? ??         : Ds1302Init
* ????????                   : ?????DS1302.
void Ds1302Init()
        uchar n;
        Ds1302Write(0x8E,0X00);                 //???д????????????д????????
        for (n=0; n<7; n++)//д??7??????????????????????????
                Ds1302Write(WRITE_RTC_ADDR[n],TIME[n]);
        Ds1302Write(0x8E,0x80);                 //??д????????
* ?? ?? ??         : Ds1302ReadTime
void Ds1302ReadTime()
        uchar n;
        for (n=0; n<7; n++)//???7??????????????????????????
                TIME[n] = Ds1302Read(READ_RTC_ADDR[n]);
ID:412862 發(fā)表于 2018-10-24 14:58 | 只看該作者
3個分開的頭文件
ID:303383 發(fā)表于 2018-10-24 17:49 | 只看該作者
提示: 作者被禁止或刪除 內(nèi)容自動屏蔽
ID:412862 發(fā)表于 2018-10-24 21:08 | 只看該作者
小貓貓愛吃魚 發(fā)表于 2018-10-24 17:49
你好!
1、整點報時,是語音播報,幾點整嗎?
2、定時鬧鐘,需要幾個?
是幾點整 只要蜂鳴器響就ok
定時鬧鐘能設(shè)置一個就好
ID:7485 發(fā)表于 2018-10-25 09:30 | 只看該作者
你走的像風(fēng) 發(fā)表于 2018-10-24 21:08
是幾點整 只要蜂鳴器響就ok
定時鬧鐘能設(shè)置一個就好
將“時”另存一個單元,每次讀取時間值,檢測讀到的值“時”和另存的是否為相同,不同有進位,就是整點。給蜂鳴器高電平發(fā)聲。然后將“時”另存的值改為新值。
發(fā)聲“時長”,由于一般都在數(shù)秒以上,可以采用定時器延時,一般不要用程序循環(huán)延時。也可以使用ds1302定時,方法有多種,例如可以比較“秒”的值,大于5秒(假設(shè)響5秒)則關(guān)斷蜂鳴器。讀1302的次數(shù)、顯示的次數(shù)都可以用來延時。
