這里介紹一個簡單的PIC單片機(jī) 讀/寫 MMC/SD 卡的小程序,希望大家能夠喜歡。
- // MMC module connections
- sbit Mmc_Chip_Select at LATC0_bit; // for writing to output pin always use latch (PIC18 family)
- sbit Mmc_Chip_Select_Direction at TRISC0_bit;
- // eof MMC module connections
- const LINE_LEN = 43;
- char err_txt[20] = "FAT16 not found";
- char file_contents[LINE_LEN] = "XX MMC/SD FAT16 library by Anton Rieckertn";
- char filename[14] = "MIKRO00x.TXT"; // File names
- unsigned short loop, loop2;
- unsigned long i, size;
- char Buffer[512];
- // UART1 write text and new line (carriage return + line feed)
- void UART1_Write_Line(char *uart_text) {
- UART1_Write_Text(uart_text);
- UART1_Write(13);
- UART1_Write(10);
- // Creates new file and writes some data to it
- void M_Create_New_File() {
- filename[7] = 'A';
- Mmc_Fat_Set_File_Date(2010, 4, 19, 9, 0, 0); // Set file date & time info
- Mmc_Fat_Assign(&filename, 0xA0); // Find existing file or create a new one
- Mmc_Fat_Rewrite(); // To clear file and start with new data
- for(loop = 1; loop <= 99; loop++) {
- UART1_Write('.');
- file_contents[0] = loop / 10 + 48;
- file_contents[1] = loop % 10 + 48;
- Mmc_Fat_Write(file_contents, LINE_LEN-1); // write data to the assigned file
- // Creates many new files and writes data to them
- void M_Create_Multiple_Files() {
- for(loop2 = 'B'; loop2 <= 'Z'; loop2++) {
- UART1_Write(loop2); // signal the progress
- filename[7] = loop2; // set filename
- Mmc_Fat_Assign(&filename, 0xA0); // find existing file or create a new one
- for(loop = 1; loop <= 44; loop++) {
- // Opens an existing file and rewrites it
- void M_Open_File_Rewrite() {
- filename[7] = 'C';
- Mmc_Fat_Assign(&filename, 0);
- for(loop = 1; loop <= 55; loop++) {
- // Opens an existing file and appends data to it
- // (and alters the date/time stamp)
- void M_Open_File_Append() {
- filename[7] = 'B';
- Mmc_Fat_Set_File_Date(2010, 4, 19, 9, 20, 0);
- Mmc_Fat_Append(); // Prepare file for append
- Mmc_Fat_Write(" for mikroElektronika 2010n", 27); // Write data to assigned file
- // Opens an existing file, reads data from it and puts it to UART
- void M_Open_File_Read() {
- char character;
- Mmc_Fat_Reset(&size); // To read file, procedure returns size of file
- for (i = 1; i <= size; i++) {
- Mmc_Fat_Read(&character);
- UART1_Write(character); // Write data to UART
- // Deletes a file. If file doesn't exist, it will first be created
- // and then deleted.
- void M_Delete_File() {
- filename[7] = 'F';
- Mmc_Fat_Assign(filename, 0);
- Mmc_Fat_Delete();
- // Tests whether file exists, and if so sends its creation date
- // and file size via UART
- void M_Test_File_Exist() {
- unsigned long fsize;
- unsigned int year;
- unsigned short month, day, hour, minute;
- unsigned char outstr[12];
- filename[7] = 'B'; //uncomment this line to search for file that DOES exists
- // filename[7] = 'F'; //uncomment this line to search for file that DOES NOT exist
- if (Mmc_Fat_Assign(filename, 0)) {
- //--- file has been found - get its create date
- Mmc_Fat_Get_File_Date(&year, &month, &day, &hour, &minute);
- UART1_Write_Text(" created: ");
- WordToStr(year, outstr);
- UART1_Write_Text(outstr);
- ByteToStr(month, outstr);
- WordToStr(day, outstr);
- WordToStr(hour, outstr);
- WordToStr(minute, outstr);
- //--- file has been found - get its modified date
- Mmc_Fat_Get_File_Date_Modified(&year, &month, &day, &hour, &minute);
- UART1_Write_Text(" modified: ");
- //--- get file size
- fsize = Mmc_Fat_Get_File_Size();
- LongToStr((signed long)fsize, outstr);
- UART1_Write_Line(outstr);
- else {
- //--- file was not found - signal it
- UART1_Write(0x55);
- Delay_ms(1000);
- // Tries to create a swap file, whose size will be at least 100
- // sectors (see Help for details)
- void M_Create_Swap_File() {
- unsigned int i;
- for(i=0; i<512; i++)
- Buffer[i] = i;
- size = Mmc_Fat_Get_Swap_File(5000, "mikroE.txt", 0x20); // see help on this function for details
- if (size) {
- LongToStr((signed long)size, err_txt);
- UART1_Write_Line(err_txt);
- for(i=0; i<5000; i++) {
- Mmc_Write_Sector(size++, Buffer);
- UART1_Write('.');
- // Main. Uncomment the function(s) to test the desired operation(s)
- void main() {
- #define COMPLETE_EXAMPLE // comment this line to make simpler/smaller example
- ADCON1 |= 0x0F; // Configure AN pins as digital
- CMCON |= 7; // Turn off comparators
- // Initialize UART1 module
- UART1_Init(19200);
- Delay_ms(10);
- UART1_Write_Line("PIC-Started"); // PIC present report
- // Initialize SPI1 module
- SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV64, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
- // use fat16 quick format instead of init routine if a formatting is needed
- if (Mmc_Fat_Init() == 0) {
- // reinitialize spi at higher speed
- SPI1_Init_Advanced(_SPI_MASTER_OSC_DIV4, _SPI_DATA_SAMPLE_MIDDLE, _SPI_CLK_IDLE_LOW, _SPI_LOW_2_HIGH);
- //--- Test start
- UART1_Write_Line("Test Start.");
- //--- Test routines. Uncomment them one-by-one to test certain features
- M_Create_New_File();
- #ifdef COMPLETE_EXAMPLE
- M_Create_Multiple_Files();
- M_Open_File_Rewrite();
- M_Open_File_Append();
- M_Open_File_Read();
- M_Delete_File();
- M_Test_File_Exist();
- M_Create_Swap_File();
- #endif
- UART1_Write_Line("Test End.");
- else {
- UART1_Write_Line(err_txt); // Note: Mmc_Fat_Init tries to initialize a card more than once.
- // If card is not present, initialization may last longer (depending on clock speed)
復(fù)制代碼 詳細(xì)內(nèi)容,請參考:http://www.torrancerestoration.com/bbs/dpj-138111-1.html
2018-10-26 09:10 上傳
