查看: 3896|回復: 0
基于51單片機的電子密碼鎖程序
ID:416660 發(fā)表于 2018-10-28 19:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
sbit rs=P1^0; //寄存器選擇位,將rs定義為p1.0
sbit rw=P1^1; //讀寫選擇位,將rw定義為p1.1
sbit en=P1^2;  //使能信號位將en定義為p1.2的引腳
sbit ledg=P1^3;
sbit ledr=P1^7;
sbit relay=P1^4;
sbit buzz=P1^6;
char table0[]="error";
char table1[]="open";
char table2[]="password:";
int temp,ch,m0,ml,p,n0,n1,n2,n3,n4,n5;
void  delay(int Z)
        int x,c;
        for(x=Z;x>0;x--)
        for(c=100;c>0;c--);
keyscan()
        temp=P2&0xf0;
        P2=0xfe;
        delay(1);
        temp=P2&0xf0;
        while(temp!=0xf0)
                switch(temp)
                   case 0xe0:ch='7';break;
                   case 0xd0:ch='8';break;
                   case 0xb0:ch='9';break;
                   default:ch=p; break;
        while(temp!=0xf0)
                 temp=P2;
                temp=temp&0xf0;
P2=0xfd;
delay(1);
temp=P2&0xf0;
while(temp!=0xf0)
        switch(temp)
                 case 0xe0:ch='4';break;
                case 0xd0:ch='5';break;
                case 0xb0:ch='6';break;
                default:ch=p;break;
         while(temp!=0xf0)
                temp=P2;
                temp=temp&0xf0;
P2=0xfb;
delay(1);
temp=P2&0xf0;
while(temp!=0xf0)
        switch(temp)
                case 0xe0:ch='l';break;
                case 0xd0:ch='2';break;
                case 0xb0:ch='3';break;
                default:ch=p;break;
      while(temp!=0xf0)
                temp=P2;
                temp=temp&0xf0;
P2=0xf7;
delay(1);
temp=P2&0xf0;
while(temp!=0xf0)
         switch(temp)
                case 0xe0:ch='A';break;
                case 0xd0:ch='0';break;
                case 0xb0:ch='B';break;
                default:ch=p;break;
         while(temp!=0xf0)
                 temp=P2;
                temp=temp&0xf0;
         return ch;
void wcom(uchar com)
        rs=0;
        P3=com;
        delay(1); //命令延時為1
        en=1;
        delay(1);
        en=0;
void wdat(uchar dat)
        rs=1;
        P3=dat;
        delay(1); //此處寫數(shù)據(jù)延時可以為1
        en=1l;
        delay(4); //此處寫數(shù)據(jù)延時至少為4
        en=0;
void init()
        en=0;
        wcom(0x38);
        wcom(0x0c);
        wcom(0x06);
        wcom(0x01);
void error()
        char m2;
        wcom(0xc6);
        for(m2=0;m2<5;m2++)
           wdat(table0[m2]);
void open()
        char m2;
        wcom(0xc6);
        for(m2=0;m2<4;m2++)
           wdat(table1[m2]);
void pass()
        char m2;
        wcom(0x80);
        for(m2=0;m2<9;m2++)
         wdat(table2[m2]);
change(int m)
        delay(500);
        wcom(m);
        wdat('*');
main()
          rw=0;
          ledg=0;
          ledr=0;
          relay=0;
        buzz=0;
        init();
        delay(5);
        pass();
        wcom(0x89);
        while(keyscan()==p)
                delay(3);
                keyscan();
        wdat(keyscan());
        n0=keyscan();
        change(0x89);
        delay(10);
        ch=p;
        while(keyscan()==p)
                delay(3);
                keyscan();
        wdat(keyscan());
        n1=keyscan();
        change(0x8a);
        ch=p;
        while(keyscan()==p)
        wdat(keyscan());
        n2=keyscan();
        change(0x8b);
        ch=p;
        while(keyscan()==p)
                delay(3);
                keyscan();
        wdat(keyscan());
        n3=keyscan();
        change(0x8c);
        ch=p;
        while(keyscan()==p)
                delay(3);
                keyscan();
        wdat(keyscan());
        n4=keyscan();
        change(0x8d);
        ch=p;
        while(keyscan()==p)
                delay(3);
                keyscan();
        wdat(keyscan());
        n5=keyscan();
        change(0x8e);
        if(n0=='2'&&n1=='0'&&n2=='1'&&n3=='4'&&n4=='1'&&n5=='9')
                int m3=1;
                open();
                relay=1;
                delay(3000);
                relay=0;
                while(m3)
                                int m4,m5;
                                ledg=0;
                                for(m4=200;m4>0;m4--)
                                        keyscan();
                                        if(keyscan()=='A')
                                                m4=0;
                                                m3=0;
                                ledg=1;
                                if(m3!=0)
                                        for(m5=200;m5>0;m5--)
                                                keyscan();
                                                if(keyscan()=='A')
                                                        m3=0;
        ledr=1;
        error();
        buzz=1;
        delay(5000);
Powered by 單片機教程網
