ov2640 IO口讀取驅(qū)動源碼,具體看壓縮包。
單片機源程序如下:
- * OV2640 driver.
- #include <config.h>
- #ifdef CAM2640
- #include <devices/ov2640.h>
- #include <devices/sensor.h>
- #include "ov2640_regs.h"
- const static uint8_t OV2640_AUTOEXPOSURE_LEVEL0[]=
- 0xFF, 0x01, 0xff,
- 0x24, 0x20, 0xff,
- 0x25, 0x18, 0xff,
- 0x26, 0x60, 0xff,
- 0x00, 0x00, 0x00
- const static uint8_t OV2640_AUTOEXPOSURE_LEVEL1[]=
- 0xFF, 0x01, 0xff,
- 0x24, 0x34, 0xff,
- 0x25, 0x1c, 0xff,
- 0x26, 0x70, 0xff,
- 0x00, 0x00, 0x00
- const static uint8_t OV2640_AUTOEXPOSURE_LEVEL2[]=
- 0xFF, 0x01, 0xff,
- 0x24, 0x3e, 0xff,
- 0x25, 0x38, 0xff,
- 0x26, 0x81, 0xff,
- 0x00, 0x00, 0x00
- const static uint8_t OV2640_AUTOEXPOSURE_LEVEL3[]=
- 0xFF, 0x01, 0xff,
- 0x24, 0x48, 0xff,
- 0x25, 0x40, 0xff,
- 0x26, 0x81, 0xff,
- 0x00, 0x00, 0x00
- const static uint8_t OV2640_AUTOEXPOSURE_LEVEL4[]=
- 0xFF, 0x01, 0xff,
- 0x24, 0x58, 0xff,
- 0x25, 0x50, 0xff,
- 0x26, 0x92, 0xff,
- 0x00, 0x00, 0x00
- static void SCCB_WriteRegs(sensor_t *sensor, const uint8_t * pbuf)
- uint8_t reg_addr;
- uint8_t reg_data;
- if (sensor == NULL) {
- return;
- while(1)
- if((*pbuf == 0) && (*(pbuf + 1) == 0))
- break;
- else
- reg_addr = *pbuf++;
- reg_data = *pbuf++;
- sal_fiic_write_slave_std(sensor->iic_dev, OV2640_IIC_ADDR, reg_data, reg_addr);
- static int set_auto_exposure_level(sensor_t *sensor, int level)
- return SAL_ERR_P_NULL;
- switch (level) {
- case 0:
- SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL0);
- break;
- case 1:
- SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL1);
- break;
- case 2:
- SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL2);
- break;
- case 3:
- SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL3);
- break;
- case 4:
- SCCB_WriteRegs(sensor, OV2640_AUTOEXPOSURE_LEVEL4);
- break;
- default:
- break;
- return 0;
- static int probe(sensor_t *sensor)
- sal_fiic_read_slave_std(sensor->iic_dev, OV2640_IIC_ADDR, OV_CHIP_ID, &sensor->chip_id);
- if (sensor->chip_id == OV2640_ID) {
- sal_info("OV2640 probe OK, OV2640 ID = 0x%02x.\r\n", sensor->chip_id);
- sensor->slv_addr = OV2640_IIC_ADDR;
- return SAL_OK;
- sal_err("OV2640 not found! chip_id read: %02x.\r\n", sensor->chip_id);
- return SAL_ERR;
- static int reset(sensor_t *sensor)
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_DSP_RA_DLMT, 0x01);
- sensor->iic_dev->delay_us(2);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_SENSOR_COM7, 0x80);
- return 0;
- static int set_bandw (sensor_t *sensor, uint8_t black_white)
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0xff, 0x00);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7c, 0x00);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, black_white);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7c, 0x05);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x80);
- return SAL_OK;
- static int set_auto_whitebal(sensor_t *sensor, int enable)
- #define CTRL1 0xC3
- #define CTRL1_AWB 0x08 /* Enable AWB */
- uint8_t reg;
- int ret = SAL_OK;
- sal_fiic_read_slave_std(sensor->iic_dev, sensor->slv_addr, 0xFF, ®);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0xFF, reg & (~0x01));
- sal_fiic_read_slave_std(sensor->iic_dev, sensor->slv_addr, CTRL1, ®);
- ret = sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, CTRL1, (reg & (~CTRL1_AWB)) | ((enable != 0) ? CTRL1_AWB : 0));
- return ret;
- static int set_color_effects (sensor_t *sensor, uint8_t value1, uint8_t value2)
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x18);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, value1);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, value2);
- return SAL_OK;
- static int set_contrast (sensor_t *sensor, uint8_t value1, uint8_t value2)
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x04);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7c, 0x07);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x20);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x06);
- return SAL_OK;
- static int set_brightness (sensor_t *sensor, uint8_t brightness)
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7c, 0x09);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, brightness);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x7d, 0x00);
- return SAL_OK;
- const unsigned char OV2640_JPEG_INIT[][2]=
- {0xff, 0x00},
- {0x2c, 0xff},
- {0x2e, 0xdf},
- {0xff, 0x01},
- {0x3c, 0x32},
- {0x11, 0x00},
- {0x09, 0x02},
- {0x04, 0x28},
- {0x13, 0xe5},
- {0x14, 0x48},
- {0x2c, 0x0c},
- {0x33, 0x78},
- {0x3a, 0x33},
- {0x3b, 0xfB},
- {0x3e, 0x00},
- {0x43, 0x11},
- {0x16, 0x10},
- {0x39, 0x92},
- {0x35, 0xda},
- {0x22, 0x1a},
- {0x37, 0xc3},
- {0x23, 0x00},
- {0x34, 0xc0},
- {0x36, 0x1a},
- {0x06, 0x88},
- {0x07, 0xc0},
- {0x0d, 0x87},
- {0x0e, 0x41},
- {0x4c, 0x00},
- {0x48, 0x00},
- {0x5B, 0x00},
- {0x42, 0x03},
- {0x4a, 0x81},
- {0x21, 0x99},
- {0x24, 0x40},
- {0x25, 0x38},
- {0x26, 0x82},
- {0x5c, 0x00},
- {0x63, 0x00},
- {0x61, 0x70},
- {0x62, 0x80},
- {0x7c, 0x05},
- {0x20, 0x80},
- {0x28, 0x30},
- {0x6c, 0x00},
- {0x6d, 0x80},
- {0x6e, 0x00},
- {0x70, 0x02},
- {0x71, 0x94},
- {0x73, 0xc1},
- {0x12, 0x40},//0x40
- /*SensorWindow */
- {0x17, 0x11},// HREFST[10:3]
- {0x18, 0x43},// HREFEND[10:3]
- {0x19, 0x00},// VSTRT[9:2]
- {0x1a, 0x4b}, // VEND[9:2]
- {0x32, 0x09},// Bit7..6--PCLK分頻設(shè)置,10二分頻,11四分頻; Bit[5:3]: HREFEND[2:0]; Bit[2:0]: HREFST[2:0][===zm.li==>定義Window(H*W):400*300]
- // {0x03, 0x0f}, Bit[3:2]: VEND[1:0]; Bit[1:0]: VSTRT[1:0]
- {0x37, 0xc0},
- {0x4f, 0x60},
- {0x50, 0xa8},
- {0x6d, 0x00},
- {0x3d, 0x38},
- {0x46, 0x3f},
- {0x4f, 0x60},
- {0x0c, 0x3c},
- {0xff, 0x00},
- {0xe5, 0x7f},
- {0xf9, 0xc0},
- {0x41, 0x24},
- {0xe0, 0x14},
- {0x76, 0xff},
- {0x33, 0xa0},
- {0x42, 0x20},
- {0x43, 0x18},
- {0x4c, 0x00},
- {0x87, 0xd5},
- {0x88, 0x3f},
- {0xd7, 0x03},
- {0xd9, 0x10},
- {0xd3, 0x82},
- {0xc8, 0x08},
- {0xc9, 0x80},
- {0x7c, 0x00},
- {0x7d, 0x00},
- {0x7c, 0x03},
- {0x7d, 0x48},
- {0x7d, 0x48},
- {0x7c, 0x08},
- {0x7d, 0x20},
- {0x7d, 0x10},
- {0x7d, 0x0e},
- {0x90, 0x00},
- {0x91, 0x0e},
- {0x91, 0x1a},
- {0x91, 0x31},
- {0x91, 0x5a},
- {0x91, 0x69},
- {0x91, 0x75},
- {0x91, 0x7e},
- {0x91, 0x88},
- {0x91, 0x8f},
- {0x91, 0x96},
- {0x91, 0xa3},
- {0x91, 0xaf},
- {0x91, 0xc4},
- {0x91, 0xd7},
- {0x91, 0xe8},
- {0x91, 0x20},
- {0x92, 0x00},
- {0x93, 0x06},
- {0x93, 0xe3},
- {0x93, 0x05},
- {0x93, 0x05},
- {0x93, 0x00},
- {0x93, 0x04},
- {0x93, 0x00},
- {0x93, 0x00},
- {0x93, 0x00},
- {0x93, 0x00},
- {0x93, 0x00},
- {0x93, 0x00},
- {0x93, 0x00},
- {0x96, 0x00},
- {0x97, 0x08},
- {0x97, 0x19},
- {0x97, 0x02},
- {0x97, 0x0c},
- {0x97, 0x24},
- {0x97, 0x30},
- {0x97, 0x28},
- {0x97, 0x26},
- {0x97, 0x02},
- {0x97, 0x98},
- {0x97, 0x80},
- {0x97, 0x00},
- {0x97, 0x00},
- {0xc3, 0xed},
- {0xa4, 0x00},
- {0xa8, 0x00},
- {0xc5, 0x11},
- {0xc6, 0x51},
- {0xbf, 0x80},
- {0xc7, 0x10},
- {0xb6, 0x66},
- {0xb8, 0xA5},
- {0xb7, 0x64},
- {0xb9, 0x7C},
- {0xb3, 0xaf},
- {0xb4, 0x97},
- {0xb5, 0xFF},
- {0xb0, 0xC5},
- {0xb1, 0x94},
- {0xb2, 0x0f},
- {0xc4, 0x5c},
- /*ImageSize定義*/
- {0xc0, 0x64},
- {0xc1, 0x4B},
- {0x8c, 0x00},/*H*W=800*600*/
- {0x86, 0x3D},
- {0x50, 0x00},
- /*ImageWindow 定義*/
- {0x51, 0xC8},
- {0x52, 0x96},
- {0x53, 0x00},
- {0x54, 0x00},
- {0x55, 0x00},
- /*OutSize定義*/
- {0x5a, 0xC8},
- {0x5b, 0x96},
- {0x5c, 0x00},
- {0xd3, 0x7f},
- {0xc3, 0xed},
- {0x7f, 0x00},
- {0xda, 0x00},
- {0xe5, 0x1f},
- {0xe1, 0x67},
- {0xe0, 0x00},
- {0xdd, 0x7f},
- {0x05, 0x00},
- {0xd3, 0x7f},
- /*ImageSize定義*/
- {0xc0, 0x16},/*Image HSize[10..3]*/
- {0xC1, 0x12},/*Image VSize[10..3]*/
- {0x8c, 0x00},/*Bit6--HSize[11]?, Bit5..3--HSize[2..0], Bit2..0--VSize[2..0]*//*H*V= 176*144 */
- {0x86, 0x3d},
- {0x50, 0x00},
- {0x51, 0x2C},/*HSize[7..0]*/
- {0x52, 0x24},/*VSize[7..0]*/
- {0x53, 0x00},/*Offerset_X[7..0]*/
- {0x54, 0x00},/*Offerset_Y[7..0]*/
- {0x55, 0x00},/*Bit7-VSize[8], Bit6..4-Offerset_Y[10..8],Bit3-HSize[8], Bit2..0-Offerset_Y[10..8]*/
- /*OutSize定義*/
- {0x5A, 0x2c},/*OutW[7..0]*/
- {0x5b, 0x24},/*OutH[7..0]*/
- {0x5c, 0x00},/*Bit7..4-Zoom Spead, Bit2-OutH[8], Bit1..0-OutW[9..8]*/
- const unsigned char OV2640_YUV422[][2]=
- {0xFF, 0x00},/*選中DSP[寄存器bank選擇0--DSP, 1--Sensor]*/
- {0x05, 0x00},/*bit0 = 0-->DSP處理采集圖像(非Bypass DSP直接將Sensor數(shù)據(jù)輸出)*/
- {0xDA, 0x10},/*bit4=1-->JPEG輸出,bit3..2=0-->YUV422格式,bit1=0-->HREF與sensor相同,bit0=0-->High byte first YUYV(C2[4]=0復(fù)位缺省)*/
- {0xD7, 0x03},/*芯片保留寄存器*/
- {0xDF, 0x00},/*芯片保留寄存器*/
- {0x33, 0x80},/*芯片保留寄存器*/
- {0x3C, 0x40},/*芯片保留寄存器*/
- {0xe1, 0x77},/*芯片保留寄存器*/
- {0x00, 0x00},/*芯片保留寄存器*/
- const unsigned char OV2640_RGB565[][2]=
- {0xDA, 0x1C},/*bit4=1-->JPEG輸出,bit3..2=11-->RGB565格式,bit1=0-->HREF與sensor相同,bit0=0-->High byte first YUYV(C2[4]=0復(fù)位缺省)*/
- const unsigned char OV2640_JPEG[][2]=
- {0xe0, 0x14},/*芯片保留寄存器*/
- {0xe5, 0x1f},/*芯片保留寄存器*/
- {0xd7, 0x03},/*芯片保留寄存器*/
- {0xda, 0x10},/*芯片保留寄存器*/
- {0xe0, 0x00},/*芯片保留寄存器*/
- {0xFF, 0x01},
- {0x04, 0x08},
- /* JPG 160x120 */
- const unsigned char OV2640_160x120_JPEG[][2]=
- {0xff, 0x01},
- {0x12, 0x40},
- {0x17, 0x11},
- {0x18, 0x43},
- {0x19, 0x00},
- {0x1a, 0x4b},
- {0x32, 0x09},
- {0x4f, 0xca},
- {0x50, 0xa8},
- {0x5a, 0x23},
- {0x6d, 0x00},
- {0x39, 0x12},
- {0x35, 0xda},
- {0x22, 0x1a},
- {0x37, 0xc3},
- {0x23, 0x00},
- {0x34, 0xc0},
- {0x36, 0x1a},
- {0x06, 0x88},
- {0x07, 0xc0},
- {0x0d, 0x87},
- {0x0e, 0x41},
- {0x4c, 0x00},
- {0xff, 0x00},
- {0xe0, 0x04},
- {0xc0, 0x64},
- {0xc1, 0x4b},
- {0x86, 0x35},
- {0x50, 0x92},
- {0x51, 0xc8},
- {0x52, 0x96},
- {0x53, 0x00},
- {0x54, 0x00},
- {0x55, 0x00},
- {0x57, 0x00},
- {0x5a, 0x28},
- {0x5b, 0x1e},
- {0x5c, 0x00},
- {0xe0, 0x00},
- /* JPG 176x144 */
- const unsigned char OV2640_176x144_JPEG[][2]=
- {0xff, 0x01},
- {0x11, 0x05},/*攝像頭晶振6MHz、主控MCU工作頻率16MHz時,此寄存器可設(shè)為0x05(6分頻)、0x0B(12分頻)*/
- {0x12, 0x00}, // Bit[6:4]: Resolution selection//0x02為彩條
- {0x17, 0x11}, // HREFST[10:3]
- {0x18, 0x75}, // HREFEND[10:3]
- {0x32, 0x36}, // Bit[5:3]: HREFEND[2:0]; Bit[2:0]: HREFST[2:0]
- {0x19, 0x01}, // VSTRT[9:2]
- {0x1a, 0x97}, // VEND[9:2]
- {0x03, 0x0f}, // Bit[3:2]: VEND[1:0]; Bit[1:0]: VSTRT[1:0]
- {0x37, 0x40},
- {0x4f, 0xbb},
- {0x50, 0x9c},
- {0x5a, 0x57},
- {0x6d, 0x80},
- {0x3d, 0x34},
- {0x39, 0x02},
- {0x35, 0x88},
- {0x22, 0x0a},
- {0x37, 0x40},
- {0x34, 0xa0},
- {0x06, 0x02},
- {0x0d, 0xb7},
- {0x0e, 0x01},
- //176x144
- {0xff, 0x00},
- {0xc2, 0xcc},
- {0xc0, 0xc8},
- {0xc1, 0x96},
- {0x8c, 0x00},
- {0x86, 0x3d},
- {0x50, 0x9b},
- {0x51, 0x90},
- {0x52, 0x2c},
- {0x53, 0x00},
- {0x54, 0x00},
- {0x55, 0x88},
- {0x5a, 0x2c},
- {0x5b, 0x24},
- {0x5c, 0x00},
- {0xd3, 0x7F},
- /* JPG 320x240 */
- const unsigned char OV2640_320x240_JPEG[][2]=
- {0xff, 0x01},
- {0x37, 0x40},
- {0x4f, 0xbb},
- {0x50, 0x9c},
- {0x5a, 0x57},
- {0x6d, 0x80},
- {0x3d, 0x34},
- {0x39, 0x02},
- {0x35, 0x88},
- {0x22, 0x0a},
- {0x37, 0x40},
- {0x34, 0xa0},
- {0x06, 0x02},
- {0x0d, 0xb7},
- {0x0e, 0x01},
- //320*240
- {0xff, 0x00},
- {0xe0, 0x04},
- {0xc0, 0xc8},
- {0xc1, 0x96},
- {0x86, 0x3d},
- {0x50, 0x92},
- {0x51, 0x90},
- {0x52, 0x2c},
- {0x53, 0x00},
- {0x54, 0x00},
- {0x55, 0x88},
- {0x57, 0x00},
- {0x5a, 0x50},
- {0x5b, 0x3c},
- {0x5c, 0x00},
- {0xd3, 0x7F},
- {0xe0, 0x00}
- /* JPG 352x288 */
- const unsigned char OV2640_352x288_JPEG[][2]=
- {0xff, 0x01},
- {0x12, 0x40},
- {0x17, 0x11},
- {0x18, 0x43},
- {0x19, 0x00},
- {0x1a, 0x4b},
- {0x32, 0x09},
- {0x4f, 0xca},
- {0x50, 0xa8},
- {0x5a, 0x23},
- {0x6d, 0x00},
- {0x39, 0x12},
- {0x35, 0xda},
- {0x22, 0x1a},
- {0x37, 0xc3},
- {0x23, 0x00},
- {0x34, 0xc0},
- {0x36, 0x1a},
- {0x06, 0x88},
- {0x07, 0xc0},
- {0x0d, 0x87},
- {0x0e, 0x41},
- {0x4c, 0x00},
- {0xff, 0x00},
- {0xe0, 0x04},
- {0xc0, 0x64},
- {0xc1, 0x4b},
- {0x86, 0x35},
- {0x50, 0x89},
- {0x51, 0xc8},
- {0x52, 0x96},
- {0x53, 0x00},
- {0x54, 0x00},
- {0x55, 0x00},
- {0x57, 0x00},
- {0x5a, 0x58},
- {0x5b, 0x48},
- {0x5c, 0x00},
- {0xe0, 0x00}
- static int set_jpeg_img_format (sensor_t *sensor, image_format_e img_format)
- uint32_t i;
- reset(sensor);
- HAL_Delay(200);
- /* Initialize OV2640 */
- for (i = 0; i < (sizeof(OV2640_JPEG_INIT) / 2); i++) {
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_JPEG_INIT[i][0], OV2640_JPEG_INIT[i][1]);
- HAL_Delay(2);
- /* Set to output OV2640_RGB565 (2560bytes size vs 3072 in YUV422 mode.) OV2640_YUV422 */
- for (i = 0; i < (sizeof(OV2640_YUV422) / 2); i++) {
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_YUV422[i][0], OV2640_YUV422[i][1]);
- HAL_Delay(2);
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0xff, 0x01); /*選中Sensor寄存器bank*/
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, 0x15, 0x00); /*設(shè)置結(jié)果:bit5=0-->PCLK持續(xù)輸出;bit4=0-->數(shù)據(jù)在PCLK降沿時更新好;
- bit3=0-->HRef正極性輸出;bit1=0-->VSYNC正極性輸出;*/
- /* Set to output JPEG */
- for (i = 0; i < (sizeof(OV2640_JPEG) / 2); i++) {
- sal_fiic_write_slave_std(sensor->iic_dev, sensor->slv_addr, OV2640_JPEG[i][0], OV2640_JPEG[i][1]);
- HAL_Delay(2);
- HAL_Delay(100);
- uint8_t data = 0;
下載:
ov2640.zip
(4.68 KB, 下載次數(shù): 32)
2018-10-28 20:32 上傳
點擊文件名下載附件
下載積分: 黑幣 -5
