AT1846S引腳圖:
2018-10-31 00:29 上傳
AT1846S_datasheet_v0.2:
1. General Description
The AT1846S is a highly integrated single-chip
transceiver for Walkie Talkie applications. It totally
realizes the translation from RF carrier to voice in
the RX path and from voice to RF carrier in the TX
path, requiring only one micro controller.
The AT1846S has a powerful digital signal
processor, which makes it have optimum voice
quality, flexible function options, and robust
performance under varying reception conditions.
The AT1846S can be tuned to the worldwide
frequency band for Walkie Talkie from 400MHz to
500MHz and especially from 134MHz to 174MHz
which meets the frequency band of weather
broadcast.
The transceiver uses the CMOS process with a
package size of 5X5mm. By virtue of its high
integration, it requires the least external
components and eliminates the complicated
design of sensitive RF circuits on PCB.
2018-10-31 00:30 上傳
完整的pdf格式文檔51黑下載地址:
AT1846S_datasheet_v0.2.pdf
(7.75 MB, 下載次數(shù): 159)
2018-10-30 17:37 上傳
點(diǎn)擊文件名下載附件
規(guī)格書 下載積分: 黑幣 -5
