查看: 1366|回復: 2
求大佬幫忙把下面單片機程序改成非中斷函數(shù)
ID:418072 發(fā)表于 2018-10-31 11:17 | 顯示全部樓層 |閱讀模式
#include <reg51.h>
sbit wei1=P3^4;
sbit wei2=P3^5;
sbit wei3=P3^6;
sbit wei4=P3^7;
sbit led=P1^0;
unsigned char segdat[16]=
{0xc0,
0xf9,
0xa4,
0xb0,
0x99,
0x92,
0x82,
0xf8,
0x80,
0x90,        };
unsigned int cnt=0,kevval;
void delay(unsigned int x);
void display_seg4(unsigned int dat,unsigned char tim);
void INIT_int0(void);
unsigned int js=0;
unsigned char flag=0;
void main(void)
INIT_int0();
   if(flag==1)
  js++;
  if(js>=10000)
    js=0;
  if(flag==0)
     js=0;
  display_seg4(js,2);
void zduan(void) interrupt 0
flag++;
if(flag==3)
flag=0;
unsigned int i,j;
for(i=0;i<x;i++)
   for(j=0;j<100;j++)
IT0=1;
IE0=0;
EX0=1;
EA=1;
unsigned char tmp;
tmp=dat/1000%10;
P2=segdat[tmp];
wei1=1;
delay(20);P2=0xff;wei1=0;
tmp=dat/100%10;
P2=segdat[tmp];
wei2=1;
delay(20); P2=0xff;wei2=0;
tmp=dat/10%10;
P2=segdat[tmp];
wei3=1;
delay(20); P2=0xff;wei3=0;
tmp=dat%10;
P2=segdat[tmp];
wei4=1;
delay(20); P2=0xff;wei4=0;
ID:277550 發(fā)表于 2018-10-31 23:21 | 顯示全部樓層
這是外部中斷,不要外部中斷,就改成主循環(huán)中自動計數(shù)、延時累加,,,,,,,,,,,
ID:149144 發(fā)表于 2018-11-1 12:12 | 顯示全部樓層
不知道你的具體意思,附件里有仿真,希望對你有幫助按鍵表示開始和清零
#include <reg51.h>
sbit wei1 = P3^4;
sbit wei2 = P3^5;
sbit wei3 = P3^6;
sbit wei4 = P3^7;
sbit ledA  = P1^0;
sbit ledB  = P1^1;
sbit ButtonA = P3^2;        // * *
sbit ButtonB = P3^3;        // * *
#define Seg_7_4 P2                // * *
unsigned char segdat[10]= {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90 };
//unsigned int cnt = 0,kevval = 0;
void initTimer(void);
void display_seg4(unsigned int dat);//,unsigned char tim
unsigned int js = 0;
unsigned char flag  = 0;
unsigned char times = 0;
void main(void)
        initTimer();
        INIT_int0();
        TR0 = 1;
        ET0 = 1;
        EA  = 1;
        ButtonA = 1;
        ButtonB = 1;
                display_seg4(js);//   *  *
                if(flag == 0)
                        times = 0;//清零
                        js = 0;//清零  JS 計數(shù) ? 還是劍圣 ?
void timer0(void) interrupt 1// 50 000 us = 50ms
        TH0=0x3c;
        TL0=0xb0;
        if(flag == 1)
                if(++times > 20)// 50ms * 20 = 1s  想看效果 這個改小
                        times = 0;
                        if(++js > 9999)
                                js = 0;
void zduan(void) interrupt 0//**
        delay(2);
        if(ButtonA == 0)
                if(++flag >1 )flag=0;//        * *   改成 2   2的時候就是暫停 3=0
void initTimer(void)//  *  *
TMOD=0x1;
TH0=0x3c;
TL0=0xb0;
        unsigned int i,j;
        for(i=0;i<x;i++)
                 for(j=0;j<100;j++)
        IT0=1;
        IE0=0;
        EX0=1;
        EA=1;
void display_seg4(unsigned int dat)//,unsigned char tim  //        * *
        unsigned char tmp;
        tmp = dat/1000;
        Seg_7_4 = segdat[tmp];
        wei1 = 1;
        delay(2);//        *        *
        Seg_7_4 = 0xff;
        wei1 =0;
        tmp = dat/100;
        wei2 = 1;
        delay(2);
        Seg_7_4 = 0xff;
        wei2 = 0;
        tmp = dat/10;
        wei3 = 1;
        delay(2);
        Seg_7_4 = 0xff;
        wei3 = 0;
        tmp = dat%10;
        wei4 = 1;
        delay(2);
        Seg_7_4 = 0xff;
        wei4 = 0;
51.rar
54.2 KB, 下載次數(shù): 6
