查看: 3039|回復(fù): 1
Arduino與labview串口通訊
ID:418577 發(fā)表于 2018-10-31 16:00 | 顯示全部樓層 |閱讀模式
const unsigned char LED = 13;
byte comData;     //定義從串口接收過來的數(shù)據(jù)
void setup() {
  // put your setup code here, to run once:
  Serial.begin(9600);       //初始化串口,波特率設(shè)置為9600
  pinMode(LED, OUTPUT);     //設(shè)置數(shù)字引腳為輸出模式
void loop() {
  // put your main code here, to run repeatedly:
  if (Serial.available() > 0)   //檢測串口緩沖區(qū)是否有數(shù)據(jù)
    comData = Serial.read();
    if (comData == 0x01)        //接收到該命令,則執(zhí)行關(guān)燈
      digitalWrite(LED, LOW);
    if (comData == 0x02)        //接收到該命令,則執(zhí)行開燈
      digitalWrite(LED, HIGH);
ID:518059 發(fā)表于 2020-6-7 19:09 | 顯示全部樓層
留個(gè)資源啊
