查看: 3193|回復(fù): 0
DSP仿真出現(xiàn)ACU_SEL Register write failed
ID:283156 發(fā)表于 2018-11-1 14:17 | 顯示全部樓層 |閱讀模式
之前板子一直好著呢,今天再插上后編譯仿真出現(xiàn)ACU_SEL Register write failed,不知道怎么回事,而且電流好像很低,LED燈就不怎么亮,之前偶爾出現(xiàn)過(guò)這樣情況,但是轉(zhuǎn)動(dòng)一下電源插口就好了,這次怎么就不行了,哪里出錯(cuò)了,請(qǐng)大神指教?謝謝仿真后出現(xiàn)如下
C28xx: GEL: Error while executing OnReset(1): Target failed to read register ST1
         at (ST1&~(0x0100)) [f28335.gel:322]
         at C28x_Mode() [f28335.gel:38]
         at OnReset(1)
C28xx: Flash Programmer: Warning: The configured device (TMS320F28335), does not match the detected device (). Flash Programming operations could be affected. Please consider modifying your target configuration file.
C28xx: Breakpoint Manager: Error enabling this function: ACU_SEL Register write failed
