激光測(cè)距源碼,跟大家分享一下
- GY53----MINI
- VCC----VCC
- GND----GND
- 1:GY53L1_TX---10
- 2:GY53L1_RX---11
- #include <SoftwareSerial.h>
- SoftwareSerial mySerial(10, 11); // RX, TX
- unsigned char re_Buf[11],counter=0;
- unsigned char sign=0;
- byte data_Buf[3]={0};
- void setup() {
- Serial.begin(9600);
- mySerial.begin(9600);
- mySerial.listen();
- delay(1);
- // mySerial.write(0XA5);
- // mySerial.write(0X45); //初始化,連續(xù)輸出模式
- //mySerial.write(0XEA); //初始化,連續(xù)輸出模式
- void loop() {
- unsigned char i=0,sum=0;
- unsigned char RangeStatus=0,Time=0,Mode=0;
- uint16_t distance=0;
- while (mySerial.available()) {
- re_Buf[counter]=(unsigned char)mySerial.read();
- if(counter==0&&re_Buf[0]!=0x5A) return; // 檢查幀頭
- counter++;
- if(counter==8) //接收到數(shù)據(jù)
- counter=0; //重新賦值,準(zhǔn)備下一幀數(shù)據(jù)的接收
- sign=1;
- if(sign)
- sign=0;
- for(i=0;i<7;i++)
- sum+=re_Buf[i];
- if(sum==re_Buf[i] ) //檢查幀頭,幀尾
- data_Buf[0]=re_Buf[4];
- data_Buf[1]=re_Buf[5];
- data_Buf[2]=re_Buf[6];
- distance=data_Buf[0]<<8|data_Buf[1];
- RangeStatus=(data_Buf[2]>>4)&0x0f;
- Time=(data_Buf[2]>>2)&0x03;
- Mode=data_Buf[2]&0x03;
- Serial.print("distance: ");
- Serial.print( distance);
- Serial.print(" mm,RangeStatus: ");
- Serial.print( RangeStatus);
- Serial.print(" ,Time: ");
- Serial.print( Time);
- Serial.print(",Mode: ");
- Serial.println( Mode);
- /*void serialEvent() {
- while (Serial.available()) {
- re_Buf[counter]=(unsigned char)Serial.read();
- counter++;
- sign=1;
全部資料51hei下載地址:
arduino.zip
(1.83 KB, 下載次數(shù): 18)
2018-11-4 21:32 上傳
點(diǎn)擊文件名下載附件
