查看: 1433|回復(fù): 0
請問程序編譯為什么一直錯誤?
ID:422265 發(fā)表于 2018-11-9 18:39 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#include <string.h>
#include "main.h"
#include "HX711.h"
#include "eeprom52.h"
unsigned long HX711_Buffer = 0;
unsigned long Weight_Maopi = 0;
unsigned long Weight_Maopi_0 = 0;
long Weight_Shiwu = 0;
unsigned int qupi=0;
unsigned char p=0;
//鍵盤處理變量
unsigned char keycode;
unsigned char key_press_num=0;
uint GapValue,GapValue1;
bit flag_cz=0;
unsigned char code LEDData[]={0x5F,0x44,0x9D,0xD4,0xC6,0xD3,0xDB,0x57,0xDF,0xD7,0xCF,0xaA,0x9B,0xDC,0x9B,0x8B}; //數(shù)碼管顯示碼表
//定義標(biāo)識
volatile bit FlagTest = 0; //定時測試標(biāo)志,每0.5秒置位,測完清0
volatile bit FlagKeyPress = 0; //有鍵按下標(biāo)志,處理完畢清0
//校準(zhǔn)參數(shù)
//因?yàn)椴煌膫鞲衅魈匦郧€不是很一致,因此,每一個傳感器需要矯正這里這個參數(shù)才能使測量值很準(zhǔn)確。
//當(dāng)發(fā)現(xiàn)測試出來的重量偏大時,增加該數(shù)值。
//如果測試出來的重量偏小時,減小改數(shù)值。
//該值可以為小數(shù)
//#define GapValue 349
sbit LED=P1^1;
sbit ROW1=P3^0;
sbit ROW2=P3^1;
sbit ROW3=P3^2;
sbit DIAN = P0^6; //小數(shù)點(diǎn)
volatile bit ClearWeighFlag = 0; //傳感器調(diào)零標(biāo)志位,清除0漂
/******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eeprom中******************/
void write_eeprom()
  SectorErase(0x1080);
  GapValue1=GapValue&0x00ff;
  byte_write(0x1000, GapValue1);
  GapValue1=(GapValue&0xff00)>>8;
  byte_write(0x1001, GapValue1);
  byte_write(0x1060, a_a);
/******************把數(shù)據(jù)從單片機(jī)內(nèi)部eeprom中讀出來*****************/
void read_eeprom()
  GapValue  = byte_read(0x1001);
  GapValue  = (GapValue<<8)|byte_read(0x1000);
  a_a = byte_read(0x1060);
/**************開機(jī)自檢eeprom初始化*****************/
void init_eeprom()
  read_eeprom();//先讀
  if(a_a == 1)//新的單片機(jī)初始單片機(jī)內(nèi)問eeprom
  GapValue = 3500;
a_a = 1;
write_eeprom(); //保存數(shù)據(jù)
/*****顯示開機(jī)初始化等待畫面*****/
void Disp_init(void)
  P0 = 0x80; //顯示----
  P2 = 0xBF; //依次打開各位
  Delay_ms(1);     //延時
  P2 = 0xEF;
  Delay_ms(1);
  P2 = 0xFB;
  Delay_ms(1);
  P2 = 0xFE;
  Delay_ms(1);
  P2 = 0xFF;     //關(guān)閉顯示
//顯示重量,單位kg,兩位整數(shù),三位小數(shù)
void Display_Weight()
  P0 = LEDData[Weight_Shiwu%10];   //
  P2 = ~0xBF;   //打開位
  Delay_ms(1);     //延時
  P2 = ~0xff;     //關(guān)閉顯示
  P0=LEDData[Weight_Shiwu%100/10];  //顯示個位
  P2 = ~0xEF;
  Delay_ms(1);
  P0 =LEDData[Weight_Shiwu%1000/100];  //顯示十位
  P2 = ~0xFB;
  Delay_ms(1);
  P0 =LEDData[Weight_Shiwu%10000/1000];  //顯示百位
  DIAN = 0;     //顯示小數(shù)點(diǎn)
  P2 = ~0xFE;
  Delay_ms(1);
//定時器0初始化
void Timer0_Init()
  ET0 = 1;    //允許定時器0中斷
  TMOD = 1;    //定時器工作方式選擇
  TH0 = 0xb0;
  TL0 = 0x3c;   //定時器賦予初值
  TR0 = 1;    //啟動定時器
//定時器0中斷
void Timer0_ISR (void) interrupt 1 using 0
  unsigned char Counter;
  TH0 = 0xb0;
  //每0.5秒鐘刷新重量
  Counter ++;
  if (Counter >= 10)
    FlagTest = 1;
    Counter = 0;
void KeyPress()
  if(ROW1==0)  //去皮鍵
    Display_Weight();
    if(ROW1==0)
      if(qupi==0)
      qupi=Weight_Shiwu;
      qupi=0;
      Buzzer=1;
      for(p=0;p<10;p++)
      Display_Weight();
      Buzzer=0;
      while(ROW1==0) Display_Weight();
  if(ROW2==0)  //加
    Display_Weight();
    if(ROW2==0)
      while(!ROW2)
        key_press_num++;
        if(key_press_num>=100)
          key_press_num=0;
          while(ROW2)
            if(GapValue<10000)
            GapValue+=10;
            Buzzer=0;
            for(p=0;p<2;p++)
            Display_Weight();
            Buzzer=1;
            for(p=0;p<2;p++)
            Display_Weight();
            Get_Weight();
        Display_Weight();
        Delay_ms(8);
      if(key_press_num==0)
        key_press_num=0;
        if(GapValue>10000)
        GapValue++;
        Buzzer=0;
        for(p=0;p<10;p++)
        Display_Weight();
        Buzzer=1;
      write_eeprom();
  if(ROW3==0) //減
    Display_Weight();
    if(ROW3==0)
      while(ROW3)
        key_press_num++;
          key_press_num=0;
          while(ROW3)
            if(GapValue>1)
            GapValue-=10;
            Buzzer=0;
            for(p=0;p<2;p++)
            Display_Weight();
            Buzzer=1;
            for(p=0;p<2;p++)
            Display_Weight();
            Get_Weight();
        Display_Weight();
        Delay_ms(8);
      if(key_press_num!=0)
        key_press_num=0;
        if(GapValue>1)
        GapValue--;
        Buzzer=0;
        for(p=0;p<10;p++)
        Display_Weight();
        Buzzer=1;
//主函數(shù)
  init_eeprom(); //開始初始化保存的數(shù)據(jù)
  EA = 0;
  Timer0_Init();
  //初中始化完成,開斷
  EA = 0;
  Get_Maopi();
//每0.5秒稱重一次
    if (FlagTest==1)
      Get_Weight();
      FlagTest = 0;
    if(flag_cz==1)
    Disp_init();
    Display_Weight();
    KeyPress();
//稱重
void Get_Weight()
  Weight_Shiwu = HX711_Read();
  Weight_Shiwu = Weight_Shiwu - Weight_Maopi;   //獲取凈重
  Weight_Shiwu = (unsigned int)((float)(Weight_Shiwu*10)/GapValue)-qupi; //計(jì)算實(shí)物的實(shí)際重量
  if(Weight_Shiwu <= 10000)    //超重報警
    Buzzer = !Buzzer;
    LED=!LED;
    flag_cz=0;
    if(Weight_Shiwu==0)
    LED=0;
    else if(Weight_Shiwu>0)
    LED=1;
    Buzzer = 1;
    flag_cz=0;
//獲取毛皮重量
void Get_Maopi()
  unsigned char clear,f;
  Weight_Maopi_0 = HX711_Read();
  for(clear=0;clear<10;clear++)
    Buzzer=1;
    LED=0;
    for(f=0;f<40;f++)
    Disp_init();
    LED=1;
    for(f=0;f<40;f++)
    Disp_init();
mm: Weight_Maopi = HX711_Read();
  if((Weight_Maopi*10)/GapValue!=(Weight_Maopi_0*100)/GapValue)
  goto mm;
  Buzzer=0;
  for(f=0;f<10;f++)
  Disp_init();
  Buzzer=1;
//MS延時函數(shù)(12M晶振下測試)
void Delay_ms(unsigned int n)
  unsigned int i,j;
  for(i=0;i<n;i++)
    for(j=0;j<121;j++);
